View Poll Results: Your break-in style and oil consumption (OC)
Easy - Little to no OC 5 4.63%
Easy - Unusual OC 3 2.78%
Recommended - Little to no OC 68 62.96%
Recommended - Unusual 16 14.81%
Hard - Little to no OC 14 12.96%
Hard - Unusual OC 2 1.85%
Voters: 108. You may not vote on this poll
Old 08-03-2012, 02:23 AM   #151
FlySense88
Member#: 327665
Originally Posted by sgoldste01
And also people don't expect their brand new cars to consume oil.
Right this. I came from a SS S/C we didn't have those problems. It's just new to me that's all. I'm learning the car.
FlySense88 is offline   Reply With Quote
Old 08-03-2012, 02:24 AM   #152
FlySense88
Member#: 327665
What's the best oil to get? I see to stay away from Mobil1
Old 08-03-2012, 04:18 PM   #153
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Amsoil, subaru, kendall (never heard of it but very popular for the foresters)
Old 08-03-2012, 04:34 PM   #154
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I'm sure this is a good product, but since I have access to Amsoil OE 0W20 for less, that's what I currently use:
http://shop.advanceautoparts.com/web...rol_99992220-p
sgoldste01 is online now   Reply With Quote
Old 08-03-2012, 05:22 PM   #155
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
here is another question. those with consumption issues, when did you do the first oil change?
Old 08-04-2012, 06:19 PM   #156
Furiousd1983
Member#: 295099
2013 Not so Hot HB
My first oil change was at 2956 miles. 2nd was at 7500. Car had shown no loss of oil up to that point. Low oil light at 12750ish miles and again at around 15k.
Furiousd1983 is offline   Reply With Quote
Old 08-04-2012, 07:08 PM   #157
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
OK, so that means your oil light came on 5250 miles after the oil change. Do you know what kind of oil was put into your car when the oil was changed at 7500 miles?
Old 08-11-2012, 01:37 PM   #158
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
I've read that on cold starts, the oil level covers the bores at least partially. Can anyone confirm this? Once oil is pumped throughout the engine, does the level sink to below the bores?
Does this also apply to EJs, and if so, how well do high mileage EJs retain their compression versus a typical inline four? If cold start wear is reduced, I don't have a problem with slightly elevated consumption.
Porsche specs its boxers to burn even more oil than ours. If this oil consumption is inherent to the boxer design, comparing it to inlines and Vs is pointless. Gravity works for and against them in different ways.
Commander Keen is offline   Reply With Quote
Old 08-13-2012, 10:59 AM   #159
1slowscoobie
Member#: 316880
2012 Impreza Sport
I don't have enough posts to vote but mine would be Recommended - Little to no OC
just over 5000 miles. I waited until 4500 for my first oil change, Castrol synthetic 0W20. I'll be watching for consumption closely over the next 5k though, hopefully nothing starts.
1slowscoobie is offline   Reply With Quote
Old 08-13-2012, 11:48 AM   #160
79letour
Member#: 302570
2013 XV
DGM!
Here's my dipstick after approximately 2000mi
http://m.youtube.com/my_videos#/watch?v=Wjce4brc5Xw
79letour is offline   Reply With Quote
Old 08-13-2012, 12:00 PM   #161
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
im not seeing any video.
auskip07 is offline   Reply With Quote
Old 08-13-2012, 12:29 PM   #162
79letour
Member#: 302570
2013 XV
DGM!
Old 08-13-2012, 02:12 PM   #163
Commander Keen
Member#: 319157
79, waiting ten minutes after shutdown is nothing. Let the car sit overnight and the level will rise significantly. I'm wondering if you guys who check the engine hot are overfilling and burning the excess off.
Old 08-13-2012, 02:19 PM   #164
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I don't know that overfilling would result in "burning the excess off". If you overfill an engine that doesn't consume oil, I don't believe it would burn the excess off. It might foam, which is bad for lubrication, but that's a different story.
Old 08-13-2012, 02:24 PM   #165
Commander Keen
Member#: 319157
A boxer may not be as tolerant of overfilling compared to an I or V engine.
Old 08-13-2012, 02:43 PM   #166
79letour
Member#: 302570
2013 XV
DGM!
It reads the same rt now and its been sitting three hours since I drove it fifteen miles at lunch. You can try do discredit/discount my oil consumption and dipstick readings, but you just don't get it. I've checked it a hundred times and a hundred ways, all I ever see is the level getting lower and lower every week. You guys are almost sad trying to come up with ridiculous excuses as to why my car is a lemon.
