Old 06-14-2012, 02:25 AM   #1
Mansour14
Member#: 279796
2004 Wrx
Default 2006 WRX injectors with stage 3 map on 04 wrx?
I was wondering if the 2006 Wrx injectors would work with the stage 3 map on a 2004 WRX, since they are 560cc.
Any insight?
Mansour14 is offline   Reply With Quote
Old 06-14-2012, 06:55 AM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Download accesstuner race and input the correct injector data.
Black94Snake is offline   Reply With Quote
Old 06-14-2012, 09:54 AM   #3
Cobb Tuning
Member#: 4803
Any insight?
Hi there. Even though the flow rating is close, you will still have to tune/tweak for the different injectors with a wideband o2 sensor (in closed loop you can get away with using the front o2 based short and long-term fuel trims, but you'll need the wbo2 for open loop verification). If you are an experienced tuner (or willing to learn), you can do this through the free AccessTUNER Race software (for version 2 AccessPORT users only). Our tuning guide at the following link describes the process:
http://www.cobbforums.com/forums/sho...et-for-Subarus
Or you can take your car to a professional Subaru tuning shop that uses our software. They can create a custom tune for your injectors and likely end up with even more power/driveability that the OTS map since it is a custom map for your specific car and gas quality.
Bill
Old 06-14-2012, 12:24 PM   #4
Mansour14
Member#: 279796
2004 Wrx
Bill
So with the accesstunerRACE, I can edit the levels and tune it myself? How would I do this? I don't want to install the turbo, injectors, and sti tmic and not being able to drive my car, due to it running like crap etc.
Can you explain to me in steps how I should do this?
Old 06-14-2012, 12:37 PM   #5
Cobb Tuning
Member#: 4803
If you have a version 2 AccessPORT, you can request a free copy of AccessTUNER Race here:
http://www.cobbtuning.com/accesstune...st-s/70716.htm
An explanation of the process can be found in our tuning guide which can be downloaded here:
Bill
FS : Exedy Stage 3 Clutch from 04 WRX RareSilverWRX Drivetrain 3 12-29-2010 12:02 PM
Stage two map on 2004 wrx sdnativesurfer AccessPort 0 06-27-2009 02:05 AM
looking for stage 1 map on 04 wrx emerica459 Open Source Reflashes 1 03-06-2009 11:06 PM
Dyno Flash Pro Tune vs Cobb Base Map on 04 WRX Stage 1 93 octane Dyno Flash Proven Power Bragging 13 10-26-2006 02:09 PM
Stage 2 Map on 06 WRX TR 06WRXTR Engine Management & Tuning 12 11-29-2005 05:26 PM
