Go Back   NASIOC > NASIOC Subaru Models > BRZ Forum
Old 06-15-2012, 05:48 PM   #1
Mach V Dan
Member#: 12029
Default Mach V's new BRZ on 17x9, 255/40R17
21 miles on it, and we're modifying it already...
The wheels are our own Mach V Awesome, 17x9 +42, satin black on the left side, gunmetal on the right. Tires are 255/40R17. I would probably go with a 245, but we already had the 255's on hand and mounted up, so we just bolted those on. At least at full ride height, I have not been able to get it to rub. If we lower it, it would probably rub.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 06-15-2012, 06:15 PM   #2
Keif
Member#: 107302
Those would fit perfect with a couple degrees of camber up front. The factory alignment settings sure are interesting.
Keif is offline   Reply With Quote
Old 06-16-2012, 03:04 AM   #3
WRblueX_Guy
Member#: 53247
Nice! What are the factory camber settings? How is the clearance on the inside?
WRblueX_Guy is offline   Reply With Quote
Old 06-16-2012, 06:32 AM   #4
Hokie-wrx wagon
Member#: 87194
Looks great, Dan! I want to stop by the shop and check it out at some point. And of course pick up some goodies for my car while I'm there.
Hokie-wrx wagon is offline   Reply With Quote
Old 06-16-2012, 08:28 AM   #5
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Originally Posted by Mach V Dan View Post
Look at that puny horn! You know what must be done.
http://www.fastwrx.com/hesu.html
Old 06-16-2012, 01:53 PM   #6
Keif
Member#: 107302
Scooby South's numbers-
Old 06-16-2012, 02:00 PM   #7
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Subaru has great alignment equipment! It seems pretty crazy that some of those numbers are so far apart from each side.
WRX_02_227 is offline   Reply With Quote
Old 06-16-2012, 11:34 PM   #8
Mach V Dan
Member#: 12029
Tons of clearance in back. Millimeters in front -- the inside of the tire is very close to the spring perch.
Just from my photos I think our car has more than a half degree of rear camber.
Yes.
--Dan
Mach V
FastWRX.com
Old 06-18-2012, 11:53 AM   #9
wrxadam05
Member#: 84070
2015 Fiesta ST - E30
500whp GRB STI
Does anyone have a printout/screenshot of the stock alignment with a driver inside the car?
wrxadam05 is offline   Reply With Quote
Old 06-18-2012, 01:19 PM   #10
SpamMansXe
Member#: 15920
1999 White Mock 22B
2014 Plasma Blue GR STi
So much win!
SpamMansXe is offline   Reply With Quote
Old 06-20-2012, 04:04 PM   #11
Mach V Dan
Member#: 12029
Black Delrin Kartboy shift knob, STi logo.
--Dan
Mach V
FastWRX.com
Old 06-20-2012, 04:05 PM   #12
Mach V Dan
Member#: 12029
Old 06-20-2012, 05:50 PM   #13
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Beautiful! Please do tell where that STI logo sticker can be had!?
Old 06-20-2012, 07:51 PM   #14
Mach V Dan
Member#: 12029
Maybe try clicking that hyperlink above.
--Dan
Mach V
FastWRX.com
Old 06-20-2012, 08:03 PM   #15
chanomatik
Member#: 159474
SNOSLO
Haha I didn't click it originally because I assumed it was going to link to Kartboy's site, which I had just happened to be on right before you posted pics and KNEW there wasn't an STI sticker on there. I still fail, though, because I assumed...
Thank you!
Old 06-20-2012, 10:57 PM   #16
Lminette
Member#: 138923
2000 2.5RS Coupe
Satin Green Metallic
Sticks out too far in my opinion. This car doesn't need that much tire. 225's or 235's with stickier compound would be more than enough given the BRZ's weight. Shoot when I get one I might just stick with the stock size and get some Direzzas or RE11's.
