Old 06-18-2012, 09:18 AM   #1
supraman95
Member#: 320829
Default disable AVCS on 05 STI longblock in 02 WRX
So I have done alot of searching and trying to figure out what needs to be done. I have an 02 WRX with a 2.5 STI longblock in it. I need to run the car without using the AVCS. Most of the articles I found were older and I did not know what the latest info is on this.
Does someone make block off kits? Is it as simple as just unplugging the AVCS solenoids?
can someone show me pics of each side head and how the oil lines run. Someone welding closed the area where the solenoids go on my heads and I just want to make sure it is even connected correctly.
thanks
supraman95 is offline   Reply With Quote
Old 07-30-2012, 08:00 PM   #2
blynch04wrx
Member#: 249387
Bump I have the same issue plz help
blynch04wrx is offline   Reply With Quote
Old 07-31-2012, 08:15 PM   #3
blynch04wrx
Member#: 249387
Bump ..
Old 09-07-2012, 04:30 PM   #4
yellowbus
Member#: 42537
02 wrX
baby blue carbon
im looking for the same
yellowbus is offline   Reply With Quote
Old 09-07-2012, 05:03 PM   #5
Paidfor
Member#: 267815
Be in awe
dont hate .)
You gotta tap the oil holes in the cam and screw in studs to block the oil flow to the cam gear.
Theres a sheetload of info about this somewhere on here. Im not even gonna try to search for it because Nasiocs search engine sucks harder than a Hoover. Google that ****............you should find it.
Paidfor is offline   Reply With Quote
Old 09-07-2012, 06:42 PM   #6
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
If you want your valve timing to be correct you will need to replace the AVCS gears with non-AVCS gears on the intake cams and modify the cams so they don't leak.
Depending on what ECU you have you will also have to add a reluctor type cam position sensor for your drivers side intake cam and wire that into the ECU.
Old 09-08-2012, 12:59 AM   #7
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Agree! Its honestly just easier to buy a 04 STi harness and ECU on ebay. That way you dont have to mess with the b.s.
The cams Cant be welded or drill and tapped while in the car. The debris and welding slag will fall into the holes and then into the cam journals. I personally seen it wipe out a freshly built engine and the heads. So remove engine, remove cams, have them tig welded closed. Buy new cam gears and be good to go. Or just buy a harness + ecu and be on youre marry way with more power!! Should have done better research on this before you did the swap thinking it would work just fine....
UK-Wagon is offline   Reply With Quote
Old 10-17-2012, 11:29 PM   #8
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
You really have to use the ej20 Cam gears? Can anyone verify this? I was gonna block off the cam oil holes and just run driver side front cam sensor. I also need to block off the other cam sensors that are open on the heads. I think there are two..
99imprezd is online now   Reply With Quote
Old 10-17-2012, 11:33 PM   #9
Wicked Performance
Member#: 265606
thats correct. you need to use the ej205 cam gears. usually you just leave the old sensors in the heads to plug the holes....
Wicked Performance is offline   Reply With Quote
Old 10-17-2012, 11:37 PM   #10
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
ok.. they didnt come with the sensors unfortunately.. is it fine to leave all the oil lines running to the avcs or should they be capped off?
Old 10-17-2012, 11:47 PM   #11
subieguy87
Member#: 153412
1998 Impreza wrxRS
I Have a wrx swapped gc, I read ej205 wiring will run an ej207 with the exception of the avcs. Is this similar or is it easier 205>207?
subieguy87 is offline   Reply With Quote
Old 10-18-2012, 12:25 AM   #12
OC_Nooby
Member#: 311781
2003 WRX w STI V8
I didn't block any oil passages with my 2004 STI Longblock in my 03 WRX.
I followed this guide.
http://elementtuning.com/technical/ej25_install.htm
Unless an 05 longblock is different then a 04? The only thing I did was just tap for a cam sensor the same way it is in the WRX (driver side).
I'm not running AVCS.
Why are people blocking of oil to the cams? AVCS defaults to the open position (no advance).
OC_Nooby is offline   Reply With Quote
Old 10-18-2012, 12:34 AM   #13
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
ok cool.. im already set up for the driver side sensor so Ill just leave the oil lines alone..
Old 10-18-2012, 12:58 AM   #14
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Unless I'm missing something! Car has been running for 3k so far, no issues. Minus my super restrictive turbo inlet (that's a diff story). GL!
Old 10-18-2012, 01:08 AM   #15
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
so youre running the sti cam gears? this is what i was unclear about.. i thought theyd work fine but wasnt sure about the timing..
Old 10-18-2012, 12:29 PM   #16
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Yup I'm running the STI cam gears.
Old 12-26-2013, 05:10 PM   #17
salvi
Member#: 188132
From reading the entire document, the only major thing to do is tap the mounting hole for the WRX cam sensor. They didn't plug any cams or use WRX cams, etc. So, what's the final word on this?
salvi is offline   Reply With Quote
Default what cams have the plugs for avcs to run 2.5 longblock in 02 wrx wrxmase Built Motor Discussion 8 02-05-2011 10:33 AM
what cams have the plugs for avcs to run 2.5 longblock in 02 wrx wrxmase Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-01-2011 10:11 PM
04 sti longblock in 03 WRX no AVCS V8Nate Subaru Conversions 9 06-13-2010 04:53 PM
2.5 longblock in 02 wrx injector latencies sgiord86 Built Motor Discussion 8 01-20-2010 02:51 PM
USDM 05 STI Longblock into 02 bugeye Pita84 Built Motor Discussion 2 03-18-2009 10:42 PM
