Old 06-19-2012, 07:09 AM   #1
danger1138
Member#: 279525
04 rex luger!
Default Oil pan 2.0 or 2.5?
Hey guys, what are the disadvantages of running to 2.0 oil pan on 2.5 block..? Im pretty sure it can be done but just wanted your thoughts?
danger1138 is offline   Reply With Quote
Old 06-19-2012, 08:14 AM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
header clearance
fastnoypi is offline   Reply With Quote
Old 06-19-2012, 08:26 AM   #3
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Better oil control.
The 2.0 pan is a flat bottom pan.
The 2.5 pan is more shaped like a deep sump pan
More oil stays around the pick-up with the 2.5 pan
The internal baffle on the 2.0 pan restricts oil return to the pick-up
The internal baffle on the 2.5 pan is more open and oil returns faster to the pick-up
Samurai Jack is offline   Reply With Quote
Old 06-19-2012, 08:50 AM   #4
danger1138
Member#: 279525
04 rex luger!
Originally Posted by fastnoypi
header clearance
Good point, but i plan on running the grimmspeed pnp exhaust mani, which should fit either oil pan. Right?
Old 06-19-2012, 09:02 AM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Old 06-19-2012, 09:26 AM   #6
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
^This
heres a great thread with pics by KillerBMotorsports
http://forums.nasioc.com/forums/show...8&postcount=36
Old 06-19-2012, 09:27 AM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Correct... and for more pan info/comparisons check out this PAN COMPARISON POST
2.5 FTW!
KillerBMotorsport is offline   Reply With Quote
Old 06-19-2012, 09:28 AM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by fastnoypi View Post
^This
LOL... you beat me by 1 minuite!!
Old 06-19-2012, 10:59 AM   #9
danger1138
Member#: 279525
04 rex luger!
GreAt info on those threads. But being as i only have to flat 2.0 oil pan, my concerns were there compatibility. I thought if i used 2.0 block > use 2.0 pan. Ej257 block >257 oil pan..
Old 06-19-2012, 11:20 AM   #10
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
All EJ blocks have the exact same oil pan bolt pattern. Everything is cross compatible, but you need to keep in mind changing the pan will need the coresponding pickup and baffle too.
Old 06-19-2012, 11:24 AM   #11
danger1138
Member#: 279525
04 rex luger!
Understood. So oil pick up for ej257 will not work on ej205 pan.. Gotcha
Old 06-19-2012, 11:36 AM   #12
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
if you dont have a good oil pickup you should change it while its out. The factory one is weak. Get the Killer B one!
slowgenius is online now   Reply With Quote
Old 06-19-2012, 11:37 AM   #13
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Correct, but it doesn't matter because you are going to use the 2.5 pan with the KillerB Ultimate Oil Pick-up!
and get the 06+ STi pan, not the 05 STi pan. It has a better design
Old 06-19-2012, 02:18 PM   #14
danger1138
Member#: 279525
04 rex luger!
Yea and if i call within the next 10 min, ill get two oil pick ups for the price of one!
Old 06-19-2012, 03:37 PM   #15
cueballsi
Member#: 202736
2002 WRX- 6spd - MBP
1992 Civic VX 40MPG
So what would be better:
Cosworth oil pan (Modified 2.0 pan)
Or
Stock ej25 pan?
cueballsi is offline   Reply With Quote
Old 06-19-2012, 05:44 PM   #16
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Cosworth is a modified OEM pan. They have moving parts, only allow the use of very few aftermarket headers, among many other reasons why we developed our own performance/race pan.
If you don't track more than occasionally, stick with the 2.5 pan.
Old 06-19-2012, 06:01 PM   #17
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
off topic..but is the 2.0L oil pickup long enough to utilize the 2.5L pan? I recall the 2.5L pan is slightly deeper from a post. Not sure if that has been verified.
Old 06-19-2012, 06:27 PM   #18
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No, and it's a worse pickup to use. Stay away from open bottom pickups, They will funnel oil, long before the other designs.
Old 06-19-2012, 06:43 PM   #19
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
thanks for the quick reply, i plan to swap both in the future. I've never head of failures of the 2.0L pickup but more from the lack of pickup from the 2.0L pans when oil sloshes around.
Old 06-19-2012, 06:47 PM   #20
WRick
Member#: 86107
I'm pretty sure the engine sharted on mine because of this.
I had a 2.0 pan with the double baffles. Brand new engine, freshly built.
WRick is offline   Reply With Quote
Old 06-19-2012, 06:49 PM   #21
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The older 2.0 pickups fail just like the newer ones. The oldest model we've had experience with was from a 1997. Oil slosh isn't a concern on the street, and on track it's fairly rare for a typical street car, but certainly more prevalent than with the 2.5 pan design.
What is the intended use for this car? That will make pan selection a lot easier here.
Old 06-19-2012, 07:38 PM   #22
danger1138
Member#: 279525
04 rex luger!
So most likely no slosh issues on 2.0 pan if not pushed to limits on track?
Old 06-19-2012, 07:55 PM   #23
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
mine is typically on the street but plan to do more strip again.
Maybe i'm missing the reports of the 2.0L pickup failures on the board, i thought its rare. However aware and witnessed blown 2.0L motors both USDM/JDM blocks due to high g situations, i.e. roadcourse, donuts.
As far as the 2.5L pickups failures, i do know of them cracking where they are brazed.
Old 06-19-2012, 08:00 PM   #24
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
any final asessment from your builder the actual cause yet?
Old 06-19-2012, 09:30 PM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It depends on the track a lot too, but the OEM 2.0 pan is a good street pan. I personally wouldn't run a 2.0 pan with any seriousness on a road coarse, it's just not worth the risk.
Strip as in straight line?
The 2.0 pickup failures are harder to dig up. Remember, most of the forums where this data is very easy to find, were in thier infancy ~10 years ago. You need to dig a bit far and wide. Specifically where the WRX existed 10 years before they were available here in the US, where there was a good enthusiast following too (Europe, Australia, etc...).
Details on why the pickups fail can be found IN THIS LINK.
and pictures of broken pickups HERE.
WTB: Built Sblock or Lblock 2.0 or 2.5 Marlons101 Private 'Wanted' Classifieds 10 06-18-2009 06:23 PM
wtb 2.0 or 2.5 block or full motor addiction AKIC Private Classifieds 8 03-22-2009 04:18 PM
Looking for either 2.0 or 2.5 short block... serious Private 'Wanted' Classifieds 1 12-02-2004 05:20 PM
Need a pic of a 2.0 or 2.5 DOHC cylinder head 2003 sedan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-30-2004 10:36 PM
2.0 or 2.5? Nuclear3000GT Newbies & FAQs 3 11-26-2004 10:41 PM
