#1 |
Member#: 142128
Vehicle:2012 WRX Charcoal Grey |
Hey Guys. New to the forums and was hoping for some help/info on installing the Cusco front strut bar.
I searched online and on forums on how to install these strut bar and it seemed straight forward. I tried to install the bar this weekend, and everything was going well until I tried to close the hood and noticed that the intercooler intake piece was bending backwards because the strut bar was in the way. I have the car on a level ground and tightened the bolts equally on both sides before tightening all the way down. I also tried to "push" the bar further back a bit, but that obviously didn't help. Any ideas on what im doing wrong? Thanks in advance.
#2 |
Member#: 142128
also helps if i told you guys that I have a 2012 wrx with everything stock so far.
#3 |
Member#: 88618
SCIC
Vehicle:1994 Legacy "The Silver Slug" |
Turn it around?
#4 |
Member#: 142128
Ummm.. i know i have it in the right direction.
#5 |
Member#: 294682
NESIC
Vehicle:02 wrx Sedona Red |
Photo?
#6 |
Member#: 118500
Vehicle:02 Silver Wagon "Stage 2" |
+1 for the photo.
#7 |
Member#: 142128
i'll be able to post a photo when i get home from work.
Thanks. |
#8 |
Member#: 142128
![]() The intercooler intake in the middle will hit the strut bar just by a few centimeters and it will bend backwards. Not sure what I did wrong on this install. If anyone has an advice/info it would be appreciated. Thanks |
#9 |
Member#: 123843
NESIC
Vehicle:2006 SGM WRX S2 Let LED's light your way! |
Do you have a sedan or hatch (just curious) and do you have the part-number for the bar?
I wonder if this is a bar for a non-turbo model or other Subaru model? |
#10 |
Member#: 142128
I have the sedan and the part number is: CUS 692 540 A
I bought the part from rallysportdirect.com |
#11 |
Member#: 123843
NESIC
Do you have any other pictures of the bar installed? Say from higher up in the center, and from the sides? I would like to see how the bar itself is shaped.
The center of the Beatrush bar is curved rearward to compensate for the I/C and Whiteline's is a smaller diameter tube versus the more wide and flat diameter bar by Cusco. The bar from GT Spec is similar to that of Cusco and based on the pictures posted on RSD's website, seems to sit a bit further back/closer to the firewall. It's also possible that the bar is correct, but because of manufacturing tolerances: your strut towers are closer to the front of the vehicle; the hood is closer to the windshield, and the intercooler splitter is also shifted toward the windshield. Because of this, everything comes together to make your day that much more frustrating; it won't fit. |
#12 |
Member#: 142128
![]() ![]() Hopefully you can get something out of this. It's just a very slight block. |
#13 |
n00b Moderator
Moderator Member#: 99397
RMIC
Vehicle:'13 BRZ, '13 STi SRs13 '83 Skyline '93 GTR |
trim the duct.
#14 |
Member#: 142128
I dont think triming the duct is going to work because it will still bend backwards. Unless i cut the whole duct off which I dont want to do that.
#15 |
Member#: 77637
I was about to order one of these for my car... guess I will wait.
#16 |
Member#: 142128
No one has any ideas?
#17 |
Member#: 171127
Vehicle:62XX Rotated *Mo Displacement |
Can you take a pic of EXACTLY where it is rubbing.......i am ray charles right now and don't see ****. Cusco front tower bar always angles backward, are you refering to the ac line?
#18 |
Member#: 77637
I went back to Rally Sport Direct's website and noticed this review/comment.
Cusco Front Strut Bar on 2011 WRX "Easy install. Just make sure when close the hood. the scoop that plastic may hit the strut bar...you can see the photo on Cusco instruction paper too..." Did you see anything in the instructions that mentions this? |
#19 |
Member#: 142128
I saw that on the rallysportdirect site also and talked to the support but they had no idea either.
#20 |
n00b Moderator
Moderator Member#: 140114
Vehicle:06 18G Semi Built SGM WRX |
Send it back, strut bars on these cars are for looks anyways.
#21 | |
Member#: 292246
International
Vehicle:2011 Diamond in the Dust |
I've been wondering about this as well. Fast WRX has this disclaimer on the description.
http://www.fastwrx.com/cusfronstrut.html |
#22 | |
Member#: 332887
Vehicle:2012 WRX stage 2+ DGM (sedan) |
Yes, the bar will hit your splitter. Luckily for me, I replaced my splitter when I purchased the Process West TMIC so I won't have this problem with installing mine. |
#23 | |
n00b Moderator
![]() ![]() ![]() But I am glad someone bumped a 6 month old thread.... |
#24 |
Member#: 332887
#25 |
n00b Moderator
Way to avoid the first part.
| Thread Tools | |
| Display Modes | |
| FS : 02-07 WRX/STi Cusco Front Strut bar & STi 26mm Whiteline front sway bar | 04jaxwrex | Suspension/Brakes/Handling | 4 | 03-08-2012 01:52 PM |
| 02 07 cusco front strut bar rear wagon strut bar | refuse | SCIC Private Classifieds | 3 | 09-05-2009 04:51 AM |
| wrx cusco front strut bar, ebay strut bar and new ebay H brace | ubi_scoobi | SCIC Private Classifieds | 12 | 07-26-2009 12:19 AM |
| FS:(socal) wrx 02-07 cusco front strut bar, ebay rear strut bar & new ebay H brace | ubi_scoobi | Suspension/Brakes/Handling | 1 | 07-23-2009 03:27 AM |
| Intercooler that will clear cusco front strut bar? | NYCshopper | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 11-04-2002 02:42 PM |
