Old 06-13-2012, 06:11 AM   #1
AlexNorinh
Member#: 176002
2001 WRX
Default Hybrid 2.5/Twin scroll GTX3076R Build
Thought I'd add my build thread to this forum also to just get the info out there. Car started its life as an ADM 2001 WRX (bugeye), but not much left of that now Ran the original EJ205 (hard!) to 240,000km before a rod bolt let go and made a good mess (lucky I had already started building). Cut to the chase...
Bits to go in:
New EJ255 Short Block
Balanced Crank & Rotating Assembly
CP 9:1 Pistons
Manley H Beam Rods
Modified Kando Twin Scroll Headers (TS T3 flange, dual EWG VTA, ceramic coated)
Custom 3" VBand Dump with Tomioka Racing 5" Body 100 Cell Metal Cat
Subaru 12mm Oil Pump
Subaru Timing Belt Kit & Water Pump
ID1000 Injectors (May get larger)
2x Turbosmart CompGate40 EWG's (Nominal gate pressure 12psi)
ADM 05 STi Heads (Mild port & clean up)
1mm Oversize Exhaust Valves (Cos some fkn retards cut the seats too deep)
Kelford 264 AVCS Cams
BC Springs
ARP 11mm Head Studs
STi Solid Steering Knuckle
Deatschwerks DW301 in tank Fuel Pump
Turn in Concepts Transmission Cross Member Bushings
JDM AH581 ECU
STi Group N Engine Mounts
Perrin 3" silicone intake
Exedy Racing 'Stage 1' clutch (15803HD)
Exedy FF501 Lightweight flywheel
Hyperflow 'Stage 3' Sump
Process West 72mm CAI & K&N Filter
JDM V7 STi DCCD Factory Option cluster
Garrett GTX3076 - 3" Intake 0.6 A/R, 3" VBand out, T3 twin scroll up 0.82 A/R
Process West Anti-Surge Tank with Bosch 044 Pump
JDM 08 STi AVCS Cam Sprockets
Already on the car:
Engine:
STi Factory Butterfly-less & Port matched TGV Housings
8mm Phenolic Spacers
Parallel Fuel Rails
PFI Fuel Pressure Regulator
Hyperflow Oil Cooler (Foglight mounted, thermo-less sandwich plate)
JustJap Alloy Radiator
Drift Catch Can
Grimmspeed 3-Port Boost Solenoid
Process West V1 FMIC
Driveline/Suspension/Brakes:
JDM 06 STi DCCD 6 Speed Gearbox
Plated R180 Rear Diff
Brembo Front Calipers (Painted World Rally Blue)
DBA5000 Front Rotors
Project Mu HC+ Front Pads
Goodridge Braided Brake Lines
STi R180 Rear Hubs & Driveshafts
Subaru 2 Pot Rear Calipers
DBA656 Rear Rotors
RaceBrakes Comp2 Rear Pads
STi Short Shifter
STi GrpN Transmission Mount
STi GrpN Pitch Stopper
Kartboy Rear Shifter Stay
Kartboy Front Stay Bushings
TiC Shift Linkage Bushings
TiC Pivot Bushings
Whiteline 22mm Front Swaybar
Whiteline Steering Rack Bushings
Whiteline Roll Centre Adjustment Kit
Whiteline LCA Offset Rear Bushings (Sport, Max Caster)
Superpro LCA Front Bushings
H&R Front Camber Bolts
Cusco H Brace (Factory U Brace Removed)
Cusco Front Strut Brace w/ Integrated Brake Stopper
Whiteline Rear Diff Outrigger Bushings
Whiteline Rear Subframe Lock Bolts
TiC Rear Diff Mount Bushings (Race)
STi Pillowball Rear Trailing Arm
Superpro Rear Trailing Arm/Hub Bushings
STi Pillowball Rear Control Arms
Poltec Pillowball Rear Swaybar Links/Mounts
Whiteline 22mm Adjustable Rear Swaybar
Whiteline Heavy Duty Rear Swaybar Mounts
Whiteline Rear Swaybar Lateral Locks
Cusco Rear Strut Brace
Tein SuperStreet Coilovers (Aus. Spec/Fulcrum, Strut Tops Set for Caster)
Volk TE37 17x8 +44
Exterior:
KSTech Scoop Delete
JDM STi HID Headlights (Kaixen 6000k HID Kit)
Coded Skirts
Coded Spats Front & Rear
Coded Side Markers
Coded Mesh Foglight Covers
Clear Side Indicators
Replica STi Grill
Project Mu Lock Nuts
Wingless Bootlid (Welded/Resprayed/De-badged)
Interior:
Greddy SMI Gauges (Oil/Water Temp, Oil Pressure)
Greddy Electronic Peak/Warn Boost Gauge
Innovate LC1 & XD16 Wideband Kit
LinkElectro Knocklink (Custom Outrigger)
Spiider DCCDPro Universal Controller
STi DCCD Thumbwheel & Manual/Auto Switch
Tein EDFC
STi Titanium Shift Knob
STi Alloy Shifter Trim
04 STi Steering Wheel
Brown-Davis Rear Harness Bar
Schroth 6 Point Harness (4 Point Setup)
Terrible Driver
The build is almost complete, but I'll add some pics anyway!
