Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 06-20-2012, 02:19 AM   #1
peyton331
Member#: 289688
Default Subaru WRX STI minor paint correction
Process used:
Wash
Clay
IPA wipedown
Black Meg's pad with Menzerna SF4000
Ipa wipedown
Menzerna Powerlock sealant
Chemical Guys 50/50 paste wax
Dress all rubber
scrub the wheels
clean the engine bay
Took about 8 hours, stock Subaru paint is really soft so it corrected (slightly, thus the minor correction) with the black pad.
Forgot to take a lot of pictures, sorry!
peyton331 is offline   Reply With Quote
Old 06-20-2012, 02:20 AM   #2
peyton331
Member#: 289688
Space was a bit cramped so the after shots don't do much justice
Old 06-20-2012, 02:20 AM   #3
peyton331
Member#: 289688
Old 06-21-2012, 02:38 AM   #4
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
vf39 ewg tuned ppg gears
Looks good! But isnt the black pad mostly used with waxes and sealants? I use an orange pad on all the cars i've worked on which is 3. ( beginner right here )
dumpstercrusher is offline   Reply With Quote
Old 06-21-2012, 03:33 AM   #5
peyton331
Member#: 289688
Nope, its for finishing (polishing)
Sealants have their own pads, and i dont wax by machine so I have never even looked into that.
Thanks!
Old 06-22-2012, 01:01 PM   #6
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
yea I've only waxed once with machine, but I enjoy waxing by hand. hmm, I thought the blue was for more of a finishing. Mine was all labeled when I bought mine, thats why.
Old 06-22-2012, 05:29 PM   #7
Tripperfx3
Member#: 242966
2005 WRX
Rally blue
Thats pretty impressive that you did all that with a black pad and from the looks of it it seems like you did it W/O a DA or orbital polisher? I've done two black Subarus (an STi and WRX) and had to use Menz Intensive polish and nano polish with an orange cutting and white polishing pad respectively, so if I'm reading correctly and you did this by hand that is very impressive.
Tripperfx3 is offline   Reply With Quote
Old 06-23-2012, 08:43 AM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....what I he said is that he doesn't apply LSP's (waxes/sealants) via machine. Although he didn't specify, Im assuming he used one for his correction steps though.
Kean is offline   Reply With Quote
Old 06-23-2012, 08:49 AM   #9
Kean
Member#: 25187
'08 Foz Prem TGM
If we're talking LC pads, orange is for cutting and black would be more for finishing. However, LC has a lot of pads they offer in between these and some are going to be quite similar. ....similar enough that I real only use orange, white and sometimes black depending on what Im trying to accomplish. ....I also have a couple of finer pads (like red) for LSP application but like the OP, I prefer to apply those mostly by hand.
Old 06-25-2012, 12:23 PM   #10
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
what about the yellow pad? Got that pad too and used it once on a car, but I stuck with the orange because it seemed to get the swirl out better.
Old 06-25-2012, 12:38 PM   #11
builthatch
Member#: 185105
2009 C63 AMG
Palladium Silver
yellow pad is for very aggressive defect removal. considering the technology available with products like optimum's hyper spray compound, the yellow pad is not necessary at this stage for anything other than the initial stages of, say, headlight correction or if you are dealing with an area on particularly hard paint. ideally on paint i don't use anything more aggro than orange pads at this point. but yellow pads will remove wetsand marks in paint rather easily using a DA - it's a rough pad!
OP, for the nooks and crannies of the engine bay, actually pretty much any area in the bay, some 3:1 to 10:1 optimum power clean and boar's hair brushes do wonders. once you give it a good initial cleaning you can upkeep it with a no rinse solution spray followed by plain water trigger spraydowns.
builthatch is offline   Reply With Quote
Old 06-25-2012, 09:32 PM   #12
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
Okay so u mentioned u could use the yellow for the headlights, got a polish you can use in combination for headlight restoration? Excluding the sanding part. Might as well buy individual supplies instead of buying a kit even though the pad for the kit be smaller
Old 06-25-2012, 09:41 PM   #13
builthatch
Member#: 185105
2009 C63 AMG
Palladium Silver
honestly i don't even sand anymore. for the worst lights i use the yellow 4" lake country CCS pads and optimum hyper spray compound, then i usually go to a flat 4" orange pad and the same spray and work it for a while, wipe off and check my work then a white or green flat 4" pad and optimum polish. then i wipe down with isopropyl alcohol solution (20% total) and turn the lights on to make sure i got everything out to my satisfaction. if so, i put optimum opti-coat 2.0 on there - it's a permanent resin coating. you need to take care to TOTALLY wipe down with isopropyl alcohol solution before hand and make sure you don't over apply the opti-coat but if you follow the normal directions you should be a-ok. it'll prevent the headlights from getting messed up again.
Old 06-26-2012, 02:37 AM   #14
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
Oh okay I'm gonna have to give that a try. thanks!
FS/FT : NC: 2004 Subaru WRX Sedan Custom Paint Job $9,000 FIRM LukeMann Private Vehicle 'For Sale' Classifieds 50 07-12-2012 12:24 PM
FS : CT: 2004 Subaru WRX/STI Body Clone, Just painted.. Not running $10K 98SubbyLeg Private Vehicle 'For Sale' Classifieds 11 06-15-2011 03:11 AM
FS: Artic White Alpine 03 Subaru WRX with minor mods Hybridizer Private Vehicle 'For Sale' Classifieds 2 12-28-2005 06:26 PM
