Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 06-19-2012, 10:50 PM   #1
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
This is an analysis of the factory fill at 2800 miles after a hard break-in. The oil was never topped off.
Element Actual PPM / Typical PPM
Aluminum 1/2
Chromium 1/1
Iron 29/7
Copper 154/5
Lead 1/5
Tin 2/1
Molybdenum 828/53
Nickel 1/0
Manganese 20/4
Silver 0/0
Titanium 0/0
Potassium 4/1
Boron 138/44
Silicon 330/10
Sodium 8/15
Calcium 1929/2187
Magnesium 12/266
Phosphorus 850/771
Zinc 792/937
Barium 6/0
Flashpoint 410F
Fuel <0.5%
Antifreeze 0
Water 0
Insolubles 0.2%
SUS Viscosity @ 210F: 48.8
cSt Viscosity @ 100C: 6.89
Comments: High wear and silicon are common finds in new engines such as yours. The excess wear is due to new parts wearing in, while silicon is from sand-casted parts and sealers used when assembling your engine. With a few more oil changes, everything should read around if not better than, universal average levels. Those averages are based on an oil run of around 4200 miles. The viscosity was in the 5W20 range with no fuel or coolant present. No abnormal finds.
Commander Keen is offline   Reply With Quote
Old 06-19-2012, 10:55 PM   #2
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Thankyou Commander Keen, I guess waiting till 7500 isnt a good idea
Im currently running Break in additive at around 3500
Interesting the Zinc levels are a little lower than average and Moly is way high
This is a Zinc additive website stating a few facts about engine breakin with modern oils.
#5 Redline oil and others are suggesting a 3,000-mile break-in for new engines! Proper seating of rings, with today’s lubricants is taking that long to properly seal. Shifting to synthetics before that time will just burn a lot of oil and not run as well as hoped.
For you science buffs: ZDDP is a single polar molecule that is attracted to Iron based metals. The one polar end tends to “Stand” the molecule up on the metal surface that it is bonded to by heat and friction. This forms a sacrificial layer to protect the base metal of the cam and tappet from contacting each other. Only at very high pressures on a flat tappet cam is this necessary because the oil is squeezed/wiped from the surface. This high pressure is also present on the gudgeon pin (wrist pin) in diesel engines, therefore the need for ZDDP in diesel engines.
Second part of the equation is Molybdenum disulfide (Moly). The moly bonds to the zinc adding an additional, very slippery, sacrificial layer to the metal. I found out that too much of the moly will create problems; lack of this material reduces the effectiveness of the ZDDP. The percentage, by weight is from .01 to .02%, not much, but necessary.
auskip07 is offline   Reply With Quote
Old 06-19-2012, 11:15 PM   #3
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Interesting. Thanks for posting your oil analysis. I plan to have mine analyzed after my third of fourth oil change and the engine is fully broken in.
jr0bb5 is offline   Reply With Quote
Old 06-20-2012, 10:37 AM   #4
79letour
Member#: 302570
2013 XV
DGM!
I definitely need one of these tests.
79letour is offline   Reply With Quote
Old 06-20-2012, 06:01 PM   #5
John451
Member#: 321966
2012 Impreza + XV 14
Black Pearl + White XV
A mate went though a high oil usage issue with his BMW K1300S motorbike where he was using 600ml per 600miles of the specified Full Synthetic, after trying to resolve many times with the dealer for not being " fit for purpose " as a Sports Tourer he was quietly advised by the dealers mechanic to try it with Semi Synth but if he did it would void warranty.
John451 is offline   Reply With Quote
Old 06-20-2012, 07:00 PM   #6
TObject
Member#: 320185
2012 Impreza 2.0i
Zink can lower the efficiency of the catalytic converter; higher levels of Moly can make the remaining Zink more beneficial. From what I understand, Moly is relatively harmless for catalytic converters; so seeing more of it is not surprising.
Thank you for sharing the analysis.
TObject is offline   Reply With Quote
Old 06-20-2012, 08:20 PM   #7
finklejag
Member#: 318622
2012 Impreza
Thanks for the UOA. Can you post the viscosity. That's a nice shot of moly. Honda also uses high moly in their factory fill.
finklejag is offline   Reply With Quote
Old 06-20-2012, 08:27 PM   #8
Commander Keen
Member#: 319157
Updated with viscosity.
Old 06-21-2012, 08:05 AM   #9
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
OK, so my interpretation of this is:
  • We should follow the break-in process (no cruise control; no exceeding 4k RPM; etc.) for 3k miles, not the 1k miles stated in the owner's manual.
  • We should perform the first oil change at 3k miles, not at the 7500 miles stated in the owner's manual.