AlexNorinh is offline   Reply With Quote
Old 06-14-2012, 12:05 AM   #2
561wrx
Member#: 166427
03 wrx
oh man that is nice
561wrx is offline   Reply With Quote
Old 06-14-2012, 12:47 AM   #3
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
all that money and putting in a used timing belt?
NW2TONE is offline   Reply With Quote
Old 06-14-2012, 08:47 AM   #4
AlexNorinh
Member#: 176002
2001 WRX
Old 06-23-2012, 01:53 AM   #5
561wrx
Member#: 166427
03 wrx
Hey more I candy
Old 06-23-2012, 07:14 PM   #6
Purple Drink
Member#: 237470
2007 Varis WB STI
P. Silver
what oil pan is that? And let me know how the gtx3076 turbo does. I have a gt3788r twin scroll and i am thinking of going smaller. I put down 668 at the wheels and believe it or not the turbo is pretty responsive.
Only real difference in our builds is i have dart sleeves and 282/276 Kelford drag cams.
So as soon as you have numbers PM me if you dont want to make them public.
Thanks dude.
Purple Drink is offline   Reply With Quote
Old 06-23-2012, 08:29 PM   #7
LBell05STI
Member#: 305890
2005 STI
And Manley H-Beams? I run then in my motor but I will never see over 400whp.
LBell05STI is offline   Reply With Quote
Old 06-23-2012, 11:04 PM   #8
AlexNorinh
Member#: 176002
2001 WRX
Thanks dude.
It's a hyperflow sump:
http://www.hyperflow.com.au/index.ph...hyas-my9707s3k
I'm still on my run in tune (done about 450km), and only just started working on cruise and early spool, keeping things <0.8bar and <5000. I can tell you that it's super responsive and really wants to move. Using e90. These turbos down here in Victoria tend to max out at 300kw/400hp atw. I'll be sure to post results when I'm done, will also hit the drags at some point too.
Old 06-23-2012, 11:07 PM   #9
AlexNorinh
Member#: 176002
2001 WRX
As above, the single scroll gt/x3076r's here max out at 300kw/400hp atw on e. that's for single scroll 0.82 a/r rear housings. Being twin scroll I may lose some top end. Hoping the twin vta gates will help with that
Old 06-24-2012, 01:09 AM   #10
Purple Drink
Member#: 237470
2007 Varis WB STI
P. Silver
Wow, thats a pricy oil sump even for me
I am about to order the killerbee one but this one seems to have a better oil pick up system.
what do you think?
http://www.killerbmotorsport.com/ind...imalOilPan.htm
I was thinking either way no matter which one i get i am gonna make a custom oil return from the turbo. At 38lbs of boost i have a issue not getting the oil back out of the turbo on decel.
Old 06-24-2012, 11:25 PM   #11
CeeMan36
Member#: 323416
08' WRX
Looks like a good start to a great build, few things:
How much boost are you planning on running?
Did you decide to run 9:1 pistons to lower the compression?
How much clearance do you have on your Brembo's with the 17x8 wheel setup?
CeeMan36 is offline   Reply With Quote
Old 06-25-2012, 06:40 AM   #12
AlexNorinh
Member#: 176002
2001 WRX
what do you think?
This one was another option, as was the Moroso. I went with the Hyperflow as I could easily get local support if required.
Depends what the boost/kw ratio gets to be. I guess I could ballpark around 25psi or so, possibly less for longevity
Do you mean raise? Standard compression EJ25T is 8.2 or so. Using an EJ25 block and EJ20 heads raises compression again, and I also opted for the thinner STi headgasket. I haven't done the calcs, but my static compression ratio should be well over 9:1
From memory I have about 5-10mm. They are genuine Rays TE37's.
Old 06-26-2012, 12:30 AM   #13
CeeMan36
Member#: 323416
08' WRX
You clearly seem to know what your doing but i would like to exercise my knowledge a bit please feel free to correct me im here to learn.
