Old 06-19-2012, 06:48 AM   #1
STi MAN86
Member#: 287906
2006 STi
Default Should I go to Bluch 2.5XTR?
Hey guys,
Just wanted to ask a few questions before I do anything..
Car is currently making about 370/380WHP at 24psi taping of to 22.5psi at top end... Current Turbo was rebuild due to rear main seal leaking oil about 4 weeks ago.
Everything was fine till recently it started to use oil again! Not sure why it happened!? Maybe it can't handle the high boost?
Anyways I was thinking about upgrading the turbo to a Blouch 2.5XTR what are everyone’s thoughts? Would I make more power with less boost or same power figures with less boost? Sorry if it's a noob question
Thanks for any input guys
Here is a log I did not that long ago 3rd gear pull
https://docs.google.com/spreadsheet/...2FQV0ZPUlY1Rmc
07STi
Build bottom end 2.5L
Stock heads 06STi Heads
TD-06H 60-1 8cm kinugawa Turbo
AEM Meth Kit
Custom CAI 73mm MAF, AVO Pod Filter
Hyperflow TMIC
Tactrix 3-Port Boost Control Solenoid
Omni 4bar map sensor
AP 3" Turbo intlet pipe
TGV DELETES
TBE 3" CES system Twin seperated DP
Headers GT Spec Heat wrapped UE
Walbaro fuel pump 255l
Injectors ID 1,000cc
Split fuel rails
Sard Fuel pressure regulator
ACT clutch kit stage 3
NGK 1 step colder plugs
ARP 11mm Head Studs
STi MAN86 is offline   Reply With Quote
Old 06-19-2012, 06:04 PM   #2
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
I think a Dom 2.5 would be a bit of a downgrade from what you are at currently. Look into a dom3
timeXlost is offline   Reply With Quote
Old 06-20-2012, 01:38 AM   #3
KpT KiM
Member#: 242422
Looks like he has a 20G. Don't think it would be a downgrade, but from what I've read the best stock location turbo is the 1.5 XTR. Any bigger and it's good to go rotated.
KpT KiM is offline   Reply With Quote
Old 06-20-2012, 02:12 AM   #4
STi MAN86
Member#: 287906
2006 STi
No it's not a 20g its a gt30 compressor wheel has a 3' Turbo intlet
Would love to know what the dom3 does full boost in 3rd and 4th gear
Old 06-20-2012, 02:20 AM   #5
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
DOM 3 or 4
FP Green HTA or FP Red
500awhp capable turbos on E85 or race gas...
My personal experience is 430awhp at 25psi with an FP Green HTA on an internally bonestock 2011 STI....
jdpsearcher is offline   Reply With Quote
Old 06-20-2012, 02:52 AM   #6
STi MAN86
Member#: 287906
2006 STi
My other quick question is I would should make same power levels that I am making now with less boost with the dom3 or 4 correct? So fuel knock shouldn't be a problem when reaching more power then I am making now?
Old 06-20-2012, 05:15 AM   #7
STi MAN86
Member#: 287906
2006 STi
Originally Posted by jdpsearcher View Post
DOM 3 or 4
Was that on pump gas or E85/race fuel?
Old 06-20-2012, 03:33 PM   #8
fourmicah
Member#: 128760
2017 STI
I had a Blouch Dom3 on my 06 WRX, it was a great turbo, hit full boost around 3500 RPM's, ran strong as hell. I don't think you can go wrong with it. I learned a lot from that turbo set up, primarily that I will always buy bigger injectors and a larger turbo than what I think I want. For the extra $100, go with the Dom4, you already have the supporting mods for the larger turbo and if you want more later you can always retune. It won't spool that much slower either, maybe 250 RPM's.
fourmicah is offline   Reply With Quote
Old 06-20-2012, 07:34 PM   #9
STi MAN86
Member#: 287906
2006 STi
Cheers for the replies guys!
I wonder if my stock 06sti heads and cams will be restricted for 400whp? Any idea when they become a restricted?
Old 06-20-2012, 10:37 PM   #10
fourmicah
Member#: 128760
2017 STI
Not at all. The main thing heads and cams will do for your car is give you more top end power or move your plot to the right, all depending on what you do, how its done and what parts are used. For what you are doing, you can easily pull 400 WHP without any issues.
Old 06-21-2012, 02:09 AM   #11
rexwagon02
Member#: 226312
2007 WRX Wagon
OBP swirled to perfection
I have freshly rebuilt (by blouch) dom3 for sale, way cheaper than new.
rexwagon02 is offline   Reply With Quote
Old 06-21-2012, 03:10 AM   #12
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
E85....
