Old 06-24-2012, 09:13 PM   #1
amroof
Member#: 211224
2005 Saabaru
Who knows
Default "usdm 32 bit ecu running jdm V9 engine, in 2005 fxt"
Hey guys so i finally got to a stopping point of my swap that to many people said it was impossible. So i took the challenge with and with the motivation for a few friends and a little over the phone conversation from a very helpful company i did the swap.
I have a full 32 bit jdm v9 in my 2005 fxt. full swap as in 5x114 hubs, sti struts on jdm pink springs,
full rear r180 cradle and aluminum lateral links
jdm v9 6 speed
vf37 ts turbo
ect
Will i started this swap because i had the motor sitting in the back yard as we where trying to sell it and i wanted something only a handfull of people have ever attempted in a 32 bit car. so i jumped at the challenge and went for the big jdm awesomeness!
pictures of how she looks.
and for anyone looking to do this swap it takes a lot of patience and willing to do things no one should.
out with the old
jdm awesomeness with new belts and pulleys
moded mani
with the mani done this way i can now run it properly mounted a full 180 degrees rotated. WITH OUT IT LEAKING!!
on the above setup i drove around with factory sti mani and tgv deletes and parallel fuel rails for 2000 miles before i got the mani installed today.
amroof is offline   Reply With Quote
Old 06-24-2012, 09:16 PM   #2
amroof
Member#: 211224
2005 Saabaru
Who knows
the new setup with the mani installed
mani assembled
tb cleaned up
installed
Old 06-24-2012, 09:19 PM   #3
amroof
Member#: 211224
2005 Saabaru
Who knows
and the engine ports and engine stamp so people will believe.
and pics of the fozzy
Old 06-24-2012, 09:29 PM   #4
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
The 32bit ECU has no issues running this motor when properly setup for all those who will say it can't. I know because I tuned it and have driven it. Hauls Ballz!
Great looking Grandma mobile Alex! Pry safe to assume it is the only one in the country!
lukeskywrx is offline   Reply With Quote
Old 06-24-2012, 10:29 PM   #5
amroof
Member#: 211224
2005 Saabaru
Who knows
to bad not very many people believe it! i love my fxt and this is how it should have come from the factory.
and thanks dude.
Old 06-25-2012, 08:38 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
just to clarify
a 2005 32bit ecu from a 05 forester xt
2009 ej20 from a ver 9
using a 255/257 throttle body and manifold
is the intake avcs working?
assuming the exhaust avcs is not
Old 06-25-2012, 09:12 PM   #7
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
[quote=Jaxx;37460022]just to clarify
Wondering if it's running a jdm ecu?
666stars is offline   Reply With Quote
Old 06-25-2012, 09:42 PM   #8
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Jaxx- THere is no exhaust AVCS on the v9, just intake and yes its working
666stars - it is running the forester ECU, like I said above
Here is an initial test log to make sure things were safe, Please note:
IAM is 1 as on a 32 bit ECU
RPM hits 8200, not something you want to do on the 2.5L very often
AVCS is at 40 peak, the 2.5L cam gears physically will not do more than 30
and dear lord look at all that delicious timing on the top end!
Old 06-26-2012, 12:15 AM   #9
amroof
Member#: 211224
2005 Saabaru
Who knows
as luke said above. this v9 engine is running on a usdm 05 fxt 32 bit ecu! im running the full jdm engine minus a few little changes made to get the engine to run on the 32 bit ecu. but it runs amazing and made a 1000 mile trip to mexico and back last weekend flawlessly.
Old 07-06-2012, 01:52 PM   #10
amroof
Member#: 211224
2005 Saabaru
Who knows
Currently at 4500 miles already and have switched back and forth from 91 oct to e85. Got about 24 mpg on the freeway cruising at 85 at 4000 rpm ( jdm trans FTMFW!) always in boost.
Old 07-07-2012, 05:49 AM   #11
666stars
Member#: 221364
[posted by amroof]666stars - it is running the forester ECU, like I said above
Actually since the title is "running 32 bit jdm V9" and not "usdm 32 bit ecu running jdm V9 engine".
Old 07-07-2012, 03:42 PM   #12
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Dude thats amazing congrats!!!!
rexworx is offline   Reply With Quote
Old 07-08-2012, 02:17 AM   #13
amroof
Member#: 211224
2005 Saabaru
Who knows
666stars. Took your recommendation and ran with it.
And thanks rexwrox
Old 07-08-2012, 07:00 AM   #14
Erik
Member#: 168774
Thats not going to work but ok.
