Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
View Poll Results: Your break-in style and oil consumption (OC)
Easy - Little to no OC 5 4.63%
Easy - Unusual OC 3 2.78%
Recommended - Little to no OC 68 62.96%
Recommended - Unusual 16 14.81%
Hard - Little to no OC 14 12.96%
Hard - Unusual OC 2 1.85%
Voters: 108. You may not vote on this poll
Old 09-21-2013, 06:24 AM   #301
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by Commander Keen View Post
Consumption rate from the last drain: 1qt / 3720 mi.
Well, that's not terrible. It's not ideal, but it's not terrible. I change my oil every 6.5k miles, so if I owned your car, I'd top off the oil level at 3250 miles, then I'd do a complete oil change at 6500 miles, shortly before the oil light comes on. With this strategy, you'd only be adding approximately 1 qt of oil between changes, and that's not too shabby.
sgoldste01 is offline   Reply With Quote
Old 09-21-2013, 12:09 PM   #302
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
I do something similar. I start with 5.3, then about 2500 miles later, I dump in the 0.7, then change again at 5000. It doesn't really worry me.
Commander Keen is online now   Reply With Quote
Old 11-30-2013, 02:45 PM   #303
Rknuckles
Member#: 374943
2013 Impreza sport
white
Default 2.0 oil consumption
Like many Impreza owners, I too am concerned with oil consumption. I'm new to the forum so please be patient. I have a 2013 Impreza sport with about 12,000 miles on the odometer now. Before the first 7500 mile recommended oil change, my car used about 2 quarts of oil. I looked for obvious signs of leakage but saw nothing. I added a quart about every 3000 miles to top it off figuring it was just burning off during break in per the factory manual. My problem is that after the first oil change I have used over 2 quarts in 3000 miles. This prompted the low level oil light to illuminate. I am currently having the dealership perform an official oil consumption test as the problem seems to be getting worse. Is there anyone that can give me some advice that has gone through this process? I don't believe that adding a quart of expensive synthetic oil every 1500 miles is acceptable even if it is within Subaru standards. I love the car, but I don't know if I can live with this condition.
Rknuckles is offline   Reply With Quote
Old 11-30-2013, 04:59 PM   #304
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
Just did the 30,000 mile oil change. I put the recommended 5.3 quarts in last time, got about 5 quarts out this time. I am more than happy with that.
foghelmut is online now   Reply With Quote
Old 11-30-2013, 09:38 PM   #305
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
Satin White Pearl
Same here, lost less than half a quart in 7k miles.
Haunty is offline   Reply With Quote
Old 12-06-2013, 01:55 PM   #306
79letour
Member#: 302570
2013 XV
DGM!
My 3/13 built Crosstrek will go 7500 miles without losing any oil.
Buyers beware 2/13 and earlier. Although folks on the XV forum with post 3/13 cars are having some reports of oil loss.
79letour is offline   Reply With Quote
Old 12-06-2013, 01:58 PM   #307
orndog
Member#: 34670
2013 No gears!
Saltine American
Has this not been posted?
http://techinfo.subaru.com/static/whatsNew.html
I don't have privileges to read, but there is a TSB.
orndog is offline   Reply With Quote
Old 12-06-2013, 02:34 PM   #308
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Just changed the oil on my 2012 Impreza Sport (5MT, with a 4/2012 build date, and 23k on the odometer) last night. I put 5.3 quarts in 5500 miles ago, and drained 5.0 quarts out last night. I'm fine with consuming 0.3 quarts in 5.5k miles.
I'm also continuing to enjoy my Fumoto valve every time I use it.
Old 12-08-2013, 12:05 PM   #309
Chris793
Member#: 336926
2013 Impreza Sport
Ice Silver
That is the same amount that came out of mine before if started consuming. I would bet yours did not burn anything, probably 0.3 left in the lines and pockets of the pan.
Chris793 is offline   Reply With Quote
Old 12-08-2013, 12:18 PM   #310
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
No, judging from the dipstick readings I saw over the 5.5k miles, I'd say that it truly did consume 0.3 qts over that oil change interval.
Old 07-19-2014, 05:11 PM   #311
79letour
Member#: 302570
2013 XV
DGM!
So after all this time it still hovers near 20%.
Old 07-19-2014, 10:42 PM   #312
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
yes. it isn't nearly as bad as you make it out to be
Old 07-20-2014, 01:19 AM   #313
rickrobin
Member#: 306993
2012 Impreza Ltd.
Ice Silver Metallic
Default Cold weather oil consumption
When new, my car used about 2/3 of a quart in 6000 miles (light came on). At about 30,000 miles, the light started coming on in around 3500 mi, and it seems to be holding to that usage so far - almost 40,000 mi now. Guess time will tell if the increase was due to break-in, or if it's ongoing. So far, anyway, it still only amounts to a quart or so between oil changes, so not bad really. BUT - in very cold weather (though not extreme - say, below 15 degrees), the light will come on in around 2000 mi. Happened the past two winters, each time returning to "normal" consumption when the weather warmed up. What does anyone think? Is the thin oil getting past the rings in pretty cold weather until the engine warms up? Could this be indicative of the known rings problem? Or else, would a slightly thicker oil in cold winters be a good idea?
rickrobin is offline   Reply With Quote
Old 07-20-2014, 05:41 AM   #314
79letour
Member#: 302570
2013 XV
DGM!
no, I would just take it to the dealer.
Old 07-20-2014, 05:43 AM   #315
79letour
Member#: 302570
2013 XV
DGM!
That actually would be worse.
('11-'14) 2012 break-in period... which oil? carrathanatos Impreza Forum 10 05-16-2012 07:36 PM
Break-in oil consumption... does not seem normal to me... hoeser Built Motor Discussion 40 10-22-2011 05:13 PM
No Oil Consumption Ever, Then Massive Oil Consumption - Where to Start? This Is Not Mike Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 48 12-30-2010 09:18 PM
DO oil catch cans help with oil consumption? 1/500yellowwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 01-10-2005 02:57 AM
oil consumption and synthetic oil happasaiyan Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 06-18-2004 01:08 PM
