Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Perrin Performance
Old 06-10-2012, 09:28 PM   #1
PERRIN
NASIOC Manufacturer
Vendor Sales Rating: (10)
Member#: 6776
Default NEW Polyurethane Exhaust Hangers By PERRIN
WHY DO YOU NEED EXHAUST HANGERS?
When new, OEM rubber exhaust hangers are fine for the stock exhaust system. But they simply don't hold up or perform well in performance applications. Over time rubber breaks down and increases the amount of exhaust system movement. This excessive movement can damage the exhaust system as well as allow the hot tip to contact the bumper. PERRIN Polyurethane exhaust hangers are extra stiff to help keep your exhaust system in place, away from your bumper and other undercarriage parts. Most clients can install a set of hangers in less than 30 minutes with simple hand tools!
CONSTRUCTION
The PERRIN Polyurethane hangers are made from a special blend of polyurethane to withstand the temperature of high performance exhaust systems. In all kinds of conditions, from hot runs on a dyno, to freezing winter temps, the PERRIN exhaust hangers will outlast and outperform the stock hangers.
STIFFNESS
The stock rubber hangers are rated at a low durometer hardness of 55a. PERRIN hangers are rated at 75a to keep your exhaust under control with minimal additional NVH (Noise Vibration Harshness) to your car.
5 YEAR WARRANTY
PERRIN Performance warrants to the original purchaser, all PERRIN products to be free from defects in material and workmanship within a sixty (60) months period from the date of purchase.
PERRIN is offline   Reply With Quote
FS : 4 15 mm polyurethane exhaust hangers like new Nukinfutz88 Engine/Power/Exhaust 2 04-23-2012 10:21 PM
FS: 06 sti axle back with cobbs polyurethane exhaust hangers (price drop) nelli-son Engine/Power/Exhaust 0 07-20-2008 06:55 PM
FS: cobbs 12mm polyurethane exhaust hangers nelli-son Engine/Power/Exhaust 0 07-18-2008 08:35 PM
WTB: polyurethane exhaust hangers - Cobb, Kartboy (stock size, not XL) nimaxpro Private 'Wanted' Classifieds 2 08-20-2006 08:33 PM
One (1) long Kartboy polyurethane exhaust hanger gpatmac Private 'Wanted' Classifieds 3 10-30-2004 04:12 AM
Message Board Statistics All times are GMT -4. The time now is 12:40 PM.
