Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 06-16-2012, 04:47 PM   #1
recian
Member#: 313209
1995 Impreza L
blue-green
Default EJ20T swap into 95 impreza L
I've read some posts and it says this swap has been done. Im curious if anyone can point me in the right direction? Maybe with some thread links on the site. I'm trying to see if i can do the swap without having to buy a whole GC8 clip and convert to RHD to make the crossmember and hydraulic clutch trans fit.
recian is offline   Reply With Quote
Old 06-21-2012, 08:24 AM   #2
02midnightblue
Member#: 266411
2002 wrx
i am swapping a 95 impreza as we speak. All the bodys are the same from 93-01. My wrx hydro clutch went right in the impreza no issues. And the impreza was cable. All the holes are there and everything lines right up. Just start taking stuff apart and figure it out. Ill tell you this everything works. Use iwire for the harness swap tho.
02midnightblue is offline   Reply With Quote
Old 07-02-2012, 01:04 AM   #3
suberacer_my00_sti
Member#: 324890
2000 Impreza Sti
black
the crossmembers from 2002 wrx fit in my GC8 2000 rs2.5
suberacer_my00_sti is offline   Reply With Quote
Old 07-02-2012, 11:16 PM   #4
99ForesterSti
Member#: 223154
1995 Impreza
green
for the most part, all impreza 93-07 and forester 98-02(maybe newer, never dealt with them) crossmembers are interchangable, depending on what engine you want to run. They are also easy to change if you are already swapping the motor. And yes the hydraulics for the clutch bolt righ in if you have all the pieces.
For an example of interchangibility, my 95l has an ej20k w/ 5-speed trans + hydraulic clutch, 02 wrx pedals, 06 sti crossmember and a hodge-podge of other parts off of other subarus. And this drivetrain was previously swapped into a forester (hence the name) and it all bolted in with no modification.
The only thing that wasnt easy was the wiring, subaru was nice with the mechanical interchangibility but wiring wise forget it. Contact I-Wire for the wiring, it will be worth it. Im kicking myself for tacklling wiring myself
99ForesterSti is offline   Reply With Quote
Old 07-04-2012, 08:19 PM   #5
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
Any usdm crossmember will need the front control arms shimmed. I got a jdm sti cross and sway to eliminate that. Go to I-wire, amazing customer service, and workmanship. Check RS25 because this has been covered extensively.
MattTHEpainter is offline   Reply With Quote
Old 07-10-2012, 01:27 AM   #6
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Correct, the control arms for the 02+ are wider where they bolt to the cross member, so you either run a 93-01 turbo cross member, or the 02+ WRX cross member and shim you control arms, or go with the 02+ WRX front control arms, which will also have a wider stance than your stock ones, unless they are from a WRX wagon. And RS25 is a great resource, try to find some old posts here and on RS25 by Supermoose(I think that was his S/N) his writeups have helped me with several swaps.
Hope this helps.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 07-12-2012, 06:50 AM   #7
sakibs1111
Member#: 325899
thats nice post bro.
sakibs1111 is offline   Reply With Quote
Old 07-28-2012, 05:11 PM   #8
thefixion
Member#: 311881
I am putting an ej20k in to my 95 L. i haven't been able to find much info on the clutch conversion.. i have bought a usdm wrx clutch and flywheel, but the whole pull type push type clutch stuff is confusing me what do i need to get the ej20k tranny(TY752VBCAA) to work?
thefixion is offline   Reply With Quote
Old 07-28-2012, 08:34 PM   #9
RallyColtTurbo
Member#: 16819
If you already have a\the EJ20K tranny, all of the little details will be the same as a USDM WRX. If for some reason newer parts don't work the only other USDM car to look at is the '91-'94 Legacy turbo.
RallyColtTurbo is offline   Reply With Quote
Old 07-28-2012, 09:09 PM   #10
subieguy87
Member#: 153412
1998 Impreza wrxRS
My 98L has an ej205 in it
subieguy87 is offline   Reply With Quote
Old 07-29-2012, 08:56 AM   #11
thefixion
Member#: 311881
so i read somewhere that in 05 the wrx crossmember is different becuase of some change to the steering rack. is that true? the reason i ask is im trying to find a crossmember for the 20k and id rather not pay full price for a new one but i can only find a used 05 crossmember.
Old 07-29-2012, 10:26 AM   #12
subieguy87
Member#: 153412
1998 Impreza wrxRS
You need a post 05 rack to go with a post 05xmember. But any will fit.
02 wrx swapped into 95 impreza 95SubieNate Subaru Conversions 10 08-06-2011 11:14 PM
95 legacy rear crossmember into 95 impreza? greg donovan Subaru Conversions 1 10-02-2010 01:07 AM
EJ20T swap into 2.5GT mfdakid Subaru Conversions 2 04-20-2004 07:10 PM
Jspec EJ20T swap into 97 Impreza L Murray Engine Management & Tuning 24 11-02-2002 03:20 AM
ej20t in a 95 impreza L nmbwhitey1 Normally Aspirated with bolt-on Forced Induction Powertrain 2 10-14-2002 06:52 PM
