Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 12-03-2014, 09:27 PM   #1
jdmb18b
Member#: 407773
Default blinkers and windows NOT working
Need some help here I have a 2007 subaru impreza 2.5i and today I went to drive my car and I went to turn and my blinkers did not work idk what happend they worked when I parked my car the night before I used my blinkers to turn in my drive way so I tryed my 4 ways they work fine that's what I don't get and as I was sitting there I went to go put my window down and they didn't work so I checked all the fuses in the car and everything is fine I don't get it
jdmb18b is offline   Reply With Quote
Old 12-04-2014, 02:49 AM   #2
jdmb18b
Member#: 407773
No one knows what's going on
Old 12-04-2014, 12:36 PM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I don't have the exact data for your model year but it shows that fuse #6 in the panel under the hood supplies power to the areas you mentioned along with the horn. If the horn doesn't work that would be a very good clue for the fuse problem. If you haven't verifed power is getting through the fuses under the hood yet I suggest you do that next using at least a test light probe placed on each side of the slits on top of the smaller fuses with the clip lead to ground.
Cougar4 is offline   Reply With Quote
Old 12-05-2014, 10:30 PM   #4
Slomaroz28
Member#: 400135
+1 my windows and turn singles stopped working a week ago and I can't find anything wrong
Slomaroz28 is offline   Reply With Quote
Old 12-06-2014, 01:40 PM   #5
menri005
Member#: 386167
2006 Impreza WRX STi
Obsidian Black Pearl
Im having the exact same issue. Replacing the flasher relay does not fix the problem.
Sent from my iPhone using NASIOC
menri005 is offline   Reply With Quote
Old 12-17-2014, 04:51 AM   #6
jdmb18b
Member#: 407773
found my problem my car is low i rubbed thought the wires in the wheel well on the driver side check there
Old 12-20-2014, 03:31 PM   #7
menri005
Member#: 386167
Could you show where it was rubbing? I took a look and didnt see anything unusual.
