Old 06-14-2012, 04:09 PM   #1
B506
Member#: 296145
Default Please help with logs
Hey all, I have a 06 wrx mods are invidia catless dp and invidia q300 catback with a Clark tuner map, I did a couple 3rd gear runs and was wondering why I'm experiencing Fine Knock Learning at the same rpm range, is it a problem or am I just being paranoid? Thanks for the help in advance!
https://docs.google.com/spreadsheet/...TFKZWdMc2JrM3c
https://docs.google.com/spreadsheet/...1l1ZTFnaTBhSnc
https://docs.google.com/spreadsheet/...WpWVW00TVh2NXc
B506 is offline   Reply With Quote
Old 06-15-2012, 09:29 AM   #2
Cobb Tuning
Member#: 4803
Fine knock learning is learned from a perceived event(s) and then re-applied over and over within a broader load/RPM range until eventually it learns back to zero. So, this isn't perceived knock you are seeing over and over again in this case. Could just be a single past event. A single count of fine knock learning during a WOT run can be due to lifting off the throttle abruptly during a past WOT run. It would be best to check with your tuner and get their opinion since they are very familiar with the map and how it should respond.
Bill
Need help with logs! subiewrx001 Open Source Reflashes 13 08-06-2009 12:21 PM
Need some help with log after TGV Bad Noodle Open Source Reflashes 2 04-29-2008 07:20 PM
Need help with Logs. Got CEL need to find source nayr924 Open Source Reflashes 0 01-08-2008 06:41 PM
need help with log bbaker80 UTEC 4 12-29-2006 10:02 PM
Help with log max out wastegate and fuelpump jdgrimm Engine Management & Tuning 2 05-15-2006 10:37 AM
