#1 |
Member#: 115043
SWIC
Vehicle:2005 WRX Obsidian Black Pearl |
Worked fine yesterday, went out this morning and it would not start.
Fuel Pump turns on Fuel gets to Filter, out of Filter, to Fuel Rails Car has spark on all four cylinders Any ideas???
#2 |
Member#: 132792
SWIC
Vehicle:2007 Impreza WRX WG WRB |
ign fuse?
bad crank sensor could cause a no-start too |
#3 |
Member#: 115043
SWIC
i've checked the fuses under the hood, is the ignition inside?
i though a crank sensor would throw a trouble code... |
#4 |
Member#: 146496
SWIC
Vehicle:02 WRX Wagon 2.1L Built not bought. #0003 |
Is it AT or MT? If its a MT maybe check the clutch pedal switch. Could be bad.
That is if the car is not cranking at all. Which I'm not sure with your OP, so I'm assuming that it's not cranking over. |
#5 |
Member#: 115043
SWIC
AT, it cranks just won't fire...
#6 |
Member#: 294466
SWIC
Vehicle:1993 Legacy SS white |
You should use the search engine on bbs.legacycentral.org . Its the best forums for first gen legacys.
| Thread Tools | |
| Display Modes | |
| Car Won't Start / Started Won't Click / Battery Charged - - STUMPED! | JohnnyWas | Factory 2.0L Turbo Powertrain | 7 | 05-21-2012 12:52 PM |
| Fuel pump won't start, blown fuse SBF 2, car won't start | ClassicGC | Factory 2.0L Turbo Powertrain | 5 | 06-29-2008 09:18 PM |
| Car won't start - cranks but won't start | dave_88 | Factory 2.0L Turbo Powertrain | 4 | 12-12-2007 10:29 PM |
| '91 Legacy T Won't Start | carmat76 | Legacy Forum | 7 | 01-29-2004 05:30 PM |
| automatic 95 legacy won't start! | tdidriver | Service & Maintenance | 9 | 09-09-2003 09:19 PM |
