Old 06-20-2012, 08:32 PM   #1
chenzonies
Member#: 214145
06 WRX
Charcoal
Default Help me ID this crud on my wheels
Rota sub zeros, each wheel has an accumulation on the lip near the spokes. I'm assuming they are clear coated since the spokes are painted.
Is this the clear coat coming off, or should this stuff be removable?
chenzonies is offline   Reply With Quote
Old 06-21-2012, 02:42 AM   #2
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
vf39 ewg tuned ppg gears
what is that?? Ever try using a clar bar just to see if it takes it off? I've also heard of people sanding down the lip part of the rim and repolishing to a bright finish
dumpstercrusher is offline   Reply With Quote
Old 06-21-2012, 09:58 AM   #3
AspenScoob255
Member#: 217405
2006 WRX
Do you have any metal polish? If so, rub some into a small area as if to polish it. If the polish begins to turn black the lip is uncoated.
It looks like corrosion/oxidation and may need to be sanded down as dumpster stated or heavily polished. Report back once you find out if its coated or not and we can proceed from there.
AspenScoob255 is offline   Reply With Quote
Old 06-21-2012, 03:36 PM   #4
Drowner
Member#: 49297
14 Focus ST3
Oxidation, there is no cure, have to refinish the lips.
Drowner is offline   Reply With Quote
Old 06-29-2012, 04:22 PM   #5
BlueScoob10
Member#: 324273
2010 WRX STI
WR Blue Mica
Could just be some stuck on dirt or a stain of some sort. Kind of looks like a little oxidation and in the case that it is you'd probably have to refinish.
BlueScoob10 is offline   Reply With Quote
Old 06-29-2012, 06:03 PM   #6
shocker47
Member#: 284171
2007 Wrx "race-car"
Black Pearl
Try some mothers polish.. and a cloth should take it off. If not then try to sand it with some 800 grit then some 1500 grit followed by mothers. Should take it off.
shocker47 is offline   Reply With Quote
Old 07-24-2012, 12:21 PM   #7
chenzonies
Member#: 214145
06 WRX
Charcoal
tried some metal polish, nothing came off on the rag so it looks like they are clear coated. I think i'll try wet sanding and compound, if that doesnt get it looks like ill be refinishing at some point
Went to KingKing on sat, can you help me ID this track? Sil80sx Off-Topic 5 06-13-2011 01:56 PM
OT: Help me ID this song gongzero Off-Topic 30 11-17-2006 07:00 PM
OT, please help me ID this bird cRayZee Off-Topic 23 06-05-2006 02:22 PM
Help me ID this Song, OT! Sharkbait Off-Topic 12 07-23-2004 10:14 AM
ARGH! Help me ID this song based on one line of lyrics that I probably got all wrong! AC Lerok Off-Topic 14 03-01-2004 07:05 PM
