Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 06-15-2012, 08:50 AM   #1
John451
Member#: 321966
2012 Impreza 2.0i H
Black Pearl
Default 2012 Impreza - How best to clean aluminium engine corrosion ?
Have had my new 2012 Impreza for just 2 weeks and after checking my oil level found white corrosion spotting all over the aluminium block and its auxiliaries. I believe it's most likely due to my vehicle being the Air conditioned Show room car for the last 2 months so most likely superficial and it should have been cleaned up during detailing before sale.
Can anyone her tell me if this kind of corrosion is normal and what would be the best way to clean it ?
John451 is offline   Reply With Quote
Old 06-15-2012, 10:49 AM   #2
XERO287
Member#: 253541
2011 WRX 5DR Premium
Break out the coke.
XERO287 is offline   Reply With Quote
Old 06-15-2012, 01:21 PM   #3
hella_sti
Member#: 139289
2003 WRX Wagon
that won't hurt your engine at all
hella_sti is offline   Reply With Quote
Old 06-15-2012, 02:16 PM   #4
Not-EWRX
Member#: 158043
2013 Wrx Hatch
The reason aluminum doesn't rust is because it develops a oxidized layer at it's surface.
Not-EWRX is offline   Reply With Quote
Old 06-23-2012, 11:35 PM   #5
BigVoxjammer
Member#: 319171
2012 Impreza Spt Ltd
Sky-Blue/Gray
Originally Posted by XERO287 View Post
Break out the coke.
Oh, behave!
BigVoxjammer is offline   Reply With Quote
Old 06-24-2012, 12:25 AM   #6
John451
Member#: 321966
2012 Impreza 2.0i H
Black Pearl
Has anyone else noticed this engine corrosion on their 2012 Impreza ?
Old 06-24-2012, 11:29 PM   #7
Splinter888
Member#: 215962
2006 Wrx
SGM
How many miles you got?
Splinter888 is offline   Reply With Quote
Old 06-25-2012, 04:13 PM   #8
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
Satin White Pearl
I did notice that the surface of the aluminum has a cracked/peeling look to it and feels a little rough on mine. Doesn't look that bad yet at 3k miles.
Haunty is offline   Reply With Quote
Old 06-27-2012, 08:46 PM   #9
John451
Member#: 321966
2012 Impreza 2.0i H
Black Pearl
Was how I picked it up new with approx 15 miles on it, the car had been sitting the last 2-3 months in the Dealers Airconditioned Showroom so suspected that is the cause.
Had requested the Dealers Service Dept clean it yesterday as it should have been as part of pre-delivery detailing, they just used their engine degreaser and it looks mostly better, the corroded areas are now mostly shiny grey patches which look similar to other imported aluminium engines I've owned in the past and now I know why.
Old 06-30-2012, 01:11 AM   #10
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
Simple green, and a soft brush. I "wash" my engine bay twice a week usually. Spraying a bunch of water on it wont hurt it, I'm almost 13k miles into my '12 sti and it's fine. But to get rid of those little oxidation spots, use simple green and a soft brush.
dstroy is online now   Reply With Quote
Old 06-30-2012, 03:15 AM   #11
John451
Member#: 321966
2012 Impreza 2.0i H
Black Pearl
Thanks for the tip dstroy.
Old 06-30-2012, 12:48 PM   #12
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....take a look at the following thread and pay particular attention to Ron Ketcham's responses. He is a retired chemist/expert in the industry and knows his stuff.
http://www.autopia.org/forum/car-det...s-how-2-a.html
Having said that, I would also try the APC + brush approach first (or maybe an aluminum safe metal polish + brush) to see how that works for you first. .....personally, Simple Green wouldn't be my first choice of APC's since it has the potential to actually accelerate the oxidation of aluminum. Their Pro HD and Aircraft products will not however. If you do use SG, I would recommend following the dilution recommendations/instructions.
NOTE: some of the acids mentioned in the link I provided (like HF) are particularly nasty in regard to your health. Always wear appropriate safety gear when working with products that contain components of this sort (ie. safety glasses, chemical resistant gloves, respirator, etc.). Always follow directions and researching the risks would also be a good idea.
-- sent from mobile phone--
Kean is offline   Reply With Quote
Old 07-01-2012, 01:38 PM   #13
John451
Member#: 321966
2012 Impreza 2.0i H
Black Pearl
Thanks for the timely warning, did a google search and found the below warning from their FAQ page:
Aluminum - Is it safe to use Simple Green® on aluminum?
...However, caution and common sense must be used: aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green All-Purpose Cleaner can accelerate the corrosion process. Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green® product residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
Old 01-22-2015, 10:06 PM   #14
dragonbear7
Member#: 365417
My 2013 Impreza is showing corrosion too. Is this common with Aluminum engines?
I work in the marine field and any dissimilar metals cause corrosion. Aluminum + steel = aluminum corrodes. So what do you do? Put zinc with Al + steel + Zn = zinc corrodes
If I put zinc somewhere electrically touching the rest of the parts I wonder would it protect the engine.
I fear if it looks like that on the outside, does the inside corrode as well...?
dragonbear7 is offline   Reply With Quote
How to clean your engine bay engine parts???? turbobird14 Car Care & Detailing 39 12-25-2008 01:43 PM
What's the best way to clean the engine compartment under the hood? rabbit92x Car Care & Detailing 4 11-27-2008 09:06 PM
Best way to clean the engine bay cs11elonce Newbies & FAQs 3 11-01-2005 11:10 AM
Best way to clean an engine? wcbjr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-31-2003 10:41 PM
what is the best way to clean your engine?? waitandbleed92 Interior & Exterior Modification 1 07-20-2003 09:13 PM
