Old 06-18-2012, 10:33 AM   #1
owetwo
Member#: 240873
Default Help! 02' WRX wont start
I need some help trouble shooting my car I dont know how to explain the sound coming from the engine but here is a video that shows the sound im getting (not my video). I will try to post my own video later.
The car basically just cranks but never starts. Any ideas of what it could be? The sound seems to be coming from where the Fuel Pressure Regulator is but I dont know if thats the problem.
Has anyone heard of this? I have new fuel pump, injectors, spark plugs.. Im another part away from ripping my hair out.
owetwo is offline   Reply With Quote
Old 06-18-2012, 10:38 AM   #2
SnowmanFX
Member#: 25753
2015 WRX
Lightning Red
Check your compression.
Air
Fuel
Spark
Compression
Timing
SnowmanFX is offline   Reply With Quote
Old 06-18-2012, 10:46 AM   #3
owetwo
Member#: 240873
Air
Fuel
Spark
Compression
Timing
Have you ever heard this noise before though? I placed a cone right on top of the fuel pressure regulator and the sound seems to be coming directly from this spot. But I want to get some opinions on the problem.
Old 06-18-2012, 10:48 AM   #4
SnowmanFX
Member#: 25753
2015 WRX
Lightning Red
I have to wait to watch the video. I am at work
Old 06-18-2012, 10:53 AM   #5
owetwo
Member#: 240873
Same here! I wish I was home so I could make a detailed video. Thing is that injectors were flow tested, fuel pump is new and I know for a fact that its sending pressure up to the fuel filter, spark plugs are new, timing belt got replaced but I dont know if the timing belt could possibly be off by a tooth. I carefully aligned everything on the timing belt though even matched the line on the belt itself.
Old 06-18-2012, 11:00 AM   #6
backslider
Member#: 43196
1999 STi Type R
93GF 95GC 02GD 01SF-T
Since we are playing the guessing game and you just enlightend us that you also did a timing belt, can you provide any other details of things that you have done before the non start issue.
1, timing belt
2, injectors
3????
backslider is offline   Reply With Quote
Old 06-18-2012, 11:01 AM   #7
TheTallOne
Member#: 302855
2008 WRX
DGM/CF
It would still run if off 1 tooth. New build, had it running before?
TheTallOne is offline   Reply With Quote
Old 06-18-2012, 11:10 AM   #8
shawns_sick_STi
Member#: 126107
2004 STi
You hook up your fuel lines right? As in the supply line is going to your injectors and the return to the FPR? My friend did this and it sounded like this if I remember. He swore that it was hooked up right and then we switched them and it fired right up. Just throwing things out there. Hard to say without looking at the car.
shawns_sick_STi is offline   Reply With Quote
Old 06-18-2012, 11:18 AM   #9
owetwo
Member#: 240873
I will double check the lines when I get home but this noise was occurring before I removed anything from the car. My car had stalled on the freeway in traffic, I was about to release the clutch to take of and I heard a weird noise in the engine and I had it towed home. Tried starting it at home and that sound was present I didnt make much of it but the car wouldn't start. Removed the engine and saw that the timing belt was jammed but it was not completely snapped it still held to all gears. I ended up replacing injectors, fuel pump, clutch, timing belt and all pulleys along with the water pump. Then after I replace everything that noise is still present and It wont start.
Old 06-18-2012, 11:30 AM   #10
owetwo
Member#: 240873
1, timing belt
2, injectors
3????
I basically had this happen to me, luckily I was going <1mph when the car stalled. I go the car home in a tow truck not knowing what was going on or what happened. I attempted to start the car at home and that hissing noise was present then but I didnt make much of it. But after I figured what happened I replaced belt, injectors, spark plugs, fuel pump, clutch, pressure plate and all timing pulleys including water pump.
Old 06-18-2012, 11:44 AM   #11
backslider
Member#: 43196
1999 STi Type R
Check your compression, then start looking at the injector harness, making sure they are in the correct location. I am going to bet the timing is still off.
Old 06-18-2012, 12:09 PM   #12
owetwo
Member#: 240873
I will check the timing belt as soon as I get home. I remember aligning everything and double checking about 10 times all the notches.
Old 06-18-2012, 01:02 PM   #13
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
So thats the ac and alternator belt not the timing belt?
iconone is offline   Reply With Quote
Old 06-18-2012, 01:20 PM   #14
owetwo
Member#: 240873
Thats the timing belt.
Old 06-18-2012, 01:48 PM   #15
SnowmanFX
Member#: 25753
2015 WRX
Lightning Red
Make sure you research the timing belt install too.
I see this is a Hybrid, 2.5L block on 2.0L heads?
Old 06-18-2012, 01:50 PM   #16
owetwo
Member#: 240873
No this isnt my video, its a video I found that had a similar problem. Just so people could know.
Old 06-18-2012, 01:54 PM   #17
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
Isnt it when a timing belt snaps most of the time the motor is done as well?
Old 06-18-2012, 01:57 PM   #18
flatfourspeed
Member#: 256434
2013 STi Sedan
02 WRX Wagon
where are you at in houston? check all your sensor connections.
flatfourspeed is offline   Reply With Quote
Old 06-18-2012, 02:00 PM   #19
atomicfire
Member#: 136296
2005 STi
Id love to lend a hand - send me a PM, I live in midtown
atomicfire is offline   Reply With Quote
Old 06-18-2012, 02:01 PM   #20
SnowmanFX
Member#: 25753
2015 WRX
Lightning Red
http://www.wikiauto.com/Subaru-Impre...placement.ashx
Make note of the Lines, not the arrows.
Old 06-18-2012, 02:18 PM   #21
owetwo
Member#: 240873
I live a bit south of downtown. i45 and woodridge. about 5 minutes away from University of Houston Main Campus.
Old 06-18-2012, 02:27 PM   #22
owetwo
Member#: 240873
I did that I know my timing has to be right I double check everything to make sure it was timed and everything matched up. BUT let me check that again tonight when I get home, I will verify the information.
Old 09-26-2012, 01:58 PM   #23
barrob326
Member#: 333361
I wanted to ask what you did to resolve this. Did that diagram on WikiAuto help?
barrob326 is offline   Reply With Quote
Old 10-28-2012, 01:48 PM   #24
iskylineo
Member#: 336366
05 WRX
blue (for now)
Arrow Help me please
Hey i live off 45 and rankin so im just south of you. I wanted to know if you fixed your problem because im having starting problems were as the car will crank just not start and i think its due to coolant spilling everywere when i failed at bleeding the system haha. any advice?
iskylineo is offline   Reply With Quote
Old 03-03-2013, 03:42 PM   #25
subi-T
Member#: 348082
2006 impreza
SGM
Default my 02 wrx wont start after clutch replacment
Hey guys I hope I can get some help here, I have a 2002 subaru wrx and a mechanic replaced my clutch but now it won't turn on only when I put starting fluid??
Any help? Thanks
subi-T is offline   Reply With Quote
Help 03 WRX wont start after new battery! newgensti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 05-31-2016 03:23 PM
Help Help *wrx Wont Start* Help Help hawaiifosho Newbies & FAQs 11 05-27-2011 08:22 AM
02 wrx wont start after timing please help ej20wagon02 Service & Maintenance 6 04-03-2009 02:05 PM
Help My WRX wont start! Jokoso Newbies & FAQs 9 10-30-2002 10:02 AM
need help wrx wont start Brewmaster New England Impreza Club Forum -- NESIC 8 06-15-2002 09:06 PM
