Old 06-23-2012, 09:04 PM   #1
platinumstar17
Member#: 159756
1998 wrx sti
white [email protected]
Default oil light flashing after engine swap
i have a jdm v3 wrx and the engine went bad it was a ek20k. i swapped out the engine for a v5 sti ej207 engine. after installing the engine and started it up the oil light on the dash was flashing and the car had a misfire.
what could be the cause of this?
platinumstar17 is offline   Reply With Quote
Old 06-23-2012, 10:54 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
if it is not an erroneous wiring issue, your shortblock is now garbage. the switch is 2.1psi.
eg33GC is offline   Reply With Quote
Old 06-26-2012, 07:25 AM   #3
platinumstar17
Member#: 159756
1998 wrx sti
got the problem sorted
1999 Forester A/T Oil Temp light flashing after fluid change slideways suby Transmission (AT/MT) & Driveline 2 12-16-2011 10:05 PM
AT oil temp flashes after starter replace hondadude32 Legacy Forum 4 08-27-2009 01:45 PM
is it common to lose oil after engine swap? bnr34rb26dett Newbies & FAQs 9 02-23-2009 04:55 PM
gas light flashing after fuel pump intalled... BBBsti LTD Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 12-12-2007 02:32 AM
Dash Lights flashing after clutch swap? Swiffer Car Audio, Video & Security 1 11-11-2007 05:58 PM