Im alittle consfused as to why you would use thinner headgaskets which raises your CR when your trying to lower your CR since its already high after swapping heads?
I mean if you swap the heads and the CR raises to lets say 10:1 for example and your target CR is about 9:1 adding those gaskets could possibly put you inbetween?
I know im not an expert but it sounds contradicting. Like i said please correct me if im wrong theres obviosly a reason for you doing this.
Also ive been reading alot into these swaps why dont you just have the 2.0 heads machined out to match the 2.5 heads. It sounds like less of a pain in the ass and from what i understand it yields significant gains all throughout the powerband. This guy seems pretty competent http://forums.nasioc.com/forums/show....php?t=1942615.
Old 06-26-2012, 04:05 AM   #14
vicious_fishes
Member#: 158864
2003 SOHC destroker
iirc if you use a piston rated on the 57cc sti heads on the 50cc (or whatever it is) heads that the wrx and i think ej20's use, you add around 0.8 to the compression ratio.
so if the piston was rated to 8.2:1, it will have a comp ratio of about 9.0:1.
remember the pistons have their compression ratio on the sti calculated with the sti head gasket. the head CC's aren't including the head gasket.
vicious_fishes is online now   Reply With Quote
Old 06-26-2012, 10:12 AM   #15
AlexNorinh
Member#: 176002
2001 WRX
I'm using e85 full time, so could afford to bump the compression (that was the aim). I used CP's rated at 9:1, very minimal work was done to the combustion chamber - just rounded sharp edges to prevent hot spots. I haven't started tuning midrange or top end yet, but she seems to be taking timing just fine, which is to be expected on e85.
I'm fairly certain the builder recorded all the deck heights, etc, so in theory I could calculate my static CR. Although, I'm sure someone more familiar could probably ballpark it just from experience. Based on the above, my CR may be around 9.8 (assuming a balance of removal of combustion chamber material and deck height matching/used head skimming)? Either way, I'm not overly concerned. As long as I can land this turbo in the high efficiency zones with decent timing, I'll be happy
Old 06-26-2012, 06:25 PM   #16
CeeMan36
Member#: 323416
08' WRX
I have read that with E85 you can run a slightly higher CR! Good buildup so far, will you be posting dyno results/ more pics? Also are you using a standalone ECU?
Old 06-27-2012, 10:57 PM   #17
AlexNorinh
Member#: 176002
2001 WRX
Thanks. Standard ECU, will convert to Carberry ROM when it's all run in and I'm happy with the MAF tune. Ass-dyno tuning for the moment, will probably attend the next dyno day. I have lots of pics, what are you interested in seeing?
Old 06-28-2012, 02:03 AM   #18
CeeMan36
Member#: 323416
08' WRX
Basically whatever you feel is the important parts of your build, like the suspension setup, the interior, your car on the track or dyno, anything really... Im sure me and the other NASIOC members wont be disappointed haha
Old 06-28-2012, 12:13 PM   #19
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Im sure people have already said this but what a great build!! I love that integrated oil pickup for the oil pan too!!!
Bamofo is offline   Reply With Quote
Old 06-30-2012, 02:54 AM   #20
LETZgoBUDDY
Member#: 324745
^^ seriously. Massive props man. Keep it up.
LETZgoBUDDY is offline   Reply With Quote
Old 07-01-2012, 12:59 PM   #21
AlexNorinh
Member#: 176002
2001 WRX
Thanks guys. Hit 1200km, so time to turn it up soon! Some more pics in the interim:
Old 07-03-2012, 09:48 PM   #22
CeeMan36
Member#: 323416
08' WRX
^^^ Sick!
Old 07-05-2012, 09:18 AM   #23
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
What type of flange is the GTX3076R? It looks like a T3 but I could be wrong...matches the exhaust housing size too.
wgr73 is offline   Reply With Quote
Old 07-06-2012, 03:54 AM   #24
AlexNorinh
Member#: 176002
2001 WRX
Yup, it's T3
Old 07-06-2012, 12:43 PM   #25
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Nice! Those turbos are really nice!
UK GC8 2.35 twin scroll build P20SPD Built Motor Discussion 37 09-24-2009 03:25 AM
? 2.2 block, 2.5 twin cam heads ? schrott Built Motor Discussion 6 01-03-2009 07:49 AM
Andrewtech TurboXS hybrid 2.5 vf39 build bebemaster Proven Power Bragging 9 05-30-2008 05:35 PM
Hybrid 2.5 wrx with n/a 2.5 block turboz523 Subaru Conversions 5 03-08-2008 06:34 PM
hybrid 2.5 build womensecks Built Motor Discussion 29 06-21-2007 01:39 PM