Lminette is offline   Reply With Quote
Old 06-21-2012, 09:55 AM   #17
Izero
Member#: 121332
2004 STi
Platinum Silver Metallic
a widebody kit would look so sick on this car.... keep up the good work MachV!
Izero is offline   Reply With Quote
Old 06-21-2012, 10:41 AM   #18
Calamity Jesus
Member#: 44501
1984 That's *Sir*
225/45-17 (& 225/50-16) Star Specs (Direzzas) are $3/tire cheaper than the oem size (215/45-17).
Bumping up to 245/40-17 would be $34/tire more than oem.
I'd probably go with the 225s, run 1-2lbs less pressure at each corner, put $12 into the autox fund (that's half an entry fee!) unless I felt the 1.4% speedo error and 0.2" taller sidewall would be noticeably detrimental.
Old 06-21-2012, 12:30 PM   #19
jmelgar23
Member#: 287707
2013 BRZ Limited
Satin White Pearl
Hey Dan, I'm thinking about getting one of the shiftknobs for my BRZ from your website but don't know which to choose, decisions decisions lol. What's the difference between the delrin and the titanium?
jmelgar23 is offline   Reply With Quote
Old 06-21-2012, 12:40 PM   #20
delongedoug
Member#: 124113
and beyond!
Oh no, $34!? That's half a tank of gas!
delongedoug is offline   Reply With Quote
Old 06-21-2012, 01:29 PM   #21
Mach V Dan
Member#: 12029
Delrin is a plastic material -- think of one of those soft white cutting boards. It's light, and cool to the touch (or in winter, warm). We don't have titanium. We DO have aluminum, which is heavier, harder, and warmer in summer/colder in winter, until your hand equalizes the temp. Either one is very nice. They're affordable enough you could get a couple and switch 'em around...
--Dan
Mach V
FastWRX.com
Old 06-21-2012, 08:00 PM   #22
Tim Quinn
Member#: 16961
2011 Kawi Ninja 400R
Kawasaki Green
--Dan
Mach V
FastWRX.com
I never really thought about non-metal shift knobs before. Although I once froze my hand to my aluminum one while in Edmonton (it was -52 degrees out and my hand was damp from wiping the snow off my windshield). That was unpleasant...
-Tim
Tim Quinn is offline   Reply With Quote
Old 06-21-2012, 10:12 PM   #23
Mach V Dan
Member#: 12029
Originally Posted by Tim Quinn View Post
Although I once froze my hand to my aluminum one while in Edmonton...
Old 06-22-2012, 12:38 AM   #24
jmelgar23
Member#: 287707
2013 BRZ Limited
Satin White Pearl
--Dan
Mach V
FastWRX.com
thanks for the info! i'll check out which i want to get, leaning more towards the delrin one just don't know what color lol. i ordered my brz in swp also and that black looks great! & my mistake, i meant to say aluminum, i was probably drooling at that shiftknob pic lol
Old 06-23-2012, 05:47 PM   #25
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
niice..I am running 17x9 42 also... with 245s...have to wait to see what size tire I can 'officially' run...
this is my alignment now...getting ready to change it again... with coilovers and plates..
FS : Rota Grid 17x9 et42 5x100 w/ Nitto NT01 255/40R17 vision.dynamix Motorsports Specific Items 20 05-28-2012 05:48 PM
The new BRZ on Motor Trend! Cover shot! DSRX2005 General Community 21 11-25-2011 07:32 AM
FS (TN): 17x9 5Zigen FN01R-C bronze w/255/40r17 Nitto NT-05 resonant evil Wheels/Tires 15 06-27-2009 09:31 AM
Volk CE28N : Bronze : 17x9 && Advan A048 255/40R17 prototypeWRX Member's Car Gallery 87 06-20-2007 04:11 PM
Poll 245/45R17 or 255/40R17 Victoracers on Stock BBS for STi? crystalhelix Motorsports 9 05-13-2005 09:23 PM
