Old 06-20-2012, 08:07 PM   #1
Scooby_Vu
Member#: 215212
2005 AW STi
05OBPSTi&05CGMSTi (SOLD)
Default 05 STi Datalog help?
Hi, I just recently flahsed my 05 STi to stage 2 using cobbs AP. I was hoping to get some feed back on my data log since it seems like it's leaning towards a lot of knock. I did post this on Cobb Forums but it's not as active as NASIOC.
05 STi
Invidia TBE (catless)
Cobb stage 2 LWG LC
shell 91 gas
Rotella t6
Note: before I flashed to stage 2 I had a compression and leakdown test. The car came out with approximately 140psi across the board with 5% on the leakdown test.
https://docs.google.com/spreadsheet/...3NsMVJmU2Zsc2c
Scooby_Vu is offline   Reply With Quote
Old 06-20-2012, 11:50 PM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
You seem to have a lot of fine knock learning. I would strongly suggest you get a wideband and use accesstuner race, or take your car to a tuner and get it fixed.
Your MAF g/sec is also pathetically low for a stage 2 STi. You have a problem somewhere... And a serious one.
Black94Snake is offline   Reply With Quote
Old 06-21-2012, 12:12 AM   #3
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
I'd start by going back to a stage 1, 91 octane map and see what that does. If you still have the same problems go back to a stock map and see what happens. Post up logs
gotsugg is offline   Reply With Quote
Old 06-21-2012, 12:59 AM   #4
Scooby_Vu
Member#: 215212
2005 AW STi
I have a road trip back to California and this behavior is freaking me out. I'll go back to stock as soon as possible or a protune. I'll keep y'all posted.
Old 06-21-2012, 02:23 AM   #5
HelloMrBrahms
Member#: 320094
07 sti
UGM
try using the stg 2 91 acn map?
HelloMrBrahms is offline   Reply With Quote
Old 06-21-2012, 10:03 AM   #6
Cobb Tuning
Member#: 4803
05 STi
Cobb stage 2 LWG LC
shell 91 gas
Rotella t6
Your log is typical of a car with a bad MAF sensor. Being an older car, with low reported airflow, and extreme knock at higher RPM could mean you are running lean (with too much timing advance due to the load error) because of a bad MAF. Although you will usually see extreme positive A/F Learning 1 values with a bad MAF, you may have not have driven long enough since the install (or last map reflash) for those to populate accurately.
Because it is so critical to engine operation, I would just go ahead and replace the MAF sensor with a new one. Reflash the 91ACN map (our most conservative map) after you replace the sensor. If you do not have time to replace the sensor before your trip, then at least flash the 91ACN map and do not do any heavy throttle runs.
Bill
Old 06-21-2012, 05:29 PM   #7
Scooby_Vu
Member#: 215212
2005 AW STi
Thanks for the advice. It looks like I wont be able to get it tuned before my trip since my tuner is backed up until July. Looks like I'll flash it to 91acn before my trip.
Old 06-21-2012, 05:39 PM   #8
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Why don't you just flash the economy map and keep from blowing your car up.
Really Need Help 05 Sti Please Help alexkondor Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 02-01-2010 05:57 PM
08 sti motor in 05 sti need help! sleepysubie Subaru Conversions 19 09-29-2008 09:49 AM
Le28Ns on 05 STI need help please WRXTwiztid Tire & Wheel 7 02-01-2005 01:02 PM
aftermarket exhaust for my 05 STI - help me decide nkkilla Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 60 01-10-2005 02:04 AM
04 or 05 sti please help me decide... CXspeed General Community 14 05-25-2004 07:27 PM
