Old 06-14-2012, 11:59 PM   #1
stockscooby
Member#: 218151
2005 STi
World Rally Blue
Default acess port help for data log hot/cold start
I have to data log hot and cold starts and idle but I don't know what the wording is or what they are called on the access port. any help would be great.
thanks
stockscooby is offline   Reply With Quote
Old 06-15-2012, 10:48 AM   #2
Cobb Tuning
Member#: 4803
thanks
That would depend on exactly what you were trying to determine/diagnose. What are your mods, what car/year is this (05 STi?), what map are you using, and what problem are you trying to fix?
Bill
Old 06-16-2012, 05:34 PM   #3
stockscooby
Member#: 218151
2005 STi
World Rally Blue
Its a 2005 STi, Mods; GS EWG 38mm, Injen CAI, ID 1000's fuel rail, fuel pressure reg, walbro 255, TBE, Spearco TMIC, Cobb AP. E85 tune from P&L.
PROBLEM; Sluggish when leaving from a stop, loss of throttle response and bottom end like a flat spot. When approaching a stop I push in the clutch and come to a stop, the RPM's drop to 100-200 rpm's idle is rough then comes back to 8-900 rpm's. Throws a CEL once in a while for system lean bank 1 (P0171) Did a smoke test for a vacuume leak and everything came back fine. Any thoughts?
Old 06-16-2012, 09:10 PM   #4
Cobb Tuning
Member#: 4803
Could be a bad front o2, bad MAF, variability in ethanol content of the "E85" you using, intake tract leaks, or other fueling-related issue. Did it always run this way? Have you contacted your tuner? I would highly suggest getting a wideband o2 sensor with in-car gauge, given your mods.
Bill
Old 06-16-2012, 09:57 PM   #5
stockscooby
Member#: 218151
2005 STi
World Rally Blue
Been working with P&L, waiting to hear back from them on the data logs I just sent. Car ran great at first just started doing this two weeks ago. Saving for a wide band 02.
2009 wrx need help with data logging noypi09 Mid Atlantic Impreza Club -- MAIC 20 11-12-2010 04:16 PM
Fs CA cobb acess port v1 for 2005 sti $285 daneg6 Engine/Power/Exhaust 1 05-29-2009 12:13 AM
fs: acess port v-1 for 02 03 wrx and hks axel back WRX wa-gone Engine/Power/Exhaust 7 11-27-2008 03:26 AM
Need help w/ data log and AFR / Knock question Tronner AccessPort 1 11-09-2007 03:07 PM
Can Acess Port Help? nothingclub General Community 14 04-28-2007 04:45 PM
