Notices
Old 06-19-2012, 01:52 AM   #1
eg33GC
Member#: 206851
56 Belair
Pro Street
Default v1/2, which came with non-hla heads?
I'm trying to get a better grasp on which engines for the G came with the "good" valvetrains, rather than the HLA. Valve float past 6500rpm is terrible.
The engine I recently tore down was a closed deck, forged piston, standard intake manifold G, with a 1993 date according to the oil cap. I was super bummed to see HLA under the cams.
Also, anyone have a legitimate source for some heads? The Brits seem to trash their stuff or have no regard for keeping the integrity of the shims/buckets in line with their heads they sell.
eg33GC is offline   Reply With Quote
Old 06-19-2012, 09:23 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
i beleave it was only the STI RA's that got the non hla heads.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 06-20-2012, 05:44 AM   #3
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Yes and the RA was the only one to have forged pistons, so you might want to check those buckets again for shims underneath them
I can identify the heads based on pics of the cams by the way.
Marnix is offline   Reply With Quote
Old 06-25-2012, 12:03 AM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
the buckets look like eg33 buckets, however, there are metal rings at the bottom of the springs.. If this is hla this does not share that with the svx, which oddly could benefit from a steel base because of the dual springs and 7800 stock valvetrain safety limit
Old 06-25-2012, 12:03 AM   #5
eg33GC
Member#: 206851
56 Belair
Pro Street
Old 06-25-2012, 03:02 AM   #6
blessthekellen
Member#: 273859
MY98
WRX
STi non RA also came with forged pistons.
So it is quite possible the motor you have is out of a V1/V2 STi non RA.
blessthekellen is offline   Reply With Quote
Old 06-25-2012, 06:17 AM   #7
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
The early EJ20G WRX engines had three types of pistons:
Stock MT WRX/WRX RA cast pistons built between May 1992 and August 1996
Stock AT WRX cast pistons built between May 1993 and August 1996
Forged WRX STI and STI RA pistons built between June 1994 and August 1996
The non-HLA high rpm valve train only came WRX RA and WRX STI RA engines built between June 1994 and August 1996.
Old 06-26-2012, 12:10 AM   #8
eg33GC
Member#: 206851
56 Belair
Pro Street
I assume these are forged, because I never have seen a cast piston with this quality.
Old 06-26-2012, 01:19 AM   #9
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
The left one is forged, the right one is cast.
Old 06-26-2012, 01:45 PM   #10
eg33GC
Member#: 206851
56 Belair
Pro Street
And those are out of this engine. I posted the image of the camshaft above, do you need a better one?
The buckets are identical to eg33, which are HLA.
Old 06-26-2012, 03:56 PM   #11
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Based on the forged pistons, the HLA lifters and the grooves on the camshaft I'd say you have a 1994-1996 WRX STI engine (no RA). Was the white sticker with the engine code still present on the center belt cover by any chance?
Old 06-26-2012, 04:03 PM   #12
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Sorry, are both pistons (left and right) out of the same engine??
TommyAtomic is offline   Reply With Quote
Old 06-27-2012, 12:37 AM   #13
eg33GC
Member#: 206851
56 Belair
Pro Street
The trans was a b3CA, indicating a normal STi.
It was the forged with hla that got me confused, since I see all the time here that forged= cant have hla
Old 06-27-2012, 04:01 AM   #14
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
That's a misunderstanding I have contributed to aswell. This topic got me to examine the factory documentation AGAIN and it showed the 94-96 STI also got forged pistons, not just the RA. But only the RA got the solid valve train.
Old 06-27-2012, 12:37 PM   #15
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Also keep in mind that the ver1/2 STis were listed as having "Lightweight" HLAs. I don't think anybody has weighed the differences, but it was confirmed that STi parts were different part numbers.
-Rob
rob is offline   Reply With Quote
Old 06-27-2012, 02:14 PM   #16
eg33GC
Member#: 206851
56 Belair
Pro Street
somebody should weigh their standard wrx hla, then I will weigh these.
Also, get rings for a 02wrx for these pistons?
Old 06-29-2012, 06:28 AM   #17
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
No the EJ205 rings do not fit.
Stock HLA 13230AA160 weight 51.0 gramm
STI HLA 13230AA170
Solid RA bucket 13228AA000
Old 07-02-2012, 07:54 AM   #18
eg33GC
Member#: 206851
56 Belair
Pro Street
Okay, what rings then? Time for some japanparts?
Old 07-02-2012, 10:04 AM   #19
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Maybe or try Ebay.co.uk for EUDM EJ20G rings. OEM numbers are 12033AA730 for STD size, AA740 for 0.25 OS or AA750 for 0.5 OS. These rings fitt all 1992-1998 EJ20G and EJ20K engines. Thickness 1.2 - 1.5 - 3.0 mm.
Old 07-02-2012, 03:34 PM   #20
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
Here is a set that would work but I don't have any idea if it is a decent price for them or anything about the seller. http://www.japanesemotorspares.co.uk...set-12033aa730
spackyscooby is offline   Reply With Quote
Old 07-03-2012, 01:47 AM   #21
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
That's quite expensive! I can match that price in Euros for a OEM Subaru set and aftermarket I can get for about half.
Old 07-03-2012, 01:49 AM   #22
eg33GC
Member#: 206851
56 Belair
Pro Street
Think these are worth the trouble? I may as well just buy $450 Wiseco forged pistons for the price of rings.
Old 07-04-2012, 01:18 PM   #23
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Yes and sell me your original forged pistons
Old 07-04-2012, 04:38 PM   #24
eg33GC
Member#: 206851
56 Belair
Pro Street
partially trade you for some K heads!
Old 07-05-2012, 02:17 AM   #25
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
I just traded my last set of K heads...
2.2 n/a with ej205 heads??? 5432gone Built Motor Discussion 8 07-20-2010 12:13 AM
Legacy turbo - which came with a VF10? d00f Pre-2002 Factory Turbo Powertrain 61 04-01-2009 10:06 PM
Any one run into problems with an sti 2.5 swap with wrx heads? Magman Built Motor Discussion 1 06-19-2006 04:02 PM
need advice 2.5 liter with WRX Heads and UTEC jalow72 Subaru Conversions 0 10-06-2005 08:54 PM
2.5 block with STI heads & internals KYScuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-01-2003 11:34 PM
