Old 09-28-2012, 10:19 PM   #276
teesutt
Member#: 127940
Evil shenanigans
You need a tune with that pump, atleast thats what i was told by paul at pandl
teesutt is offline   Reply With Quote
Old 09-28-2012, 10:21 PM   #277
Juks
Member#: 108163
2015 WRX, 2005 STI
When I went to an inline bosch my afr went rich too. IDC's on the in tank were 100% and with the 044 they're around 80%.
Juks is offline   Reply With Quote
Old 09-28-2012, 11:01 PM   #278
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
Walbro 450 + ID2000s = fuel coming out of my ears lol
C J is offline   Reply With Quote
Old 09-28-2012, 11:30 PM   #279
Clark Turner
Member#: 178047
02 WRX STI Spec C
YEP. Tons of fuel now. Should be an easy fix to lean her out a bit. I used that pump today with 1000s at 50 psi base pressure. Made 500 easy.
C
Clark Turner is offline   Reply With Quote
Old 09-28-2012, 11:49 PM   #280
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
C
Battery powered/relay or stock wiring? Jw
stretchedk7 is offline   Reply With Quote
Old 09-28-2012, 11:53 PM   #281
Clark Turner
Member#: 178047
02 WRX STI Spec C
Nope. Number 10 wire, 30 amp relay. The 450 burned up the stock pump controller and threw codes. It wont support the big pump.
C
Old 09-29-2012, 12:46 AM   #282
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
C
Kinda funny. Never heard of that happening. Haven't looked much either though
Layvon is offline   Reply With Quote
Old 09-29-2012, 01:09 AM   #283
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
C
That that's exactly what I was wondering.
Old 09-29-2012, 12:40 PM   #284
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
C
Sounds like what I have set up.
Old 09-29-2012, 01:07 PM   #285
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
Here is a picture of the assembly, turned out pretty nice after you modify a few things to make it fit.
Old 09-29-2012, 01:12 PM   #286
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
u should get rid of that filter too....and put an inline in the engine bay.
Old 09-29-2012, 01:23 PM   #287
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
Yeah my buddy just did that, I like the idea of doing that but probably won't happen this season. I am getting pretty tired of buying stuff for this car, just wanted to get it up and running on 30psi and make one trip to the track which is fast approaching (October 12th).
Old 09-29-2012, 01:30 PM   #288
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
The reason why Phatron mentioned that is because that stock filter may and will become a restriction in flow on your way to 30 psi.I hope everything goes well,good luck and be safe.
john 1badSTI is offline   Reply With Quote
Old 09-29-2012, 01:39 PM   #289
Phatron
Member#: 36033
CEO PhatBottiTuning
plus its easier to get to if you put it in the engine bay.
and my neighbor had his fail....the brass part and white ceramic part untwisted somehow in the tank and he was leaking out the middle of it. Took a while troubleshooting before that was discovered.
Old 10-09-2012, 09:40 PM   #290
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
Hoping to take it to the track on Friday. Just waiting for Junior to give her a clean bill of health and get LC set up.
Praying for 10s.
Old 10-09-2012, 11:10 PM   #291
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
CJ I got ya tonight bud
Junior2JZ is offline   Reply With Quote
Old 10-10-2012, 12:38 AM   #292
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
Whenever you get a chance, I know you're a busy man.
Old 10-10-2012, 09:56 AM   #293
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Just curious...is that the stock sock filter or walbro? My stock one is pretty old and beat up and I have some older ones from the 255lph. The 400 didn't come with anything extra, I'll be putting it in soon.
Good luck at the track.
TyranosaurusWRX is offline   Reply With Quote
Old 10-10-2012, 01:03 PM   #294
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
See phatrons post above regarding the sock
Old 10-10-2012, 01:42 PM   #295
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
It is the new one. I switch them out everytime I change fuel pumps, I was surprised how dirty the sock from my walbro 255.
Old 10-10-2012, 03:29 PM   #296
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
I was under the impression he was talking about the actual fuel filter.
Thanks C J, I know in the past people were worried about the walbro sock collapsing....didn't know if that was still the status quo.
Old 10-10-2012, 03:35 PM   #297
Phatron
Member#: 36033
CEO PhatBottiTuning
yes i was talking about the filter....not the sock. The filter on the left is from the older wrx's and its in the engine bay....the one on the right is above the fuel pump in tank now
Old 10-10-2012, 07:52 PM   #298
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
What do you all recommend I have the LC set to?
Old 10-10-2012, 08:01 PM   #299
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
You can change it at the track can't you? You may have to adjust up our down based available traction.
If you can change it you tell us what worked best for you that day. It may not be what works the next day though.
Old 10-10-2012, 08:08 PM   #300
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
Where is a good place to start?
I don't think the car has a lot of launches in her before the clutch lets go. So...I don't know how many passes I will get before I am all done.
2007/2008 STI = Same R180 ? experts please! Team Scream Transmission (AT/MT) & Driveline 9 05-21-2013 04:02 PM
2006 Forester E85 / Mustang Dyno PoZeR Proven Power Bragging 8 06-29-2011 04:51 PM
FS : 2006 Aspen White STI (Ready for E85 conversion) biker921 Private Vehicle 'For Sale' Classifieds 0 08-08-2010 11:43 AM
Cheap quiet RCA's please? Experts, please contribute. ebeck Car Audio, Video & Security 20 11-29-2004 02:22 PM
