Old 06-13-2012, 08:21 PM   #1
matts65ss
Member#: 283781
2003 WRX
Sedona Red Pearl
Default 2003 WRX Stage 2 ACN 91 LWG DataLog
hey guys, 2 days ago i went stage 2 , and flashed the ACN 91 Stage 2 map. on the freeway in 4th i went wot and realized the boost was really high (19.3) to be exact, so last night i loaded the LWG ACN 91 stage 2 map and today did 2 3rd gear pulls while data logging for you guys to check out because the only thing ive ever tuned was a Holley double pumper
Also wanted to post up because it feels weak, The feel isn't much different from stage 1.
https://docs.google.com/a/calpolysig...Xb2Q2Q3c#gid=0
https://docs.google.com/a/calpolysig...2c&pli=1#gid=0
thanks in advance
matts65ss is offline   Reply With Quote
Old 06-14-2012, 09:47 AM   #2
Cobb Tuning
Member#: 4803
thanks in advance
The second log needs the permissions set to public.
Bill
Old 06-14-2012, 10:20 AM   #3
matts65ss
Member#: 283781
2003 WRX
Sedona Red Pearl
Bill
done,
https://docs.google.com/spreadsheet/...llWVjQ5VnlFc2c
Old 06-14-2012, 10:31 AM   #4
Cobb Tuning
Member#: 4803
Boost with the LWG looks good, but your dynamic advance multiplier has dropped at some earlier point (to 15). That means there was some significant knock (or other noise picked up by knock sensor) at some point. Because the older cars can end up having various mechanical issues that typically impact fueling, I would drive around on this map for about a week or more without reflashing anymore maps or resetting the ECU (or disconnecting the car's battery). Then we can look at your long-term fuel trims (A/F Learning 1 A, B, C, D) and see if they are within reasonable ranges. Should be within +/- 5% with outside of +/- 8% indicating a possible problem. But, they take some driving to populate accurately.
Bill
Old 06-14-2012, 11:46 AM   #5
matts65ss
Member#: 283781
2003 WRX
Sedona Red Pearl
Wow awsome bill thank you very much.. The logs were done right after the reflash, I'll post up in about a week! Thanks again
Old 06-18-2012, 08:13 PM   #6
matts65ss
Member#: 283781
2003 WRX
Sedona Red Pearl
heres another 3rd gear pull..
https://docs.google.com/spreadsheet/...FNiR3BWSXhmdnc
today i got the boost fluctuation again in 4th gear so i logged it
https://docs.google.com/spreadsheet/...TBJNWItWmRMYnc
it has me stumped all the lines on the car are intact
Old 06-19-2012, 11:55 AM   #7
Cobb Tuning
Member#: 4803
One of your A/F Learning values is on the high side (almost 8%). I would get a pressure test of the intake tract done. Even though the wastegate lines might be intact, check for cracking or other damage on all sides.
Bill
FS : NH: 2003 Wrx Stage 2 $9,500 1tunk5 Private Vehicle 'For Sale' Classifieds 3 05-01-2011 09:05 AM
2003 WRX Stage 2 Low Boost bconway52 Engine Management & Tuning 9 03-02-2011 12:22 PM
2003 WRX Stage 2 loss of power blakeaustintusn Service & Maintenance 1 12-01-2009 07:55 PM
2003 wrx stage 2 map adobeamd Open Source Reflashes 6 07-31-2009 02:14 PM
2003 wrx stage 2 Axis motor?! WjRgX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-05-2005 01:41 AM