  • When changing the oil at 3k miles, at that point we can begin using the recommended synthetic oil.
Does that sound about right?
sgoldste01 is offline   Reply With Quote
Old 06-21-2012, 08:18 AM   #10
79letour
Member#: 302570
2013 XV
DGM!
The car COMES with synthetic.
Old 06-21-2012, 08:59 AM   #11
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Agreed, but according to the UOA details listed above, the factory oil is 5w20, not the 0w20 specified by Subaru.
Old 06-21-2012, 09:02 AM   #12
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
My maintenance manual says 3k oil change is the first. Not sure if this is dealer recommended or Subaru.
Ladeef is offline   Reply With Quote
Old 06-21-2012, 09:09 AM   #13
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I think it's dealer recommended (and I agree with this recommendation). I believe the owner's manual says you can wait until 7500 miles.
Old 06-21-2012, 09:15 AM   #14
Commander Keen
Member#: 319157
The viscosity was only tested hot, so it could be anythingW20.
Old 06-21-2012, 09:28 AM   #15
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
Satin White Pearl
It is unlikely any harm will come if you go over 4k RPM for brief periods as long as the engine is fully warmed up, and may even be better for break-in according to some.
According to the manual, oil change at 3k miles is not required for the 2.0 engine, it is required at 7.5k miles, and synthetic oil is required. 0w20 is not even necessarily required, but advised for maximum efficiency.
Haunty is offline   Reply With Quote
Old 06-21-2012, 09:33 AM   #16
Angelus911
Member#: 89967
2012 Impreza Sport
I think the majority of people suggest changing the oil at 3000 miles just because it could have a positive impact on the life of the engine. If you spend $20k+ on a car, quibbling over a $60 oil change isn't really worth it. Better to be safe than sorry I guess
Angelus911 is offline   Reply With Quote
Old 06-21-2012, 09:35 AM   #17
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I'm getting my Impreza tomorrow, so I don't have the owner's manual to reference yet.
What other weights of oil are allowable other than 0w20?
Old 06-21-2012, 09:45 AM   #18
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Agreed 100%. And I'll do my own oil change, so it should be less than $60 if I find a good price on the filter and synthetic oil.
I assume that as long as I don't decide on Amsoil products, I can get everything at Autozone, right?
Old 06-21-2012, 10:02 AM   #19
Haunty
Member#: 319378
Satin White Pearl
Not sure, but manual says 5w20 is okay to substitute temporarily.
Edit: Actually the manual says 5w30 or 5w40 is OK for "replenishment" and 0W20 is "required for optimum engine performance and protection"
A lot of people have been getting the 5qt Mobil1 oil at Walmart cause it is the cheapest. I got some Peak oil at shopthedude.com, and an OEM filter 3 pack and crush washers on ebay (Somerset Subaru). Comes to about $43 per change for me. Would be even cheaper with the Walmart oil.
Old 06-21-2012, 10:07 AM   #20
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I'm sure the Mobil1 would be fine. I'm a big fan of Castrol oils too.
Old 06-21-2012, 10:18 AM   #21
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
OK, and just to confirm, the part number of the correct filter is 15208AA160, right?
Old 06-21-2012, 10:33 AM   #22
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yup, Walmart is selling the 5-qt jug of Mobil1 0-20 full synthetic for $26.50. On eBay, it looks like I can get the Subaru-branded filters for approximately $7.50 each, if I buy a 3-pack (and $6.67 if I buy a 6-pack). So it looks to me like I can do my own oil change for under $40, and know that I put in the right quantity of the right product.
It looks like the non-Subaru oil filters sold at Autozone are similar in price to real Subaru filters from eBay, so I'd just stick with the Subaru filters. I don't know who OEMs the filters to Subaru.
Still deciding between a Fumoto valve and top-side oil extraction. Would only go with the valve if I could reach it without jacking the car or driving up on ramps.
Old 06-21-2012, 10:34 AM   #23
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Im a Castrol guy so thats what i have used in all my vehicles. Also adding a break in additive to the engine during the first 10k wouldnt be a bad idea. Beef up the zinc and possibly help the engine seat the rings sooner.
Old 06-21-2012, 10:40 AM   #24
Commander Keen
Member#: 319157
Is it possible that the zinc drops out of the oil as it is deposited on to the engine?
Old 06-21-2012, 10:48 AM   #25
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
The metal is porus (to a certain extent) im sure the zinc plays a part in smoothing everything out. Even the cylinder walls. it might take a few oil changes to get the correct amount of zinc deposited in the engine.
The oil analysis thread (blackstone, etc). Nimbus09 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 01-22-2010 07:52 PM
0W-30 Oil Analysis richeich Newbies & FAQs 9 10-29-2000 07:36 PM