Erik is offline   Reply With Quote
Old 07-08-2012, 07:11 PM   #15
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
For a car that is not supposed to run due to an impossible swap it really does drive well.
Old 07-09-2012, 11:14 AM   #16
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
So, I am not totally up to speed on all the version 7/8/9 differences, can you explain why is this such an accomplishment to get the JDM V9 engine running on a 32 bit USDM ecu? Did you take the JDM rom images and put them on the forester ECU?
What was the purpose of rotating the DBW TB?
congrats on the swap, looks good.
Ben
Old 07-09-2012, 02:17 PM   #17
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
interesting.. i heard that it's not impossible.. just people don't do it. i have a setup that if i may go back to the states.. i'll strip down my gc8 with a V8 STI Spec C motor and either set it up in a 2005 STI or a 2005 WRX.
thanks for posting this.
old_duwel is offline   Reply With Quote
Old 07-09-2012, 03:48 PM   #18
amroof
Member#: 211224
2005 Saabaru
Who knows
It's an accomplishment cause no one does it cause you have to machine parts of heads to accept
32 bit cam sensors. This were things get different. The v9 engine is run on a 16 bit ecu or dumber ecu in some sense, so I had to get my ecu to work with the dumber setup. So I converted to Usdm cams and Usdm cam sensors. This allows me to run my factory wiring on an engine that was never setup for the 32 but ecu. And it different cause I went from a 257 to a 207 and its badass.
Now for the tunning part it is an opensource tune that is amazing and was done by a hood friend ( lukeskywrx)
I rotated the dbw tb because the inlet for the turbo was to close for my liking. And that mani was originally setup as a dbc mani
Thanks for the comments and ill answer what ever questions you guys have.
Old 07-09-2012, 07:49 PM   #19
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
awesome job! have any pics of the heads where they have to be milled for sensors?
Also looking forward to Ken finishing up his swap... tell him to hurry his ass up!
fastnoypi is offline   Reply With Quote
Old 07-09-2012, 10:20 PM   #20
jam007
Member#: 174706
2008 LGT-B
Nice Fozzy!
jam007 is offline   Reply With Quote
Old 07-10-2012, 10:56 AM   #21
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
I think he is still scrubbing down the longblock with a toothbrush so it matches the rest of his wagon.
I have his rom all ready to go so it will be a turnkey swap, whenever it eventually happens.
Old 07-11-2012, 02:19 AM   #22
amroof
Member#: 211224
2005 Saabaru
Who knows
i think its more like a singe wire wire brush!!
Old 07-11-2012, 07:57 AM   #23
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Ben
I was watching this and the only progress I can come up with is that when you go for state inspection with a 32bit car, you need to have a correct ECU, if the state expects it.
This is why the guy in Cali that did this first with a shop did it.
Other than this, when you buy an engine they already give you it's ECU.
Other than this, like it's stated, the cams get less AVCS with the USDM setup.
Also, this does not cover the whole USDM GDB, I don't think, because the Canbus began before '08, to my knowledge.
Old 07-11-2012, 08:36 AM   #24
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Old 07-11-2012, 10:53 AM   #25
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
The whole point of this is that the stock 32bit ECU is still in charge and driving the JDM motor. Forester ECU-JDM motor. So any WRX or STI from 2002-2007 can do a JDM motor swap, the 16bit cars run the JDM ECU and the 32bit cars keep their standard ECU without having to do a harness swap. As far as the ECU knows it is still a forester and the immobilizer system is still intact.
We are getting full AVCS advance (40 BTDC) using the JDM camgears with the 32bit ecu since the AVCS limit on USDM cars is a physical limit not an ECU limit.
Canbus started in 08 so this does cover the entire GDB series.
Differences between JDM V9 STI, JDM V9 Spec-A/B/C, & JDM V8 Spec-C (Heads)??? nomorem3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-06-2013 08:57 PM
64 Bit OS vs 32 Bit OS MarcsRX Off-Topic 53 08-07-2009 02:17 PM
FS/MN: Sealed Windows Vista Ultimate - Full Version: 32 bit/64 bit! WRXEcho Non-Subaru Stuff 1 12-03-2008 12:41 AM
What version of Vista should I run 32 bit vs 64 bit? Jsunn Off-Topic 14 05-08-2007 10:44 PM
Another VMWare Server question: 64 bit host or 32 bit host OS? -=C=- Off-Topic 31 04-16-2007 07:07 PM
