View Poll Results: Your break-in style and oil consumption (OC)
Easy - Little to no OC 5 4.63%
Easy - Unusual OC 3 2.78%
Recommended - Little to no OC 68 62.96%
Recommended - Unusual 16 14.81%
Hard - Little to no OC 14 12.96%
Hard - Unusual OC 2 1.85%
Voters: 108. You may not vote on this poll
Old 07-28-2012, 12:33 PM   #126
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
was reading the owners manual today and it says on page 12-5 that 5w-30 or 5w-40 may be substituted if 0w-20 is unavailable. It did state that it should be be replaced with 0w-20 on the next change though. Makes me wonder if there would be any ill effect by just using 5w-20 or 5w-30 all the time, probably not.
Old 07-28-2012, 01:35 PM   #127
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
The manual says those oils may be used "if replenishment is needed", which is not the same as filling the entire crankcase with 5w40.
Commander Keen is offline   Reply With Quote
Old 07-28-2012, 01:56 PM   #128
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i agree, I wouldn't use 5w-40 ever on this car even in a pinch
Old 07-29-2012, 09:15 AM   #129
CLL_OBP
Member#: 310435
12 Sp Limited
M1 0W30 97,705 miles
Originally Posted by ALafya View Post
If Subaru would stand behind their product to an acceptable level, of say < 1/2 quart in oil-change period and fix anything that is more, under warranty
There's a big difference in what You and Subaru call acceptable. OCI is 7,500 and you say 1/2 quart but Subaru say more than 1 quart per 1,200 mi
Hearing from others like 79letour and Furiousd1983, we know that a fix is not going to happen.
For that "oil replenishment", I don't get that one at all. Subaru requires 0W-20 synthetic but you can use 5W-40 to bring the level back up Even if it's only a quart, 5W-40 is less efficient and doesn't protect as well at start up as other available choices so why mix heavy and thin. I would go with a 5W-20, 0W-30, 5W-30 instead.
CLL_OBP is offline   Reply With Quote
Old 07-29-2012, 01:34 PM   #130
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
I think I may try a 0w-30 for my next oil change and see if that helps to reduce my oil consumption. I burn approx a half quart of oil per 1200 miles which is only half of what's acceptable to Subaru, but still very unacceptable to me.
jr0bb5 is offline   Reply With Quote
Old 07-29-2012, 09:14 PM   #131
CLL_OBP
Member#: 310435
12 Sp Limited
I know it's a new engine and all but have you thought about using an oil additive like Engine Restore to slow consumption? I didn't see anything in the manual about not adding stuff to the oil. I used it in the past and it works.
Old 07-30-2012, 01:54 AM   #132
jr0bb5
Member#: 315353
5MT OBP/DGM
Hmm... haven't really thought about it but I know most car manufacturers frown on the use of any type of oil additive. It would be my luck that my engine grenades and they find an additive in my oil. Goodbye warranty.
I have a good feeling that switching to a heavier weight oil will help quell the consumption... the only question is: what possible adverse affects might arise by using a different oil? Besides a possible slight hit in fuel economy, I don't think anything serious would develop, but ya never know.
Old 07-30-2012, 01:57 AM   #133
Acrdys
Member#: 152261
2007 WRX 2.5
Crystal Gray Metallic
I just drove the car. No time to worry about how I drive the car while going to school.
5 years later... still no OC
Acrdys is offline   Reply With Quote
Old 07-30-2012, 09:14 PM   #134
FlySense88
Member#: 327665
So if I'm reading right the new subies burn oil? What's this about?
FlySense88 is offline   Reply With Quote
Old 07-30-2012, 09:21 PM   #135
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Some relatively small percentage of them do, and it's not just the new 2.0 liter engine. I know someone with a 2.5 liter Forester with the same problem.
