Old 06-16-2012, 03:13 AM   #1
acanadianreject
Member#: 235679
99 Legacy 2.5GT
Tuxedo Black
Have a Nice Day? knuckles, suspension and ride height 99 Legacy sedan
ok so i have a 99 legacy sedan (you all know it, its the one Bad Wagon AKA Girodisc built) currently running GC8 KYB AGX struts all around, with eibach lowering springs and front and rear camber plates. when they were put on the car the front end sat almost a full 2 inches higher than the rear. Johann cut the springs and dropped it another inch but without taking significantly more we couldnt get it to sit correctly
so... my question is why? johann thinks it may have to do with the fact that i am running 98 outback knuckles all around and that the fronts may be a higher profile than the mounting points on a gc8. but wouldnt the rears be the same case? why would they be 2" higher in the front (before cutting the springs? any ideas? if i have to replace the front knuckles with ones from an impreza im down to do it but i have to be certain. thanks guys!
acanadianreject is offline   Reply With Quote
Old 06-16-2012, 03:15 AM   #2
acanadianreject
Member#: 235679
99 Legacy 2.5GT
Tuxedo Black
here is a pic, you can see just how much more wheel gap there is in the front...
Old 06-16-2012, 03:26 AM   #3
jamal
Member#: 71875
98 Legacy GT
my wheels fit
No, the upright/knuckle, from a geometry standpoint, is the same on everything. The outback is taller because of the struts, springs, tires, and spacers between the crossmembers and body. ABS sensors and bearings changed a little over the years and the newer sti uprights are wider where the strut attaches but that is all.
What are the springs supposed to go on?
Mixing springs and struts between models and generations usually results in a funky ride height because the spring perches that are welded onto the struts are in different places depending on what they are for.
jamal is offline   Reply With Quote
Old 06-16-2012, 03:57 AM   #4
acanadianreject
Member#: 235679
99 Legacy 2.5GT
Tuxedo Black
thats what i thought,
the springs are for a GC8 also, the suspension sat just fine on his gf's GC
here is a pic of that
even seems to be sitting a little higher in the back if anything on the coupe
it is very weird that it would do this.
same thing happened to my other friend's GC when we put legacy suspension on it for winter. jacked the front up but the back stayed at correct height.
very wierd.
Old 06-16-2012, 04:11 AM   #5
acanadianreject
Member#: 235679
99 Legacy 2.5GT
Tuxedo Black
so i guess the 2 other things i can see effecting wheel position would be sway bars and mounting position. the rears could mount higher up in relation to the bottom of the car in legacy's in the rear and therefore the strut is up in the body more. ive never actually measured these things but it makes sense as the legacy is a larger car
and as far as sway bars go if mine werent wide enough couldnt it technically effect the location of the wheels? i mean its just an idea, again i have only ever dealt with stock suspension set ups in the past, nothing this advanced.
Old 06-17-2012, 01:39 AM   #6
jamal
Member#: 71875
98 Legacy GT
my wheels fit
so GC springs and GC struts worked great on a GC, but don't work on a different chassis? Doesn't seem wierd to me.
And swaybars have nothing to do with this.
Old 06-17-2012, 01:58 AM   #7
acanadianreject
Member#: 235679
99 Legacy 2.5GT
Tuxedo Black
well obviously they are different but there is no way the gc has strut mounts in the front that mount 2" higher in the engine bay than a legacy...
Old 06-18-2012, 05:21 PM   #8
jamal
Member#: 71875
98 Legacy GT
my wheels fit
The front uprights are the same part number between the Outback and Legacy.
What is different between the GC and BD is the rear strut/spring/mount. So I would say it's not that the front suspension is 2" higher, it's that the rear is lower.
Old 06-19-2012, 12:16 AM   #9
acanadianreject
Member#: 235679
99 Legacy 2.5GT
Tuxedo Black
hmmmm
Wtb. Suspension And Bars For 97 Legacy Sedan vdubster79 Private 'Wanted' Classifieds 2 06-06-2008 11:55 PM
Stiffer suspension, stock ride height? MatthewMarchand Brakes, Steering & Suspension 6 01-17-2006 06:25 PM
Ground Controls with AGX's and Ride Height 1331 Brakes, Steering & Suspension 7 05-31-2004 12:51 PM
camber/castor plates and ride height abaxter34 Brakes, Steering & Suspension 20 04-08-2004 06:53 PM
coilover and ride height Q heythereok Newbies & FAQs 0 06-09-2002 07:15 AM
