Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 06-23-2012, 03:20 AM   #1
Member#: 323097
Default 96 brighton motor swap options
I am new to the forum so forgive my ignorance. I recently purchased a 1996 Impreza brighton 2 door as a project car. The car is going to be completely stripped an caged. I'm wondering what would my best option for reliable turbo power. I am looking for something in the 300 hp range. I am in CA so smog is going to be an issue but I plan on keeping the 1.8 and swapping out for smog. Again, please forgive me if is has been asked, I couldn't find too much when I searched the forum. Any advice would be greatly appreciated.
Sb1187 is offline   Reply With Quote
Old 06-26-2012, 03:16 AM   #2
Member#: 111046
1996 STiL wagon
2002 MBP bugeye
i have a 96 L wagon that i did a full swap on that would probably be able to pass emissions in cali.
i swapped in the entire dash/interior/chassis harness from a 98 2.5 rs and used the stock rs ecu with a greddy emanage blue to run a v4 sti ej20k.
the car puts down 240/217 @18 psi and runs on 91, no cels and it passed the obdII test and visual inspection in nevada.
the only downside is the rs ecu has a rev limit of 6500 while the 20k can rev to 7800, so its slightly detuned to compensate. im working on a harness that will allow me to use the jdm ecu 99% of the time and just swap out the rs ecu for smog.
route69wrx is offline   Reply With Quote
911 motor swap Skrane General Community 45 07-13-2012 02:51 PM
Clutch options for 97 wrx ra engine & 96 brighton 5 spd 2slofouru Transmission (AT/MT) & Driveline 9 02-12-2008 11:37 AM
Motor swap options 92XJET Mid Atlantic Impreza Club -- MAIC 11 08-09-2007 10:14 AM
Motor swap options. Kraziken Legacy Forum 5 07-19-2005 05:56 PM
96 impreza brighton engine swap tb_189 Normally Aspirated Powertrain 6 03-24-2002 04:13 AM