It's my unproven theory that the break-in process matters. If you baby the engine during the first 1k miles, your chances of high oil consumption increases. Like I said, this isn't proven, but that's my story and I'm sticking with it.
sgoldste01 is offline   Reply With Quote
Old 08-01-2012, 04:11 PM   #136
rockymtnhigh
Member#: 326078
When did everyone do their first oil change? Manual says 7,500 but just wanted to make sure it's ok to wait that long.
rockymtnhigh is offline   Reply With Quote
Old 08-01-2012, 04:19 PM   #137
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Personally, I wouldn't go more than 3250 miles before replacing the factory fill of oil. And then I'd replace the oil with a product other than Mobil1. I bought a 3-pack of Subaru oil filters on eBay for a good price. And I installed a Fumoto valve, but this is optional.
Old 08-01-2012, 04:19 PM   #138
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
I did my first at 1,100 (changed it myself). I have a fairly short commute (just over 5 miles one way, stop & go) which probably qualifies as "severe conditions" so I plan on changing it every 3000 miles or so. I figure it's relatively cheap insurance, so why not.
Btw, no oil consumption yet (only 1600 miles on the odo tho).
gfxguy is offline   Reply With Quote
Old 08-01-2012, 04:44 PM   #139
CLL_OBP
Member#: 310435
12 Sp Limited
First oil went @ 2K miles and again @ 5K miles. I do 5K OCI. Switched to Penzoil Platinum 0W-20 and I use the OEM filters too. I'm going to hit eBay also to get a bundle deal like sgoldste01 did.
FY'sI -When I went to the dealer for the first OC, the guy handed me a short blue filter. I said "No no no, the one that came from the factory was black and taller than that." So he goes and gets "the other one". Just wanted to point that out.
Old 08-01-2012, 05:38 PM   #140
FlySense88
Member#: 327665
Ahhh I see. Ya know I heard that else where through the grapevine. Your basically saying check my oil often right?
Old 08-01-2012, 05:44 PM   #141
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yes, at least for the first 7500 miles until you determine your car's consumption rate. I've been checking my oil level weekly, and haven't seen any consumption yet. I only have 2700 miles on the odometer, and 1000 miles since I did my first oil change.
Some people are saying that Mobil1 is more likely to be consumed than other oil brands, but I can't confirm this. I'm using Amsoil OE 0W20 right now.
Old 08-01-2012, 06:10 PM   #142
CLL_OBP
Member#: 310435
12 Sp Limited
@9,350 miles. Just check the oil and it's still looks about 1/4" over the circle as it was after the 5k OC. I'm just thankful the car has been mechanically sound up to this point.
Old 08-01-2012, 06:32 PM   #143
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Mine seems to have dropped about 1/8" over the last 1500 miles, not too worried yet, it might be the oil too. In another 2k it is getting dumped for Amsoil Signature
Old 08-01-2012, 09:03 PM   #144
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
What oil is in the car now?
Old 08-02-2012, 06:15 PM   #145
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
amsoil xl 0w-20.
Old 08-02-2012, 06:16 PM   #146
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Those with consumption issues, is it primarily on subaru oil or aftermarket?
Old 08-02-2012, 09:27 PM   #147
FlySense88
Member#: 327665
I'm still trying to figure out why the oil consumption means so much?
Old 08-02-2012, 09:45 PM   #148
CLL_OBP
Member#: 310435
12 Sp Limited
Old 08-02-2012, 10:01 PM   #149
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Oil is the Blood of the engine. It needs it to operate correctly, Its dead with out it. It might be the single most important fluid associated with your car.
auskip07 is offline   Reply With Quote
Old 08-02-2012, 10:25 PM   #150
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
And also people don't expect their brand new cars to consume oil.
('11-'14) 2012 break-in period... which oil? carrathanatos Impreza Forum 10 05-16-2012 07:36 PM
Break-in oil consumption... does not seem normal to me... hoeser Built Motor Discussion 40 10-22-2011 05:13 PM
No Oil Consumption Ever, Then Massive Oil Consumption - Where to Start? This Is Not Mike Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 48 12-30-2010 09:18 PM
DO oil catch cans help with oil consumption? 1/500yellowwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 01-10-2005 02:57 AM
oil consumption and synthetic oil happasaiyan Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 06-18-2004 01:08 PM
