Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 01-31-2013, 09:29 PM   #351
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Not saying it is the best way to do it, but here is my set up
One line goes through catch can to the PCV.
Other Line goes through the catch can to the head breathers
I kept the "equalizer" tube between the heads, but plugged the middle piece that used to go to the PCV I think.
Layvon is online now   Reply With Quote
Old 01-31-2013, 09:29 PM   #352
C J
Member#: 132587
2006 JrTuned STi
Stock block 10.34@134mph
Originally Posted by kellygnsd View Post
Initially I was thinking purge/evap system but now that I'm on the same page as you read on:
I run the the Crawford AOS so my PCV system is modified I guess. I no longer have the PCV solenoid valve in the system but I still get crankcase ventilation when the turbo is spooling because I added a nipple on my intake for the AOS to draw a vacuum from because I figured some crankcase ventilation is better than none and since I'm breaking in a new motor I wanted to give the rings the best chance to seal. Crawford says you can just vent to atm if you like but like I said, some is better than none.
Yea I do not have the solenoid anymore either but wanted to see what guys thought about venting to atmosphere or if it is necessary to plumb back into the intake.
C J is offline   Reply With Quote
Old 01-31-2013, 09:32 PM   #353
C J
Member#: 132587
2006 JrTuned STi
This is the other option I am thinking about with a short "intake" basically a pipe with a couple of fittings or nipples for the lines.
Old 01-31-2013, 09:55 PM   #354
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
10 - 4. If you do it, be smarter than I was. Weld your fittings around the pipe not down it.
the reason I took that picture was to show how tight it was in there. If I did it around the pipe I would have had plenty of room.
I bought 2 new weld on fittings but my buddy who tig welds is laid off right now, and I dont have a strong desire to pay someone to weld those two little things.
Old 01-31-2013, 11:41 PM   #355
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
I draw my Crawford AOS through my CAI so that the intake would help pull crankcase pressure from the heads. Faulty logic?
I have the pcv valve in the intake manifold plugged, and one port in my case plugged. 2.0 heads on a 257.
I'm realizin that I'm not really venting pressure anywhere...
maxpowr is offline   Reply With Quote
Old 01-31-2013, 11:44 PM   #356
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I see the logic, your oil just recirculates back to pan
Old 02-01-2013, 01:05 AM   #357
phillcam021
Member#: 260937
2005 wrx sti
phillcam021 is offline   Reply With Quote
Old 02-01-2013, 02:44 PM   #358
C J
Member#: 132587
2006 JrTuned STi
never thought about that...
Old 02-01-2013, 04:07 PM   #359
phillcam021
Member#: 260937
2005 wrx sti
I'm gonna run the rear crank breather port to a -12 an sized AOS than to that vibrant E-vac in te down pipe . No Pcv valve .
Old 02-01-2013, 04:49 PM   #360
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Do some research on those ... people have mixed feelings
Old 02-01-2013, 11:34 PM   #361
casper64
Member#: 178083
2004 545 awhp, sti
blue
I am running a 4Ętube and air filter with pump gas map, and no air filter with meth and pump map,and same for race fuel map only a screen to avoid little rocks from getting to the turbo, oil catch can,no pcv. since you are not running maf any more you can go with bigger tube for your air filter.
casper64 is offline   Reply With Quote
Old 02-02-2013, 12:19 AM   #362
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
wouldnt that bring blowby into your exhaust?
Old 02-02-2013, 10:20 PM   #363
C J
Member#: 132587
2006 JrTuned STi
Ordering a clutch this week possibly. Clutch Masters FX400 w/ the flywheel.
Also decided to make the trek to TX2K13 this year so we will be getting some of the issues ironed out this month and getting her ready to rock and roll.
Old 02-03-2013, 01:51 AM   #364
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Why the air filter on for pump and off for meth? Why not just pick one or the other? I know some people see 15-20 ditching the filter but why not just always keep it off or on?
Slimsti is offline   Reply With Quote
Old 02-03-2013, 02:18 AM   #365
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
CJ go 10s at TX2k13
Junior2JZ is offline   Reply With Quote
Old 02-03-2013, 02:36 AM   #366
gaby
Member#: 94097
2004 WRX Hybrid GT35
11.2@130.7
Originally Posted by phillcam021 View Post
I been using this for 3 years and love it.
gaby is offline   Reply With Quote
Old 02-03-2013, 02:00 PM   #367
C J
Member#: 132587
2006 JrTuned STi
Originally Posted by Junior2JZ View Post
CJ go 10s at TX2k13
That is the plan my friend!
It'll be weak **** compared to the rest of the vehicles there but I don't care, the track conditions will be the best I have ever seen and I am hoping for a fast track.
Old 02-03-2013, 02:59 PM   #368
yamahaSHO
Member#: 73932
2005 STi - E85
2004 S2000 - E85
You going to get the clutch in before then?
Sounds like I need to bring a 30-pack and head up your way?
yamahaSHO is offline   Reply With Quote
Old 02-03-2013, 03:45 PM   #369
C J
Member#: 132587
2006 JrTuned STi
Yea I think we can get it done. I need to get the intake sorted out and then get the GM IAT sensor wired in and ditch the stock MAF sensor.
Old 02-03-2013, 07:13 PM   #370
casper64
Member#: 178083
2004 545 awhp, sti
blue
When on pump map I use car for DD and I live out on the hills, with dirt roads,dont want that dust to get in to the engine, and when I go racing there is no problem there, as far as removing the air filter and pick up a few extra ponys
Old 02-03-2013, 07:22 PM   #371
casper64
Member#: 178083
2004 545 awhp, sti
blue
Theres nothing conected to the exhaust,head breathers are T to catch can, and crank case with out Pcv is conected direct to catch can, so blowby straight to atmosphere.
Old 02-03-2013, 07:25 PM   #372
C J
Member#: 132587
2006 JrTuned STi
how many guys actually use these?
Old 02-03-2013, 08:09 PM   #373
C J
Member#: 132587
2006 JrTuned STi
Or could someone just explain why I shouldn't just vent everything to atmosphere? I know it isn't ideal but what am I really going to run into by doing it this way?
Old 02-03-2013, 09:52 PM   #374
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I don't think it will hurt anything it will just not have any vacuum to pull from the heads.
Old 02-03-2013, 10:06 PM   #375
casper64
Member#: 178083
2004 545 awhp, sti
blue
I am runing to atmosphere with no issues, -20 on the gage at idle.
2007/2008 STI = Same R180 ? experts please! Team Scream Transmission (AT/MT) & Driveline 9 05-21-2013 04:02 PM
2006 Forester E85 / Mustang Dyno PoZeR Proven Power Bragging 8 06-29-2011 04:51 PM
FS : 2006 Aspen White STI (Ready for E85 conversion) biker921 Private Vehicle 'For Sale' Classifieds 0 08-08-2010 11:43 AM
Cheap quiet RCA's please? Experts, please contribute. ebeck Car Audio, Video & Security 20 11-29-2004 02:22 PM
