Old 01-22-2013, 09:57 PM   #1
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
Default group n mounts
Just installed all mounts and all the sloppiness went away instantly but now the baja vibrates at certain rpms. I have driven the car around the block and I am really glad I am not hearing the engine rock at any stoplights. I will try to post the old engine mounts with one bad mount, very flimsy granny mount and the dogbone mount very soft.
Baja_Gernaut is offline   Reply With Quote
Old 01-22-2013, 11:39 PM   #2
jrigby
Member#: 256134
2005 Baja Turbo 6MT
How many miles are on your mounts? I've been thinking about replacing mine, just haven't been motivated with the cold.
jrigby is offline   Reply With Quote
Old 01-23-2013, 09:13 AM   #3
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
My Baja has around 130 on the clock. The reason i wanted to change the mounts because i just replaced my rear drive shaft with a aftermarket one and i noticed my center bearing making a vibration while taking off. This is my third shaft so i had a theory about my mounts being weak and allowing the u joints near the tranny flex or buckle when there is a strain such as a launch in first gear. My first two drive shafts broke the u joints by the tranny, so if the engine is rocking back and forth, then that drive shaft u joint has to flex according to the engine movement.
i can say now that i do not feel any vibration in the center-bearing anymore or any movement on my stick shift. i do feel vibration coming from engine because of the stiffer mounts but i do not feel any strain on the drivetrain anymore.
I
Probably if I did this job again, I suggest changing all mounts with hardened ones except the engine. I think the OEM mounts do a better job with vibrations from the engine but the tranny mount is actually a joke. This is one mount that was incorrectly engineered because there so little support for so much movement from the car.
Last edited by Baja_Gernaut; 01-24-2013 at 05:15 PM. Reason: Typing sucks in a iphone
Old 01-24-2013, 07:49 PM   #4
Ahzlon
Member#: 45216
2005 Baja Turbo
I had a set of bushings I can't remember where they came from in my 00 RS.. HOLY CRAP. first time i started up the car.. EVERYTHING vibrated every where.. I thought my dash was going to shake off. But they broke in after a while and were not as bad.. I do remember them being 25% stiffer then group N bushings. I still have them. Might install them this summer.
Ahzlon is offline   Reply With Quote
Old 01-24-2013, 08:01 PM   #5
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
i had the same experience when I started the car up. i am hoping they break in and the some of the vibrations goes away. I have the kartboy bushings and short shifter to install and this will definitely wipe away the wobble i have with the stick.
Old 02-04-2013, 06:17 PM   #6
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
update on the mounts, vibration has gone away around 40 percent. Even the whining of the tranny has subsided so I happy with this upgrade. Now I am about install the kartboy shortshift with bushings.
Old 02-04-2013, 10:38 PM   #7
steven765
Member#: 105920
2006 Baja 5 Speed
FML I just bought a new factory mount. Which group n mount fits the baja?
steven765 is offline   Reply With Quote
Old 02-05-2013, 01:35 PM   #8
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
i bought the 5 speed kit. apparently our bajas share the same mounts any other subaru that has a 2.5 engine. this what i went by and alll mounts fitted fine. thit kit comes with engine, tranny and pitch mount.
