Old 06-15-2012, 01:22 AM   #1
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
Default arc vs sti slanty
Hey guys,
I found an arc slanty intercooler and was wondering if anyone knew if there was much benefit over an sti slanty. I tried searching but couldn't find much comparing the two. Would this just be a bling upgrade or would it actually be worth the money to upgrade?
fxt05 is offline   Reply With Quote
Old 06-15-2012, 01:38 AM   #2
bluesubby
Member#: 80247
Originally Posted by fxt05 View Post
Hey guys,
http://autospeed.com/cms/title_TopMo...8/article.html
i like ver2 ra cooler
bluesubby is offline   Reply With Quote
Old 06-15-2012, 03:19 PM   #3
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
I couldn't find anything mentioning the ra cooler being different. I have a complete swap from an sti ra so i assume my cooler is ra but couldn't really tell it apart from the sti.
So assuming its the ra ic there would be no real advantage to changing to an after market tmic?
Old 06-15-2012, 03:29 PM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
there is 0 difference between the wrx, sti, or ra variant intercoolers.
except the piping to them. It was a common misconception that the v1/2 wrx tmics were steel, but I've disproved that.
eg33GC is offline   Reply With Quote
Old 06-15-2012, 04:50 PM   #5
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
So the original question still stands. Is the arc worth buying? Is it an upgtade? I've only seen comparisons of the avo tmic which doesn't look like its worth upgrading to.
Thanks again for helping guys.
Old 06-15-2012, 04:51 PM   #6
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
The flanges are different and incompatible depending on the feedpipe. I have seen two different versions of the stock slanty with one having an indent (less volume). The STi versions never had the indent. I would guess the later standard coolers were moved to the improved design.
rob is offline   Reply With Quote
Old 06-15-2012, 04:56 PM   #7
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
The arc intercooler sold already. Only took a day. Seemed like a good deal at $300 but didn't want to spend the money and swap it if it wasn't going to be a worthy upgrade.
Hopefully I didnt miss something amazing.
Old 06-15-2012, 05:01 PM   #8
eg33GC
Member#: 206851
56 Belair
Pro Street
$300 is a diy fmic or enough money for e85 injectors.
better spent on something other than a slightly better tmic
Old 06-15-2012, 05:02 PM   #9
RallyColtTurbo
Member#: 16819
I'll second the fact that all slanty intercoolers use the same core. The only difference I noticed (outside of the piping) is that the silver STI intercooler entrance tank is not clearanced for a LHD clutch master cylinder reservior, while the black WRX one is.
RallyColtTurbo is offline   Reply With Quote
Old 06-15-2012, 05:10 PM   #10
eg33GC
Member#: 206851
56 Belair
Pro Street
I've never seen that before, the few I've had are all the larger style. I only play with the v1 or 92-94 stuff though.
Old 06-15-2012, 05:36 PM   #11
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Yep, that is what I was referring to. However, there were standard black slantys that were the same shape as the silver ones.
-Rob
Old 06-15-2012, 06:50 PM   #12
bluesubby
Member#: 80247
you can use 02 and up wrx clutch master cylinder reservior
WTB ej20g sti slanty tmic damonmlime Private 'Wanted' Classifieds 33 01-01-2010 09:41 PM
FS: APS EL Header, Ver7 STi TMIC, Prodrive Intake, ARC & STi Injectors Angry Toaster SCIC Private Classifieds 11 06-17-2008 11:49 PM
FS: Ver.2 STi slanty intercooler hail2theTheif 1993 - 2001 Impreza Specific Parts 5 07-16-2007 11:12 PM
BMI EVO IX MR vs EVO IX vs STI v10 A-Line vs STI v10 Spec C STI8U Off-Topic 31 10-12-2006 07:07 AM
ARC vs. APS clamdip Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-30-2005 02:03 AM