Old 08-13-2012, 02:57 PM   #167
Commander Keen
Member#: 319157
What is the engine's consumption rate over its lifetime?
Old 08-13-2012, 03:01 PM   #168
79letour
Member#: 302570
2013 XV
DGM!
Another huuge hole in your theory is that I've not added oil to my car. The dealer has. And I've asked SOA soooo many times for something in writing about dipstick gauges and oil capacity. I did my first change and poured in exactly 5.3 quarts and my dipstick read about 3/8 over the full dot. Two subsequent dealer changes have also shown the dipstick top full mark to be way too low on the stick.
Old 08-13-2012, 03:14 PM   #169
79letour
Member#: 302570
2013 XV
DGM!
I haven't drained it and measured but roughly a quart per 1500-2000 miles. I'm gonna drain it when the oil has 5k on it, measure, and put 5.3 quarts of Subaru oil in it. Since its on a dealer fill now, I won't know the exact rate till I dump the next fill. But my constantly dropping dipstick level is a good sign its burning it at a steady rate.
Old 08-13-2012, 03:30 PM   #170
Commander Keen
Member#: 319157
Mine was well over the full mark on 5.3q too, which is why I don't treat the dipstick as a precision instrument.
I have a drain valve fitted, so I'll be able to measure (and analyze) the remaining oil accurately in 1500 miles or so.
I'm looking forward to your analysis.
Old 08-13-2012, 03:42 PM   #171
79letour
Member#: 302570
2013 XV
DGM!
Right on, CK. Will definitely keep yall updated.
Old 08-16-2012, 06:58 AM   #172
brapple
Member#: 327032
2012 2.0i Premium
I am not sure how much oil, if any the wifes new Impreza is using. It currently has ~2,800 miles on it. I checked the oil level this morning at it was at the upper hole/marker on the dip stick. I don't recall 100% but I think this might be down alittle from when I checked it earlier on.
As for driving, I would say it was a normal break-in. She tried not to take it over 4k rpm for the first 1,000 miles. Commute to work is ~45 minutes and its about an even split of secondary roads and highway.
Also waiting for the engine and oil to cool is a good idea when taking a measurement. I checked the other day and it was below the upper mark, but it was very shortly after she got home.
I am planning on doing the first oil change this weekend.
brapple is offline   Reply With Quote
Old 08-17-2012, 08:08 PM   #173
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Originally Posted by sgoldste01 View Post
Some relatively small percentage of them do, and it's not just the new 2.0 liter engine. I know someone with a 2.5 liter Forester with the same problem.
It's my unproven theory that the break-in process matters. If you baby the engine during the first 1k miles, your chances of high oil consumption increases. Like I said, this isn't proven, but that's my story and I'm sticking with it.
You might be right about your theory. I read the manual before I drove the car, followed the break in instructions to the dot and my car consumes oil like a drunken irishman consumes beer. My low oil light has come on 3 times before my second scheduled oil change. Seems like the intervals of the light coming on are getting smaller and smaller. Started at about 4000km, then 3500, 3000, 2800, and now it just came on yesterday after 1800 km...Goooo Impreza!!
gregorz4 is offline   Reply With Quote
Old 08-17-2012, 08:13 PM   #174
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
You might be right about your theory. I read the manual before I drove the car, followed the break in instructions to the dot and my car consumes oil like a drunken irishman. My low oil light has come on 3 times before my second scheduled oil change. The intervals between when the light comes on seems to be getting smaller and smaller. The last interval between it going off is only 1800km!! gooooo impreza!!
Old 08-19-2012, 05:18 PM   #175
brapple
Member#: 327032
2012 2.0i Premium
well I just did the first oil change today at 3,144 miles .... Oil level was just alittle below the upper mark/hole on the dip stick. I put in exactly 5.3 qts and it was a good 1/4" above this mark.
('11-'14) 2012 break-in period... which oil? carrathanatos Impreza Forum 10 05-16-2012 07:36 PM
Break-in oil consumption... does not seem normal to me... hoeser Built Motor Discussion 40 10-22-2011 05:13 PM
No Oil Consumption Ever, Then Massive Oil Consumption - Where to Start? This Is Not Mike Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 48 12-30-2010 09:18 PM
DO oil catch cans help with oil consumption? 1/500yellowwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 01-10-2005 02:57 AM
oil consumption and synthetic oil happasaiyan Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 06-18-2004 01:08 PM
