Old 06-20-2012, 08:51 PM   #1
BRich37
Member#: 271263
Default WRX/STI engine swap??
I currently have an 06 impreza 2.5i with only 50xxxx miles. I want to upgrade to either a wrx or sti, so my question is... Would it be worth the money to get an WRX/STI engine swap into my current car, or just sell what i have and use the money to buy a WRX/STI??? Let me know what you think...
BRich37 is offline   Reply With Quote
Old 06-20-2012, 08:52 PM   #2
Psychoreo
Member#: 79643
04 EJ207 Swapped
Mikey tuned 271whp/287wtq
Sell current.
Buy Wrx or sti.
Psychoreo is offline   Reply With Quote
Old 06-20-2012, 09:00 PM   #3
JJ527
Member#: 312462
2004 WRX
sell it
JJ527 is online now   Reply With Quote
Old 06-21-2012, 01:24 PM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
If you want to go the WRX/STi route, then you have some options to consider:
How much money do you want to spend? Do you want to spend it all at once or would it be better to do it as-you-go?
Do you want to buy something more turn-key, or do you want to work on your car yourself?
Even if you buy a used WRX/STi, you still have to consider that you are unaware of what may be wrong with the car you buy, so you may have to fix a little or a lot of things.
If you get the WRX/STi, it will come with suspension changes not available on your current car, BUT you can modify your suspension with upgrades to be WRX/STi-like.
Get the idea?
Samurai Jack is offline   Reply With Quote
Old 06-21-2012, 05:50 PM   #5
WRX2EVOX
Member#: 203011
02 Impreza WRX
Flat Black Viny Wrap
Buy a salvaged STI donor car for approx 4-6k or a WRX for 2-3k and swap everything over, check out copart.com. Why buy another 25k+ car, unless u want it to be turn key and don't want the down time associated with swapping everything over. But if u don't mind getting dirty and spending the time doing the swap it can be cost effective.
WRX2EVOX is offline   Reply With Quote
Old 06-21-2012, 07:14 PM   #6
Psychoreo
Member#: 79643
04 EJ207 Swapped
4-6k usually gets you either the engine, or the transmission......
Old 06-23-2012, 12:01 PM   #7
WRX2EVOX
Member#: 203011
02 Impreza WRX
Ya of u buy them piece by piece. Check out Copart.com u can get a whole car for that much
Old 06-23-2012, 12:44 PM   #8
Web Foot STi
Member#: 39086
2004 STi
This is one of those questions that if you have to ask...
Just jack up the radiator cap on your 2.5i and drive a WRX, or STi underneath.
Web Foot STi is offline   Reply With Quote
FS : 2008 USDM SUBARU IMPREZA WRX STi ENGINE SWAP (EJ257) - Toronto, ON piecyk Engine/Power/Exhaust 6 10-16-2011 10:59 PM
WRX/STI engine swap??!?!??! CUbaru07 Subaru Conversions 6 02-21-2008 08:25 AM
Need an WRX/STI engine swap. codemunky Bay Area Impreza Club Forum -- BAIC 1 09-16-2006 02:44 AM
Hmmm...mostly stock STi, modded WRX or engine swapped GC? DoinkMobb General Community 25 04-07-2005 02:15 PM
wrx/sti engine swap to 1999 impreza L (2.2 MT) Qaveboy Factory 2.0L Turbo Powertrain 1 01-10-2003 06:10 PM
Message Board Statistics All times are GMT -4. The time now is 09:08 PM.
