Old 06-19-2012, 10:02 PM   #1
AkumaMotorsports
Member#: 214570
Default Akuma Motorsports: New Time Attack..STI
We are in the process of building a new shop sponsored STI. We have a laundry list of things to finish, but here are most of the mods thus far...
Here is a mod list so far...
Suspension:
KW Racecomp T2's with custom valving
Swift springs (600)
Vorschlag camber plates
Cusco rear trailing arms
Cusco rear lateral arms
GTSpec rear Toe arms
Whiteline front and rear sway bars
Whiteline ball joint extenders and bump steer kit
Custom Powerflex bushings (motorsports durometer)
Cobb rear end links
Rota Boost 2 18 x 10....BFG R1 275 35 18.......This is a temporary tire
selection for the rest of this season.
Cosworth Pectel SQ6 ECU, Akuma(John) tuned....with an array of data logging goodies.
Brakes:
AP Racing 6-piston front brakes (350mm)
AP Racing 4-piston rear brakes(325mm)
AP Racing lines
Ferrodo pads.........Swapping to CL Racing RC6
Motul RB600F fluid
Brake cooling system
Engine:
Cosworth Long block (9.2:1 compression, big valve heads, forged pistons and rods)
Cosworth Intake manifold
Cosworth fuel rails
Cosworth TGV deletes
Cosworth dry sump
Flex Lite lines
Killer B equal length headers
Akuma Hybrid Up Pipe
AEM 5-bar map sensor
AEM Intake air temp sensor
Akuma Rotated Turbo Down Pipe
Akuma Rotated Turbo Intercooler Pipe Kit with ETS core
Tial Q BOV
Tial EWG(25PSI)
AKuma Cold Air 3.5" Intake
Tial BOV
3076/Tial 82
Greddy Ti-C Catback
FIC 1100 injectors
ATL Fuel cell in custom cage
Patterson dry sump oil tank
Bosch 044 fuel pump
Custom fuel lines from the fuel cell to fuel rails
Aeromotive fuel pressure regulator
Fuel Lab fuel filters (2)
Setrab 625 oil cooler
Custom -10AN lines for the oil cooler
Koyo radiator with Evans Cool Fluid
Carbonetic twin disc clutch
Carbonetic rear Differential
Driveshaft shop carbon drive shaft
Motul 300v oil(ester based synth...awesome stuff)
Interior:
AiM MXL Pista dash and data logger...May use the Pectel/Cosworth Omega dash
Sparco Evo 2 seat Recaro Profi driver
Schroth 6-point harnesses
Fire suppression system
Piper Motorsports built roll cage
Aero
Custom front splitter... aluminum diversion panel to lower the front lip without sacrificing suspension travel
Flat bottom Panels (Driver and passenger runners)
Rear Diffuser is in the works
Aeromotions wing....however it will not go on until the chassis
is balanced/dialed in as is. I want to use the wing to help the aero, not
cover up a potential deficiency
More to follow, and thanks for all of the support!!
Cheers,
John
Here are a few teaser pics...more to follow tomorrow.
AkumaMotorsports is offline   Reply With Quote
Old 06-19-2012, 10:17 PM   #2
gizmotron2030
Member#: 145183
2011 BMW M3
Subscribed
gizmotron2030 is offline   Reply With Quote
Old 06-19-2012, 10:27 PM   #3
Bones702
Member#: 205115
06 Sti Dom4.0XTR
Dom 3.0 and rotated 3076? Typo?
Bones702 is online now   Reply With Quote
Old 06-19-2012, 10:28 PM   #4
ALEXTHESUSPECT
Member#: 319168
beast mode coming soon!
ALEXTHESUSPECT is offline   Reply With Quote
Old 06-19-2012, 11:00 PM   #5
AkumaMotorsports
Member#: 214570
Fixed.
Old 06-20-2012, 12:04 AM   #6
jamal
Member#: 71875
98 2.5GT
my wheels fit
What class and events are you planning on doing?
jamal is offline   Reply With Quote
Old 06-20-2012, 01:05 PM   #7
AkumaMotorsports
Member#: 214570
Hey Guys I got Some Teaser Pics To Hold You Guys Over For The Finial Product
Old 06-20-2012, 01:10 PM   #8
xbeamelite
Member#: 281250
2007 STi Ltd
UGM
Kevin, you wasted no time posting pics.
Saw this in person today. BEAST.
xbeamelite is offline   Reply With Quote
Old 06-20-2012, 02:07 PM   #9
AkumaMotorsports
Member#: 214570
Haha Thanks! Were on top of it.
Here are some more teasers
Custom Pulleys Strait From Europe
..... the Dry Sump tank will be mounted vertically...this is just a pic to show the parts.
Old 06-20-2012, 02:08 PM   #10
AkumaMotorsports
Member#: 214570
oops... I will get another pic here in a bit.
Old 06-20-2012, 02:08 PM   #11
AkumaMotorsports
Member#: 214570
Old 06-20-2012, 03:19 PM   #12
PCSkiBum_21
Member#: 164437
EVO IX - Track Car
2.5RS Coupe - Daily
this is going to be sick, subscribed. is this a gr hatch or sedan?
