Old 06-16-2012, 05:51 AM   #1
Merko
Member#: 317488
1995 GC8C WRX import
Hi guys, I have a JDM 95 WRX with what I guess is an STi motor (has 5th injector). Now my TD05 seems to be nearing the end of its life, and there's a much respected WRX guru around here with about 10 years' experience in early rexes who has offered to put in a VF34 for me.
Now, he says that it is safe to put in the VF34 without getting a tune, and the only supporting mod I need is the 255lph Walbro fuel pump (which I installed today). What are your thoughts on this? I am inclined to believe him because of his experience but then there's this attitude in the WRX community of if you do any mods without a tune your engine will die.
Also I am not really planning to up the boost, I have a Z4 ECU running at the stock 12.78psi. I may contemplate raising it to about 15psi if safe. As I am planning to run stock boost though, my main concern is the engine leaning out early in the power band as the VF34 spools faster. Also I should note my knock sensor is pretty much redundant as we had to move it to another location as it kept picking up false knocks from general engine noise and putting the car into limp mode.
So what are your thoughts on swapping the TD05 with a VF34 and no tune on a V2 rex?
Thanks
Merko is offline   Reply With Quote
Old 06-16-2012, 10:05 AM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
You didn't need the fuel pump. It can't hurt though.
Normally I'd say the turbo swap would be ok if you added a MBC. But with a non functional knock sensor I wouldn't.
Old 06-16-2012, 09:17 PM   #3
Merko
Member#: 317488
So knock sensor aside, you would say it's not a problem to run the VF34 without tuning?
Also I do have an MBC that I used for a bit which is currently unhooked, but am planning to use the stock boost control solenoid until I decide to run more boost.
Old 06-17-2012, 01:39 AM   #4
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Lol not a problem at all. Your car will really get up and boogie with it.
i_c_the_light is offline   Reply With Quote
Old 06-17-2012, 11:28 AM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
You need to use a MBC. The ecu can't control a different turbo properly, duty cycle will be wrong and the boost will be erratic.
Old 06-17-2012, 12:15 PM   #6
eg33GC
Member#: 206851
56 Belair
Pro Street
Im not too familiar with the compressor map of the vf34, but my understanding is it is a bit smaller than the oem 16g.
as stated, you MUST not use the factory electronic boost controller, unless you modify the rom. It is actually extremely straight forward if you have the equipment.
eg33GC is offline   Reply With Quote
Old 06-21-2012, 09:15 PM   #7
Merko
Member#: 317488
Cool thanks for the input folks. But I'm curious, why doesn't it need to be tuned? Do the early rex ECUs tolerate mods more than the later 3-plug ECU GCs? Because apparently everything needs a tune for the later GCs.
Old 06-22-2012, 12:18 AM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
The early ECU's are less picky and have much more capacity to adapt. You can also make the new turbo work with the stock boost controller but it would take a lot of fiddling and experimenting with bleed hoses and/or restrictors in the hoses.
Marnix is offline   Reply With Quote
Old 06-22-2012, 04:21 AM   #9
Merko
Member#: 317488
Cool thanks. So if I wanted to up the boost to 15psi, is it as simple as winding up the MBC a bit? I've always heard this was a no no with other cars. Only supporting mod I have is the walbro pump. Stock injectors and intercooler.
Old 06-22-2012, 10:18 PM   #10
CFej257
Member#: 247687
2002 Subaru Wrx
Hmmm, I've been running a vf30 with z4 ecu for 20,000 miles now with no MBC. My boost seems to be fine.
CFej257 is offline   Reply With Quote
Old 06-23-2012, 07:05 AM   #11
Merko
Member#: 317488
Yeah I had it running on the stock BCS and it was fine? boosted a couple of psi lower though than with the TD05. Anyway, I've put my MBC back on and set it to about 14-15psi and it runs awesome! Loving the quicker spool of the VF34
Let's just hope things don't go pop
okay to drive to dealership with downpipe and no tune? kodirat7 Newbies & FAQs 33 12-29-2010 12:40 PM
2004 WRX driving to tuner Wed with catless turboback.. no tune sLicK 2004 General Community 4 11-09-2009 05:57 PM
Really Nice Running '04 WRX with Vf34 and Pro Tune Dyno Flash Proven Power Bragging 16 05-17-2007 01:45 PM
FS Chicago: 04 WRX front seats, PSM WRX trunk lid, HID kit, VF34 & pinks DickWRX Private 'For Sale' Classifieds 2 07-21-2006 05:00 PM
drivable with injectors + turbo + no tune? Costanza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-07-2003 12:14 PM
