Old 07-08-2012, 01:45 PM   #26
jvsoundwave
Member#: 66060
2007 STI Limited#534
Crystal Gray
Looking good!
jvsoundwave is offline   Reply With Quote
Old 07-12-2012, 09:52 AM   #27
AlexNorinh
Member#: 176002
2001 WRX
Thanks
Quick update. I've done a little tuning and I've almost maxed the 65mm CAI and getting close-ish to the 300g/s hardlimit. This is only with 1.1 bar, slow ass spool, 5700 RPM and about 15* timing. Here's a Virtual Dyno, but I think it's a little enthusiastic. There's a drag day on the 21st which I hope to get to, but unsure how well the weather will hold..
AlexNorinh is offline   Reply With Quote
Old 07-21-2012, 10:21 AM   #28
AlexNorinh
Member#: 176002
2001 WRX
Made it's "debut" outing at the drags today, limited by the 300g/s limit (no load scaling workaround). Best time managed a 12.738@ 112.97mph (1.978 60'). This is with full interior, 1/2 tank of fuel, street tyres and still only 1.1 bar. Shifting at ~ 7200.
Here's an in-car vid of my second fastest run of the day - 12.895 @ 112.23mph 1.996 60'
Clearly I can't launch for **** :P
Old 09-16-2012, 02:38 AM   #29
AlexNorinh
Member#: 176002
2001 WRX
First time on a dyno yesterday. Fairly happy with the result, it's a very safe tune with 13* peak timing up to 17* redline, 12* AVCS peak to 0* by 5200 RPM, 11.5 AFR with e90
For comparison, a 2002 STi with a TD06SL2 20G 8cm, e90 made 230kW on this dyno and ran a 12.1 @ 115mph.
Clutch slipped as it came on boost, and only 19psi as injectors are reporting over 100% duty. Time for a stronger clutch and ID2000's...
UK GC8 2.35 twin scroll build P20SPD Built Motor Discussion 37 09-24-2009 03:25 AM
? 2.2 block, 2.5 twin cam heads ? schrott Built Motor Discussion 6 01-03-2009 07:49 AM
Andrewtech TurboXS hybrid 2.5 vf39 build bebemaster Proven Power Bragging 9 05-30-2008 05:35 PM
Hybrid 2.5 wrx with n/a 2.5 block turboz523 Subaru Conversions 5 03-08-2008 06:34 PM
hybrid 2.5 build womensecks Built Motor Discussion 29 06-21-2007 01:39 PM
