Old 08-29-2002, 03:46 PM   #1
blkwag
Member#: 4838
2002 WRX Wagon
Black in Recovery...
Default HELP! White Smoke Problem...Experts needed
I just installed a '98 2.2L motor that replaced my '93 1.8L.
I'm still using my 1.8 ECU but I have the entire 2.2L hooked up, including injectors. It started just fine but there is huge white smoke coming from the tailpipe.
Just wondering if all the shaking of the engine and laying it down on different sides while transporting it could've made the oil/coolant go to different parts of the engine and these remains are what's burning off.
Other possibilities:
blown head gasket (unlikely since the motor had 25k miles and came from a wrecked car hit in the rear ) Also, I didn't fill the engine/radiator with coolant yet, just water added.
2.2L injectors running from 1.8L ecu (if it were running rich, wouldn't there be greyish smoke coming out?)
I plan on doing a compression test. Never did one on a Suby but don't you just have to pull the connector on the coil so it doesn't start?
Thanks for any help.
blkwag is offline   Reply With Quote
Old 08-29-2002, 04:57 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
what does the smoke smell like?
is it thick?, or like condensation you would see in the winter time?
is the water level going down?
i would let it run and monitor the fluids and see if the smoke disapates.
Jay
Old 08-29-2002, 07:03 PM   #3
blkwag
Member#: 4838
2002 WRX Wagon
Yup, I let it run some more and the smoking has subsided. It smokes only on occasion when I rev it and that's probably due to rich fuel mixture from using the 1.8 ecu.
There probably was some fluids in the engine that got everywhere during transport.
Runs pretty good considering the 1.8 ecu.
Old 08-29-2002, 07:07 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I think you should hang a white towel in front of the tail pipe and let the car run for a minute. Then turn the car off and inspect the towel.
Old 08-29-2002, 08:12 PM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
the 1.8 ECU really shouldn't matter. It should take readings from all the sensors and adjust the mixture accordingly.
Blue/white smoke is usually oil
black smoke is usually too much fuel
steam is coolant/water.
The towel trick sounds like a good idea
Legacy777 is offline   Reply With Quote
Old 08-29-2002, 09:31 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
it could have just been condensation in the exhaust...how is the weather near you?
Jay
Old 08-30-2002, 02:48 AM   #7
blkwag
Member#: 4838
2002 WRX Wagon
Thanks all but it seems to be running fine now. I think it was just a buildup in the engine/exhaust.
Old 08-30-2002, 02:57 AM   #8
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
When I changed the heads on my Cougar some water got into the exhaust pipes. When I first started the car it was blowing TONS of white smoke (like a fog screen) out the back but after about 5 miles it all went away. It happens
Eric
Eric SS is offline   Reply With Quote
White smoke problem DigitalPunk Built Motor Discussion 10 08-26-2009 10:04 AM
93 Subaru Impreza White Smoke Problem!!! Nitsuji Service & Maintenance 1 04-06-2007 02:01 PM
help! white smoke!! please! RIRENTER Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-31-2006 01:37 PM
Help!!! White smoke after resinstallation of stock injectors calib17a Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-24-2005 02:54 AM
White smoke problem eaalto Normally Aspirated Powertrain 2 08-28-2002 11:11 AM
