Old 07-30-2012, 08:59 PM   #126
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
That's an option but I'm getting a pretty good deal as is.
C J is offline   Reply With Quote
Old 07-30-2012, 09:05 PM   #127
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Oh okay. Combo deal on a new 1 + a tune from ron, I like it. He will treat you right n your car will be flawless. When will the tune be done?
Layvon is online now   Reply With Quote
Old 07-30-2012, 09:25 PM   #128
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
Good deal + Jrtune =)
Junior2JZ is offline   Reply With Quote
Old 07-30-2012, 09:34 PM   #129
SuaveCougarBait
Member#: 255092
2007 WRX Limited
Garnet Red Peal (33j) e85
I am glad to see you going SD...I dont think you are going to regret this.
And if Junior is helping...well rumors have it he knows a few things
SuaveCougarBait is offline   Reply With Quote
Old 07-30-2012, 09:49 PM   #130
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I think the rumors are true too... I wish his inbox would empty so I could PM him about a vipec!
Old 07-30-2012, 09:58 PM   #131
SuaveCougarBait
Member#: 255092
2007 WRX Limited
Mmm ViPec..now your talking! And I am drooling a little.
Old 07-30-2012, 11:24 PM   #132
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I'm getting one, it is just a matter of who is tuning it
Old 07-31-2012, 12:52 AM   #133
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
Money sent, I can count down the hours until this thing runs....IMPATIENT is an understatement
For the first time in months I am seriously hopeful, from what everyone has said here this is the trick that should do it.
Old 07-31-2012, 05:50 AM   #134
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Originally Posted by 99STM View Post
I'm pretty sure that basic physics and common sense will tell you that if you break a half shaft, it's going to pull to one side or the other. Seeing how there are walls on both sides of the track, it's a good chance you'll hit one of them if you are doing 100+. Hitting the wall at a track is a risk you take no matter what you drive at the track.
When I broke my R160, it wanted to pull to the right. Can't imagine how bad an axle would be.
Not so much, unless you're running solid spools and also have the DCCD in lock position. Otherwise you'll just lose all forward drive as the power is unloaded through the now free-spinning axle. Ask anyone who has broken a left rear axle while launching...sometimes the car won't even break the traps to start the timers, it just sits with no motion until the driver locks the DCCD and backs out of the box (AKA puts tail between legs and heads for pits)
lancelucas is offline   Reply With Quote
Old 07-31-2012, 06:01 AM   #135
99STM
Member#: 219160
2002 Impreza WRX
AW (6MT, E85, EWG, VF39)
I have my DCCDpro locked every time I am at the track. :shrug:
99STM is offline   Reply With Quote
Old 08-09-2012, 08:43 PM   #136
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
What ended up happening with this??
Old 08-09-2012, 08:57 PM   #137
99STM
Member#: 219160
2002 Impreza WRX
Waiting on an AP.
Old 08-10-2012, 04:20 PM   #138
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
Haven't got the AP yet so can't do anything until then. Hope it shows up soon though I really want to drive this thing ha.
Old 08-10-2012, 06:36 PM   #139
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
What's taken so long to get it? (Sorry junior have to harass )
Old 08-11-2012, 01:03 AM   #140
kakarot09
Member#: 182375
08 Sti
Wrbm
Originally Posted by Phatron View Post
blow thru is not the answer...unless its paired with the Cobb MAF/SD combo to utilize the MAF at low MAFv.
But even then blow thru (in most cases) causes great oscillations in teh MAFv due to the pressure waves coming back through the throttle body. And blow thru also necessitates a larger MAF housing....which will just lead to worse drivability than a smaller draw thru.
Speed density is much easier as you can just pop open the table real time and get rid of any crazy fueling issues....but you can do those same things with MAF....although its not real time and you have to find the compensation table to modify. Its time consuming.
