Old 06-13-2012, 12:58 PM   #1
toonz
Member#: 322044
Default JDM EJ20G Gates Timing belt.... which one?
I looked up on the website from Gates and I saw 2 different timing belts available for my engine...one was the T277 standard belt, the other was the T328RB racing belt... I would prefer the second choice but wanted to know which is the one that the emgine needs incase of some kind of issue(s).
Thanks.
toonz is offline   Reply With Quote
Old 06-13-2012, 12:59 PM   #2
toonz
Member#: 322044
Oh and the year of my engine is 96-98 EJ20G
Old 06-14-2012, 01:50 PM   #3
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
they both work. i have a 20g with the racing blue gates belt. i think its from a 02-03 wrx. prettyyy sure they are all the same dohc
azn0boi04 is offline   Reply With Quote
Old 06-14-2012, 02:03 PM   #4
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
I am pretty sure the belt is the same across all the dohc. I have been using one for the usdm sti for a couple years now with no problem.
spackyscooby is offline   Reply With Quote
Old 06-14-2012, 03:04 PM   #5
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
the T277 doesnt cross-reference to the 02-03 wrx , at least in Amazon's application finder.
fastnoypi is offline   Reply With Quote
Old 06-14-2012, 08:40 PM   #6
vica153
Member#: 76586
2006 9-2x Aero
277 and 328 are the same. 328 has the Gates Blue belt option (328RB) that is 1mm wider.
vica153 is offline   Reply With Quote
Old 06-14-2012, 09:10 PM   #7
toonz
Member#: 322044
great.... thanks for the help guys.
Old 04-30-2013, 12:48 AM   #8
iRomey
Member#: 254547
Semi-grave bump, but for clarification on the JDM EJ20's, are all the tensioners, idlers, water pump and seals the same across the board as well?
I'm trying to piece together a timing belt kit for my install, but I've been reading a bunch of different information.
iRomey is offline   Reply With Quote
Old 04-30-2013, 01:00 AM   #9
eg33GC
Member#: 206851
56 Belair
Pro Street
you can use any timing belt and any tensioner. you can intermix whatever you'd like.
order the tensioner from a ej22e and the belt from a 02 wrx
eg33GC is offline   Reply With Quote
Old 04-30-2013, 01:01 AM   #10
NewWRXMike
Member#: 341540
I just bought the Gates TCK277 kit for the 1996 2.5L DOHC Legacy. It has the older style tensioner pulley (which mine has, 1993 WRX). All the pulleys are the same and the belt is the exact same size with the marks in all the correct places.
I also used a thermo/water pump from 02 WRX, it fit perfectly.
NewWRXMike is offline   Reply With Quote
Old 05-01-2013, 10:38 PM   #11
CRX7
Member#: 31639
99 Impreza
I used the blue 328RB on my ej20g and I used the old style tensioner as I heard it is more reliable.
CRX7 is offline   Reply With Quote
Old 05-02-2013, 01:44 AM   #12
iRomey
Member#: 254547
Single piece or two piece, it's good to know I can use both
Old 05-02-2013, 10:31 PM   #13
CRX7
Member#: 31639
99 Impreza
Don't forget to do the waterpump, thermostat and crank seal at the same time. Get some clamps to hold the timing gears in place too, that's what took me the longest, the timing gears kept slipping after I set them.
Old 05-12-2013, 06:59 PM   #14
iRomey
Member#: 254547
So, I compiled my timing belt parts list for my early EJ20G.
x1 - Gates Racing Timing Belt- GATE-T328RB
x1 - Older Tensioner, EJ22E/T, EJ18- 13068AA051
x2 - Smooth Idler Pulleys- 13073AA142
x1 - Toothed Idler Pulley- 13085AA010/80
x1 - Water Pump- 21111AA026
x1 - Water Pump Gasket- 21114AA030/51
x1 - Thermostat and Gasket- 21210AA030
x4 - Cam Seal 806732150
x1 - Crank seal - Front- 806733030
x1 - Crank seal - Rear- 806786040
I recall needing 4 pulleys, but I only listed 3. Can anybody tell me if I'm missing anything?
Gates timing belt kit, which for my needs? Whoa!ShutItDown Service & Maintenance 1 11-06-2011 05:04 PM
STI timing belt, or gates timing belt? matt.nbg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-03-2011 09:44 PM
Time for timing belt / which one? explosivo South West Impreza Club Forum -- SWIC 13 12-14-2010 02:48 AM
'94 JDM EJ20G... What timing belt? Subarutex NWIC Private Classifieds 5 10-25-2006 09:04 PM
SOHC 2.5L (EJ25) Gates timing belt for sale Atwood Private 'For Sale' Classifieds 0 09-03-2005 01:08 AM