PCSkiBum_21 is offline   Reply With Quote
Old 06-20-2012, 04:16 PM   #13
AkumaMotorsports
Member#: 214570
Hatch!
Old 06-21-2012, 02:49 AM   #14
mpj_becks
Member#: 6265
What events are you going to run it in?
Congrats on the build it looks great!
mpj_becks is offline   Reply With Quote
Old 06-21-2012, 10:58 AM   #15
slowguy
Member#: 4326
2010 turdle
very nice!! cant wait to see this in action. TRM MT1 wheels? 18x9.5?
slowguy is offline   Reply With Quote
Old 06-21-2012, 11:22 AM   #16
Rokkit
Member#: 84181
NASA #530 PTC
All that stuff and you couldn't throw down the extra coin for JRZ's? Racecomp has the hookup
Rokkit is offline   Reply With Quote
Old 06-21-2012, 11:49 AM   #17
JPotter
Member#: 92604
05 WRX STi
CGM
How did you get custom valving on the Racecomp T2s?????
When I spoke with Myles in Dec/Jan. looking to get custom valving on mine - he said they don't rebuild them and KW no longer offers re-valve/rebuild service on T2s. They'll only rebuild them if they broke under warranty and he said my only option was to get JRZs or wait for 'another option' in the works.
So....... how'd you get them?
JPotter is offline   Reply With Quote
Old 06-21-2012, 02:45 PM   #18
AkumaMotorsports
Member#: 214570
In all honesty, the owner had them before we started. I can find out when I talk to him.
I like the JRZ, but the owner had these already. We will run them with the Swifts and then see where we run out of adjustment. If we need to make the change, we can do that later.
I was trying to finish the sheetmetal work and turbo kit this week, but with this heat it may not happen. We were trying to make it in time to shoot it for DSport. We will have to see how far we get by the end of the week.
John
Old 06-21-2012, 03:15 PM   #19
mpj_becks
Member#: 6265
What series are you going to run this in John?
Old 06-21-2012, 03:25 PM   #20
haberkorn
Member#: 97732
2004 STi
65 Nova 9.46@142
Hope that dry sump tank ends up vertical and not laying down flat when it's done.
haberkorn is offline   Reply With Quote
Old 06-21-2012, 03:29 PM   #21
AkumaMotorsports
Member#: 214570
Originally Posted by haberkorn View Post
Hope that dry sump tank ends up verticle..not laying down when it's done. Even though it's not our pump..that's definitely our tank heh
Wow. If I put the tank horizontally...we should not be building this car.
We will be running with EMRA, NASA, and SCDA for testing/tuning. Since we are pretty well into the season, I am only running time trials with Real Time Attack and EMRA. I don't recall the class off the top of my head. Unlimited with Real Time Attack though.
John
Old 06-21-2012, 03:30 PM   #22
alcoolaid
Member#: 134949
'07 SWP STi
Twinscroll ViPec Anti-lag
Are those off the shelf ap racing brakes?
alcoolaid is offline   Reply With Quote
Old 06-21-2012, 04:25 PM   #23
RallyLegacy
Member#: 114353
1997 White Legacy
2007 SWP STI
I'm a little curious on why only a 3076 for an "unlimited" time attack build. Upgrading in the future once the car is all sorted or are you squeezing into a power/weight class with one of the sanctioning bodies?
RallyLegacy is offline   Reply With Quote
Old 06-21-2012, 04:34 PM   #24
haberkorn
Member#: 97732
2004 STi
65 Nova 9.46@142
John
Glad you know...you have no idea how many tech calls I get asking 'Why do I have oil pressure fluctuations, my tanks laying flat! I get about 3 - 4 a month.
If you guys have any questions or need any parts for the dry sump let me know. I work at Peterson Fluid Systems.
Old 06-21-2012, 04:45 PM   #25
AkumaMotorsports
Member#: 214570
I want to keep a balance between spool and overall power. This car will make well over 500HP which should be more than ample for the weight. I find the 35R to be a little big with the gearing in the 6 speed. At this time we are staying stock on the trans, so this should work well. Should have about a 4500-4800 RPM power band.(3500RPM - 8000 roughly)
Thanks.
Left over goodies from Akuma time attack STi (JRZ, Bride, Cosworth, ACPT etc!) AkumaMotorsports Vendor 'General Sale' Forum 19 02-15-2011 05:20 PM
GOTO:Racing's new Time Attack racecar B Esquire Motorsports 55 09-29-2009 11:07 PM
WTT: NEW Time Attack Rota P1s 18X8 5x100 gingertooth Tri-State Area Private Classifieds 29 10-25-2008 06:19 PM
Crawford Performance's new Time Attack car dyno video modaddict Motorsports 45 02-01-2008 08:50 PM
Building Time Attack STi...Stock STi parts FS! dentsport NESIC Vendor Classifieds 35 07-17-2006 11:33 AM
Message Board Statistics All times are GMT -4. The time now is 11:08 PM.