Old 06-21-2012, 09:13 AM   #13
fourmicah
Member#: 128760
2017 STI
^^^^Yes! If I had access to E85, I'd run that exclusively.
Old 06-21-2012, 11:12 AM   #14
al82
Member#: 177913
2011 WRX STi PBP
Well basically you should be looking at turbos above the 55lbs/min range since the 60-1 are old school 30R's. FP HTA Black or Red, ATP GTX series and the DOMs 3 and bigger.
al82 is offline   Reply With Quote
Old 06-21-2012, 12:11 PM   #15
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
I would steer clear of a blouch turbo right now. They were putting out great turbos and making great power but as of late there turbo's have been real hit or miss. Some people are making great #'s and some people are making really lack luster #'s from what i've been reading and hearing. Its a gamble. I gambled and gt bit.lol. Made less power on a dom 3xtr than i was making on my OG Fp green. Be careful, there to expensive to not be sure of the quality.
Slimsti is offline   Reply With Quote
Old 06-21-2012, 02:05 PM   #16
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
really, interesting...
Thran is offline   Reply With Quote
Old 06-21-2012, 02:27 PM   #17
Blouchturbo
Member#: 119764
2006 STi
Our turbos are far from hit or miss, and our quality hasnt changed.
Blouchturbo is offline   Reply With Quote
Old 06-21-2012, 02:30 PM   #18
Blouchturbo
Member#: 119764
2006 STi
Originally Posted by STi MAN86 View Post
Hey guys,
07STi
AEM Meth Kit
Hyperflow TMIC
TGV DELETES
Split fuel rails
ARP 11mm Head Studs
The 2.5X-R and 3.0XT-R are smaller then the 60-1 turbo that you currently have. If your looking to improve spool this would be the way to go, but if your looking for more power then what you are making, look into the Dom 4.0XT-R, ATP35R or the FP HTA BLack
Old 06-21-2012, 03:12 PM   #19
djc1827
Member#: 238618
2011 WRX
11.82 stock 5sp/eng vf52
I plan on making 430-440whp w my 2.5xtr on a mustang dyno at about 24psi. A 3.0 would prob yield 460-475whp. Obviously higher on diff dynos. Turbo is capable of 10s but if your rebuilding the motor you minds well go 4.0+. Just remember that large step in turbo means you will break stuff constantly plus u have to upgrade your fuel system and you will have lots of lag but if you can rev her to 9k who cares
djc1827 is offline   Reply With Quote
Old 06-21-2012, 03:30 PM   #20
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr jdm 6-spd JJtuned
Change your mind about that hta68?
Dave D. is offline   Reply With Quote
Old 06-21-2012, 06:42 PM   #21
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
I think it's funny that you can even disagree with the people that make the turbo...
Good luck with it...I hope you can really push that thing that hard...little turbo's gonna be huffin!
Squidz is offline   Reply With Quote
Old 06-21-2012, 09:17 PM   #22
STi MAN86
Member#: 287906
2006 STi
Yeh right I didn't realize the dom3xtr was smaller then what i have all ready
Old 06-21-2012, 09:20 PM   #23
STi MAN86
Member#: 287906
2006 STi
Ron mention with the dom3 with 93/Meth I should see 420whp
Old 06-21-2012, 10:51 PM   #24
fourmicah
Member#: 128760
2017 STI
Yes, you can. How hard do you want to push the turbo? I think the DOM3 would do fine at that power level, maybe even 450 WHP, but not much higher than that. Remember that you can push any set up really hard, but then you run into the chance that you will be breaking more stuff. I think you have a good set up to run 425-450 WHP with your current set up, but like I said, you'd be pushing it to it max efficiency.
If I were you, I would go with the DOM4 or similar turbo, upgrade your injectors to make sure you can run the fuel and run E85 all day long.
Old 06-22-2012, 04:07 PM   #25
Squidz
Member#: 142608
2003 Sonic Yellow
The dom3 is good for more than 420. We're running ours (and it's the older dom3, not the new one) and pushing 462WHP/481WTQ on E85. Turbo was runing about 25 psi.
I think there is a lot more potential in your current setup.
Should I go to stage 2? SoCal_Scooby AccessPort 3 11-30-2009 12:29 AM
What shop should I go to to get my struts installed? streko Bay Area Impreza Club Forum -- BAIC 2 06-03-2008 01:42 PM
Going to Miami, this weekend, should I go to the Playoff's? chexmix78 Off-Topic 11 04-20-2006 12:35 PM
where should i go to get my swapped 2.5rs looked at? TurboCharged97L Mid Atlantic Impreza Club -- MAIC 22 12-16-2005 05:42 PM
Where should i go to get my swapped 2.5 looked at? TurboCharged97L Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-13-2005 04:27 PM
