Old 06-25-2012, 02:21 PM   #76
teesutt
Member#: 127940
Evil shenanigans
i have the same turbo running e85 with a Junior speed density tune on an AP. I also have big lines and rails, aem 3 bar map and an Aero 340 hardwired. Had similar issues at first, ended up being 2 bad Aero 340s. Third one did the trick.
Also, arent those injectors a little big for the stock ecu? I thought the ID2000's required stand alone fuel management like hydra or aem?
teesutt is offline   Reply With Quote
Old 06-25-2012, 07:42 PM   #77
C J
Member#: 132587
2006 JrTuned STi
[email protected]
which turbo kit do you have?
C J is offline   Reply With Quote
Old 06-25-2012, 08:30 PM   #78
teesutt
Member#: 127940
Evil shenanigans
Perrin 3582r, tial 44
Old 06-27-2012, 06:31 PM   #79
C J
Member#: 132587
2006 JrTuned STi
[email protected]
KSTech megaMAF 83mm intake has been ordered, will be waiting impatiently
Old 06-30-2012, 10:39 AM   #80
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
That should really help
stretchedk7 is offline   Reply With Quote
Old 06-30-2012, 12:23 PM   #81
Racer_X_X
Member#: 141804
'98 RSTi HTA86 AEM
'02 35R-Nürburgring Cert.
I would try the double pumper, as you pretty much have everything you need to do it.
I went straight to blow-threw and speed density on mine and never had any idling issues, I just started to blow the MAF electronics off the tube. Fixed that, and haven't had any issues since.
Racer_X_X is offline   Reply With Quote
Old 07-24-2012, 08:17 PM   #82
RyBread916
Member#: 318285
2005 WRX STi
Originally Posted by Layvon
If you're tuned w/ a cobb, you should consider speed density to see if that is part of the problem. There is a setting on there where it blends the two so you dont have to retune right away, but it doesn't sounds like getting a modified tune is a problem for you.
If you have a Cobb tuning facility near you, get the accessport and have them do the speed density protune. It's a little more spendy, but after 4-5 months of trying to figure out this problem, it may be worth investing in. I got a speed density protune and couldn't be happier with the results. Perfect drivability and great power!
RyBread916 is offline   Reply With Quote
Old 07-24-2012, 08:23 PM   #83
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Yeah I am still struggling with the car, more or less to the point I have given up on it and the car can just sit. I go back to Nebraska a few times a month and don't even look at the car anymore.
Old 07-24-2012, 08:35 PM   #84
CatfaceType-R
Member#: 81102
Don't give up, mate.
CatfaceType-R is offline   Reply With Quote
Old 07-24-2012, 08:38 PM   #85
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
same here, 6+ months at a time 3 times now, everytime inbetween debated getting rid of and giving up
Irv Weissmanhowerton is offline   Reply With Quote
Old 07-24-2012, 08:41 PM   #86
WagonMafia23
Member#: 273900
02 wrx
SRP
im in the same boat but with my 240 ka-t, having pressure drops and misses under boost, sometimes i want to sell it and put it into my subi but patients will pay off
WagonMafia23 is offline   Reply With Quote
Old 07-24-2012, 09:18 PM   #87
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
After re-reading this again, I'm first of all curious about how the bigger intake helped / didn't help.
Secondly. . . You are trying to run 500whp on stock lines on E85. That is a lot of fuel for those lines, which I think might be part of the problem, not the entire problem, but some. There is 44% more cross sectional area by merely jumping from 5/16" to 3/8" (6AN). It would be relatively inexpensive to test some push-lok fittings and rubber hose to see if it helps, and if it does, just upgrade to stainless lines. FWIW, on my ~500whp E85 build I'm doing a walbro 255 feeding a surge, 2 044s feeding -6 lines, merging to a -8 line to the rails. From what I've heard, 500whp is the limit on on 93 you need to take 30-40% off that for E85.
Just my .02 again.
