Old 06-19-2012, 07:18 PM   #1
rsg9115
Member#: 218569
91 leggy sdn turbo
black
Default 91 legacy sway bar endlinks?!
The bushings let go and it's making all kinds of noise is there an aftermarket end link I can buy or replace the bushings ?!
rsg9115 is offline   Reply With Quote
Old 06-19-2012, 07:25 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
Sure they aren't anything special same as GC body and wrx wagon.
Old 06-20-2012, 07:37 AM   #3
rsg9115
Member#: 218569
91 leggy sdn turbo
black
Well I have a 96 wagon and those look like a C shape these are just straight in the rear
Old 06-20-2012, 12:13 PM   #4
guesswhoou812
Member#: 191280
1991 LSi w/EJ22T!
Prodrive Brakes!
Prefacelift legacys have a different lateral link and endlinks setup then 92+ legacies and imprezas. Check ebay, if not then whiteline may make a replacement endlink.
-Jay
guesswhoou812 is offline   Reply With Quote
Old 06-20-2012, 03:28 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
There's a few different straight ones out there.
get me a pic, and a center to center measurement.
Old 06-20-2012, 04:25 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
Hmm. Might be the same as the STI then?
Old 06-20-2012, 04:47 PM   #7
rsg9115
Member#: 218569
91 leggy sdn turbo
black
What if I just put my suspention from my wagon into the legacy or will it not fit ? I have poly bushings in those parts
Old 06-20-2012, 04:55 PM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
Seems like a plan. You might have to put the rear subframe in too? I can't recall what the frame looks like on the very early legacy, I've only see one or two of them ever.
Old 06-20-2012, 08:26 PM   #9
rsg9115
Member#: 218569
91 leggy sdn turbo
black
Ya no big deal I looked at it yesterday I think it's the same thnx
Old 06-21-2012, 07:43 AM   #10
guesswhoou812
Member#: 191280
1991 LSi w/EJ22T!
Prodrive Brakes!
The suspension from your impreza wagon will bolt right up into the legacy no problems as long as you swap everything.
Old 06-21-2012, 02:57 PM   #11
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
No need to swap the subframe, just the arms is fine. They are the same length as the Legacy's (1989-1998 use the same length on Legacy, Impreza etc) so you just need to swap the arms which hold the stabilzer endlink. But if it has harder bushing it's better to swap the front lateral arm aswell.
Marnix is offline   Reply With Quote
Old 06-21-2012, 04:28 PM   #12
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
why is this posted under powertrain?
Samirr76 is offline   Reply With Quote
Old 06-21-2012, 06:57 PM   #13
69subaru360
Member#: 159682
1995 WRX
2015 F150
Nobody is really picky about that in this section as long as it's about the older cars.
Old 06-21-2012, 08:28 PM   #14
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
And less likely to get a BS answer.
i_c_the_light is offline   Reply With Quote
Old 06-21-2012, 10:17 PM   #15
rsg9115
Member#: 218569
91 leggy sdn turbo
black
Well I got the answer I needed
FS : Whiteline: sway bar, endlinks, alk, perrin endlinks, crawford AOS, STi lateral links, iheartmysuby SCIC Private Classifieds 6 03-29-2011 02:26 PM
FS (SC): OEM 04 STi Front & Rear Sway Bars, Endlinks, Mounts, RCA's/Links, Strut Bar sagelwwa Suspension/Brakes/Handling 28 10-28-2008 08:40 PM
FS: Cusco sway bars, endlinks, strut bars, JDM Pink STI Springs WRXIN Suspension/Brakes/Handling 21 08-02-2007 11:32 PM
WTB: Shocks, Springs, Rear Sway Bar, Endlinks, Strut Bars for 2000 Legacy lgt2000 Private 'Wanted' Classifieds 1 07-06-2007 11:10 AM
GUAGING INTEREST: RARE!! GC8 GAB Rear sway bar/endlinks/sway bar mounts lildragn11 Private 'For Sale' Classifieds 1 10-26-2004 12:01 AM
