South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 06-15-2012, 02:22 PM   #1
04reddragon
Member#: 216553
2006 wrx sti
gray
Default my 04 ac making crazy sounds need a shop or person to look at it plz
So yea the other day my AC was blowing warm air at times so I thought I was low on freon I charged it AC full blast and started blowing cold air but Its making a loud as noise its never made. Now when I turn the AC on it blows cold air but it makes a loud squeaky noise that's annoying. So I'm wanting to know who can check it out for me or know a good shop I can take so they can tell me wat is thanks guys
04reddragon is offline   Reply With Quote
Old 06-15-2012, 03:44 PM   #2
NAZSTI
Member#: 164516
2004 STI
PM JapCarRealGood.
NAZSTI is offline   Reply With Quote
Old 06-15-2012, 06:53 PM   #3
s-tizzleboost
Member#: 281439
2005 impreza wrx STi
if its screaming when you turn a/c on its most likely the belt slipping. mine did the same thing, replaced the belt now its quiet!
s-tizzleboost is offline   Reply With Quote
Old 06-15-2012, 07:03 PM   #4
04reddragon
Member#: 216553
2006 wrx sti
gray
Mmm I hope so. Cause I know before I charged it every fee seconds it would blow ice cold air then warm then wat I think is the compressor clutch would kick in and start blowing cold air so I thought it was low on freon
Old 06-15-2012, 08:21 PM   #5
s-tizzleboost
Member#: 281439
yeah, if im not mistaken the compressor does not stay on constantly, so yeah it was prolly low, and check your belt! look at the teeth on it! if they are missing or are cracked and really dry, then replace it and that should fix the problem!
Old 06-15-2012, 08:28 PM   #6
04reddragon
Member#: 216553
2006 wrx sti
gray
Yea I know when I charged it it took the whole can and blew ice cold air but then started making this loud noise then blew warm air. Then the next day I tried it and blows cool air now
Old 06-15-2012, 09:44 PM   #7
04reddragon
Member#: 216553
2006 wrx sti
gray
I just checked the belt and seems tight and no cracks. I did a test run and drove it and at first it blew cold air then warm the sound kinda goes away but seems like it wants to turn on and its a no go. Wat gives
Old 06-16-2012, 04:15 AM   #8
s-tizzleboost
Member#: 281439
hmmm, you may need to ( not 100% on it) clean your condenser out!
Old 06-16-2012, 12:11 PM   #9
04reddragon
Member#: 216553
2006 wrx sti
gray
Really? Seems easy how do I clean it out?
Old 06-16-2012, 01:51 PM   #10
s-tizzleboost
Member#: 281439
that my man i have no clue! ive just herd of a dirty clogged condenser messing up the a/c and making it blow cold then making it stop.. i believe you have to vacuum it out, but idk exactly how! im sure there is a thread out there on here or iwsti.com!
Old 06-16-2012, 06:31 PM   #11
thegreg
Member#: 105429
2004 WRX STi
You can bring it to my shop, Arizona Auto Care. 5235 s Kyrene #42 Tempe, 85283. 480.820.2693
Sounds like the system is either low, or overcharged. The pressure switches will cycle the compressor off, if once it builds pressure, see its too high or low. As far as the noise goes, it may just be the compressor cycling, hard to say with out hearing it first hand.
As far as the condenser goes, you can visually check the fins on the side that faces the bumper/grill area. You can blow it out with an air gun, or attempt to clean with water. Its unlikely that it is that restricted, but its possible, as the lack of air flow across the condenser will cause pressures to rise, and the compressor will cycle off.
thegreg is offline   Reply With Quote
Old 06-17-2012, 05:35 AM   #12
Infantry209
Member#: 266895
2008 STi
Sounds like your belt could be loose, or you just have a leak. You said you recharged your ac recently. You did it yourself? Did you fasten all the bolts tightly? Did you change any gaskets or clips?
Infantry209 is offline   Reply With Quote
Old 06-17-2012, 05:46 AM   #13
metallbizkit
Member#: 211119
2012 STI Limited
Lightning Red
Originally Posted by NAZSTI View Post
PM JapCarRealGood.
Let us know how it goes wherever you take it, but I've heard some good names mentioned on the forums that can be trusted.
metallbizkit is offline   Reply With Quote
Old 06-17-2012, 01:19 PM   #14
s-tizzleboost
Member#: 281439
what thegreg said (:!
Old 06-17-2012, 01:47 PM   #15
04reddragon
Member#: 216553
2006 wrx sti
gray
Yea i bought the belt ac belt and just to replace also got the power steering belt also my brother in law took my car to his.mechanic and said its the compressor so idk how sure he is.he missed with the trianglr part of the compressor and said it was it
Old 06-17-2012, 02:52 PM   #16
s-tizzleboost
Member#: 281439
damn, i hope you get it all figured out! good luck!
Old 06-17-2012, 03:27 PM   #17
04reddragon
Member#: 216553
2006 wrx sti
gray
Thanks bro hella hot outside need ac
Old 06-17-2012, 06:20 PM   #18
s-tizzleboost
Member#: 281439
I know what you mean! I don't have a/c either haha! I gotta stop being lazy and take it back to fletchers cause they screwed me over!
Old 06-18-2012, 12:21 PM   #19
bluecloud
Member#: 258852
2002 "BugEye"Impreza
blue
I also went to the shop cause my ac is not working . At first, I knew I had no charge. They charged it up, it ran cold for a min, then it stopped. The shop said it was the expansion valve cause and the cause was a blockage. We used ac cleaner thinking it would knock the clog loose, it worked fine for another two minutes then blew hot. I went by superstore they said 129 dollars for the part (crazy). . .so I called BAP and got the expansion valve for 12 dollars on order. I'm putting it in when the part comes in. The only sucky part is that the expansion valve is inside the car behind the dash, the repair program the shop is using said it would take 4 hours to get to. So I decided to bring it home and got to it less then 30 mins. I'll let you know of it works. It sounds like we have the same problem, mine was making a wired noise also because it the compressor was going into vacuum of that helps any.
bluecloud is offline   Reply With Quote
Old 06-19-2012, 12:57 AM   #20
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
expansion valves are quite common on subarus, but it still needs to be hooked up to guages to find out exactly waht's going on.
bobturismo is offline   Reply With Quote
Old 06-19-2012, 12:57 AM   #21
bobturismo
Member#: 42145
6-4 jockin da bish-
Old 06-20-2012, 12:02 AM   #22
04reddragon
Member#: 216553
2006 wrx sti
gray
Yea just want to know wat it really is don't want to buy things that j don't need was working great before I charged it smh
Old 06-20-2012, 02:40 AM   #23
bluecloud
Member#: 258852
blue
From what I've heard, when people try charging the air conditioning, water ends up in the system or its is over charged with freon that can make it not work . Good luck on finding what is wrong with it !
Found a strange fossil/rock. Need a fossil nerd to look at it. Strider Off-Topic 69 03-13-2010 07:57 PM
Shop or mech to look over a used car in westchester ptrout Tri-State Area Forum 0 02-13-2010 11:06 AM
What's a fair price for this WRX? Going to look at it tomorrow. fiveightandten Newbies & FAQs 3 08-22-2009 06:47 PM
I need a shop or person recommendation around Seattle, please. (transmission swap) ChrisRT North West Impreza Club Forum -- NWIC 5 10-20-2006 11:51 PM
Stamford, CT area mechanics. or someone to look at my suspension? kbcr3 Tri-State Area Forum 2 02-25-2005 06:03 PM