Layvon is offline   Reply With Quote
Old 07-24-2012, 09:23 PM   #88
C J
Member#: 132587
2006 JrTuned STi
[email protected]
The issues that have frustrated me to the point of giving up on the car is the terrible idling, misfires, etc. All occur at idle or just cruising around. Car was taken apart in March expecting a fun summer with track trips praying not to blow it up...instead it hasn't left the garage unless for a short drive to do some logging. My friend who had the car for awhile took the car to his house and had his "tuner" mess with it. Said he wouldn't charge unless the car ran better, given that he has been tuning my friends EVO for quite a few years and seems to be pretty good buddies with him I said sure why not. Well car ran like total ****, guy didn't know what the hell he was doing with a Subaru and disabled all kinds of things and didn't bother scaling the MAF, after I told him I wanted to just call it quits and part ways it turns out my buddy had already fronted the money for a "tune". The tuner MELLON RACING (total **** btw) wouldn't refund my friend who is a loyal customer of his so I just paid my friend since it wasn't his fault the guy is a douche.
I started the car on May 13th after getting the new turbo kit on, car ran and drove sort of. I have spent about $3000 just trying to get it to run right. Frankly I am just tired of spending money on a bottomless pit. I probably could have just dropped the car off at a shop and picked it up for less money.
On a positive note I finally just went to the bank and paid off the balance of the loan b/c I am tired of paying for a car I never drive.
Old 07-24-2012, 09:39 PM   #89
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Does the car currently have a solid tune on it? You gotta figure this out. Do you think there is a short in the wire harness? My guess is some type of wiring problem in the coilpack area.
Maybe switch up those fuel rails, PIA but might be it also.
TDagen is offline   Reply With Quote
Old 07-24-2012, 09:45 PM   #90
SuaveCougarBait
Member#: 255092
2007 WRX Limited
Garnet Red Peal (33j) e85
Car is idling better last I knew with the KS Intake.
SuaveCougarBait is offline   Reply With Quote
Old 07-24-2012, 09:47 PM   #91
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Car as it sits has a very basic tune on it with the new KSTech intake. After getting taken for cash on that screwy deal from my friends tuner I am not sure what to do with the car right now. I have spent a lot of money chasing false leads with not a whole lot of luck...
The car ran fine on the old stock turbo set up so I don't think the harness has an issue, has to do with the new parts/setup on the car now.
Old 07-24-2012, 09:48 PM   #92
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Still has a ways to go but I hate bugging Jason to help me.
Old 07-24-2012, 09:49 PM   #93
SuaveCougarBait
Member#: 255092
2007 WRX Limited
CJ, I think Jason was fairly confident we can work with it now. At least we had talked about it on the drive home that night.
Old 07-24-2012, 09:50 PM   #94
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Talk to one of the real tuners who have posted here. I know you're aren't there much, but Junior isn't that far from you. I'm not sure who else is around you. AMS doesn't tune non AMS builds anymore so thats out...
is someone in Indy any good at tuning?
Layvon
Old 07-24-2012, 09:51 PM   #95
SuaveCougarBait
Member#: 255092
2007 WRX Limited
You're a good friend. We just new to nail a time down when you're up here and Jason has time.
Old 07-24-2012, 09:51 PM   #96
C J
Member#: 132587
2006 JrTuned STi
[email protected]
He is a busy guy and I don't have the ideal schedule to work around.
Old 07-24-2012, 09:51 PM   #97
SuaveCougarBait
Member#: 255092
2007 WRX Limited
Haha I feel your pain on that.
Old 07-25-2012, 12:01 AM   #98
bjohnson_55
Member#: 216580
Where's the car?
bjohnson_55 is offline   Reply With Quote
Old 07-25-2012, 12:27 AM   #99
RyBread916
Member#: 318285
2005 WRX STi
Get an accessport and speed density protune. The MAF is a PITA with a turbo that big. Once I got mine all the problems you are talking about went away. My walbro 255 was maxed out at 400whp on 92 pump.
Old 07-25-2012, 12:35 AM   #100
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i want a shot at it. send me the modlist and rom, lets do this!
2007/2008 STI = Same R180 ? experts please! Team Scream Transmission (AT/MT) & Driveline 9 05-21-2013 03:02 PM
2006 Forester E85 / Mustang Dyno PoZeR Proven Power Bragging 8 06-29-2011 03:51 PM
FS : 2006 Aspen White STI (Ready for E85 conversion) biker921 Private Vehicle 'For Sale' Classifieds 0 08-08-2010 10:43 AM
Cheap quiet RCA's please? Experts, please contribute. ebeck Car Audio, Video & Security 20 11-29-2004 01:22 PM
