Old 06-13-2012, 02:39 PM   #1
Zoltan123
Member#: 315980
2012 WRX
Default 2012 WRX Stage 1 First Data Log!
https://docs.google.com/spreadsheet/...nVrdG04d1lsRGc
Just installed AP and loaded the Stage 1 93 map (stock intake). Trying to learn about what I'm looking for in the data log, I did watch the Cobb tutorial on youtube and found it helpful. Any opinions on the log would be appreciated, thanks!
Zoltan123 is offline   Reply With Quote
Old 06-13-2012, 02:58 PM   #2
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
you have to allow access otherwise we can't see it
freddy121389 is online now   Reply With Quote
Old 06-13-2012, 03:07 PM   #3
Zoltan123
Member#: 315980
2012 WRX
anyone using the link should be able to access the doc, i'll double check.
Old 06-13-2012, 03:12 PM   #4
Zoltan123
Member#: 315980
2012 WRX
saved as public, should work. If not...I don't know.
Old 06-13-2012, 03:55 PM   #5
subiebosch
Member#: 155548
2015 2500 Dmax
2011 WRX TP STG2 COBB DP
your knock looks good but you are underboosting. if you want, try the HWG map and post some logs.
subiebosch is offline   Reply With Quote
Old 06-13-2012, 03:59 PM   #6
Zoltan123
Member#: 315980
2012 WRX
Thanks for the feedback!
Old 06-13-2012, 04:23 PM   #7
Cobb Tuning
Member#: 4803
Try to get another log and start the run a little earlier (if you can do so safely).
Bill
Old 06-13-2012, 04:41 PM   #8
Zoltan123
Member#: 315980
2012 WRX
Bill
Ok, will do.
Old 06-13-2012, 05:44 PM   #9
Zoltan123
Member#: 315980
2012 WRX
Here we go, two more logs
https://docs.google.com/spreadsheet/...GV6SzhYWVhlWEE
https://docs.google.com/spreadsheet/...Udjajd4aWk3ZlE
Hopefully that will provide some more info. Thanks!
Old 06-14-2012, 10:34 AM   #10
Cobb Tuning
Member#: 4803
Logs look good. You are underboosting some - if you want you can download the high wastegate (HWG) version of your map from the maps section at cobbtuning.com (use the AccessPORT Manager software to transfer that map from your computer to the AccessPORT and then reflash it to the car).
If you decide to go with the HWG map, get some more logs. Also, besides a 3rd gear run, check or log your boost in higher gears under heavy throttle (where you would normally go WOT in higher gear such as passing).
Bill
Old 06-14-2012, 04:24 PM   #11
Zoltan123
Member#: 315980
2012 WRX
I'll give the HWG map a shot and log some more. Thanks for the response Bill.
Old 06-21-2012, 04:12 PM   #12
211STi
Member#: 283286
2011 STi
Isn't 15 normal for WRX?
Read the notes, target for 93 stg1 is 16.5
211STi is offline   Reply With Quote
My 07 wrx stage 2ots map data log kingjess25 AccessPort 4 06-02-2012 12:54 PM
2012 WRX Stage 2 Overboosting data log Isoh AccessPort 2 02-24-2012 03:29 AM
2012 WRX Stage 1+SF Data Logs KitKatJim AccessPort 14 02-22-2012 11:45 AM
2011 wrx stage 1 acn91 data log assist - overboosting? mattesonb AccessPort 9 02-10-2012 08:36 PM
2010 WRX Stage 1 knock issue? logs inside. JonnyD91 AccessPort 4 08-07-2011 09:16 PM