I ran my car on the kstech83mm in my daily driver for 4 years without issue. then i switched to an 89mm maf and gtx35 and 280 cams. I still didnt have any real issues, except for one spot when cruising. I didnt really troubleshoot it as i just switched to SD within a week. The cruising issue was gone. For either system you're basically modifying the IPW to dial in the fueling....but its just alot easier to do it in a VE table instead of having to go through every compensation table to get it correct with MAF. Speed density has its own issues which cobb covers in teh manual.
Why do you think the maf v oscillations are caused by pressure pulsations?
kakarot09 is offline   Reply With Quote
Old 08-11-2012, 04:12 AM   #141
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
OP: I think you'll be pleasantly surprised by COBB SD.
Old 08-11-2012, 01:56 PM   #142
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
Hope so! All I hear are good things.
Old 08-17-2012, 01:44 PM   #143
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
Just got a shipping notification. Accessport is officially on its way!
Old 08-17-2012, 02:32 PM   #144
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
Thanks to Lance Lucas!!!
Old 08-17-2012, 03:06 PM   #145
C J
Member#: 132587
2006 JrTuned STi
8.69@164mph
Definitely. I sure hope this is the key to getting it to run and drive better.
Old 08-17-2012, 04:36 PM   #146
SuaveCougarBait
Member#: 255092
2007 WRX Limited
Glad to hear it's in route. I'm ready for this thing to be raping a few things around town
Old 08-19-2012, 06:57 AM   #147
cRashtEstDumy
Member#: 291602
2007 Limited STI#464
Satin White Pearl
I don't want to beat a dead horse but I've been in this same boat as far as your fuel system issues go... Your problem isn't your pump really but it's your fuel lines not allowing the fuel you need for e85... Unless you want to spend $1700+ in upgrading your fuel lines and what not you can do what I did and get 600+wheel horse power on e85 with a GT35 turbo...
DW2200cc injectors
DW300 in tank fuel pump(compatible for e85)
Integrated Engineering Surge Tank w/ Bosch 044pump(battery location)
Relocate your battery to the trunk.
Aeromotive fuel rail kit.
The idea is that the intank fuel pump fills the surge tank up while the surge tank provides fuel directly to the engine, thus avoiding the restrictive stock fuel lines, and reducing the chance of your fuel cutting out or running lean on e85. This allows you to run smoother, longer, and safer while going for 550-800awhp.
http://www.intengineering.com/integr...with-pump.html
http://www.deatschwerks.com/products...tank-fuel-pump
http://www.deatschwerks.com/products...fuel-injectors. (find a way to go top feed)
http://www.rallysportdirect.com/Aero...-STI-2007-2011
cRashtEstDumy is offline   Reply With Quote
Old 08-19-2012, 07:30 AM   #148
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
DW2200cc injectors
$1700 for fuel lines? Are they gold plated?
Old 08-19-2012, 07:42 AM   #149
cRashtEstDumy
Member#: 291602
Satin White Pearl
No... There's more to it than just replacing fuel lines and getting bigger and bigger in tank fuel pumps.
I just explained what I did to cut out all restrictions and have instant response and power for big turbo and running e85...:-)
Old 08-19-2012, 06:12 PM   #150
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
A single Bosch 044 cannot support 600whp+ on E85, at least not at sea level. I've maxxed out more than one, usually starting around 480-490whp
Are you including elevation correction in your 600whp? That'd be quite a bit of power on a 35R at 4000 ft.
Seems like a dangerous place for a surge tank. The trunk seems wiser as there are not nearly many ignition sources vs. the engine bay during a crash.
2007/2008 STI = Same R180 ? experts please! Team Scream Transmission (AT/MT) & Driveline 9 05-21-2013 04:02 PM
2006 Forester E85 / Mustang Dyno PoZeR Proven Power Bragging 8 06-29-2011 04:51 PM
FS : 2006 Aspen White STI (Ready for E85 conversion) biker921 Private Vehicle 'For Sale' Classifieds 0 08-08-2010 11:43 AM
Cheap quiet RCA's please? Experts, please contribute. ebeck Car Audio, Video & Security 20 11-29-2004 02:22 PM
