Old 12-03-2012, 06:59 PM   #26
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
and ya dont need the 4 pot calipers.....just do the h6 rears with good fluid, ss lines and good pads...add a mc brace and
Old 12-03-2012, 08:40 PM   #27
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
Omgz!! I can't imagine why the 06/07 WRX guys aren't trading in their 4/2 pot setup a for the 2 pot sliders and H6 upgrade!?!? Don't they know what they are missing!?
gsrcrxsi is offline   Reply With Quote
Old 12-03-2012, 08:58 PM   #28
jarencibia
Member#: 187021
2004 WRX Sedan
Centric stop tech pads are cheap and don't take much to get up to temp. You just need to heat them up every once in awhile to get a good initial bite since they glaze over in the boring daily commute. I'm able to easily initiate the abs with them at any reasonable speed. I'm running the stock front/ lgt h6 rear currently
jarencibia is offline   Reply With Quote
Old 12-03-2012, 09:11 PM   #29
sc00by4life
Member#: 97135
you realize that the braking distance actually increased from 02-05 to the 06-07's according to pretty much every independent review of the vehicles?
123ft vs 115ft for 60-0.
Old 12-03-2012, 10:02 PM   #30
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Braking distance isn't everything
What's the weight difference between the 04/05 and 06/07?
On average, the 06/07 is 125lbs heavier.
What's the difference in wheels?
04/05 uses a 16.5lb 16x6.5" wheel
06/07 uses a 21lb 17x7" wheel
ie more rotational inertia in the 06/07 wheel
What's the difference in tires?
04/05 used 205/55/16 RE2s
06/07 used 215/45/17 RE2s
A meager increase.
Think about these things before throwing out numbers to try and discount the 4/2 pot setup
Old 12-04-2012, 01:29 AM   #31
Uncle Scotty
Member#: 16200
OK buy Nates beans
A meager increase.
d0000000000000000000000000000000000000d
there is NO magic to the 4pot/2pot setup OTEHR THAN the 290mm rear discs
THAT is IT
id rather have the brakes the way i had them on my 02 than my 06....WAY better when i was done with them
and i didnt have the 2pots in back
stop blowin smoke up yer own ass...it aint workin
Old 12-04-2012, 09:10 AM   #32
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Then why aren't you swapping out the 4/2 pots? Lol. You're a hypocrite. You fellate the 2 pot slider setup and bash the 4 pots, yet you continue to run the 4/2 pots. If you TRULY felt this strongly about it you'd be swapping them out for the "better" setup.
But you don't. You just think it's kiddie k000 to say things like "kiddie k000" and "d0000d" and "yer".
Fact is, I posted factual data compiled from cars101.com and the stickies here that more than likely makes up for the 8ft difference between the years. This makes you angry. Cue Internet tough guy mode lol. Go back to pushing stop tech pads, tranny oil mixes, and federal tires.
Old 12-04-2012, 09:24 AM   #33
vicious_fishes
Member#: 158864
2003 SOHC destroker
considering the 4pots are weaker than the 2pot sliding caliper, then even with the H6 rear there is still some bias improvement to be had.
TIC tell me that even with a full stoptech system up front you're still not going to overheat the VENTED rears first.
i feel a solid disk would be a much different story.
vicious_fishes is offline   Reply With Quote
Old 12-04-2012, 10:40 AM   #34
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by NordiX View Post
But whenever I've searched around for technical advice Scotty does seem to be one of the forum gurus that tends to have solid knowledge of all things Suby...
I'm amazed you were able to find posts in which he showed that knowledge rather than ranting about who knows what.
But I have a hard time believing that all I need to do is swap to StopTechs and my 2/1 pots are going to suddenly become amazing... so I feel that the 4/2 pot question is still open for more discussion.
I think there is little (if anything at all) to be gained by going with the 2-pot rears. I do think the 4-pots are a useful upgrade.
[Dude,] there is NO magic to the 4pot/2pot setup OTEHR [OTHER] THAN the 290mm rear discs[.] THAT is IT[.] id [I'd] rather have the brakes the way i[ I] had them on my 02 than my 06....WAY better when i[ I] was done with them[.] [A]nd i[ I] didnt have the 2pots in back[.]
I have H6 rears on my car. When I went from '02-05 WRX fronts to 4-pot fronts, I stopped having brake fade issues at track events. Same fluid, same pads, same rotors. If anything I'm harder on the brakes now than I was before. And I haven't even bothered to install my RCE cooling ducts at the last few track events because I don't need them anymore. It's almost like there is more to braking performance than just raw brake torque.
But yes, the 4-pots are a weaker, inferior system.
Well said.
Old 12-04-2012, 10:22 PM   #35
jarencibia
Member#: 187021
2004 WRX Sedan
How's front/rear bias with 4pot front and h6 rear?
Old 12-05-2012, 12:32 AM   #36
Uncle Scotty
Member#: 16200
OK buy Nates beans
Well said.
you blithering blundering boob
I HAD THE 4POTS ON MY 02 WRX and they are NOT what made the brakes better
the 290mm rear rotors ARE WHAT MADE THE BRAKES BETTER
and your track usage of another kind of car is irrelevant to what we are discussing here, cupcake
YOU dont drive or own ANY WRX of any sort....so get out of this thread
and stop trying to **** me in the ass here....it aint working
Old 12-05-2012, 12:39 AM   #37
Uncle Scotty
Member#: 16200
OK buy Nates beans
it makes it THE WAY IT IS SUPPOSED TO BE
the us market got mismatched brake parts from good old fhi on the 2.0 cars.....NO other market got the garbage brakes WE got
EVERY other market got the 294mm/290mm rotors
the calipers are irrelevant
this has been posted here many times with all the calculations done for you already
the CALIPERS are IRRELEVANT TO ALL OF THIS, really....they do FAR less than pad compounds do to any of the 'numbers'
the rotor size is NOT irrelevant
Old 12-05-2012, 12:42 AM   #38
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Old 12-05-2012, 12:45 AM   #39
Uncle Scotty
Member#: 16200
OK buy Nates beans
stupid ****ing children
Old 12-05-2012, 02:55 AM   #40
jarencibia
Member#: 187021
2004 WRX Sedan
Scotty relax doooooooood
@Patrick
I already run the h6 rear and stock front calipers. I'm interested in the brake bias
change caused by the difference in caliper piston area between the front 2 pots and front 4 pots. Do you see any significant difference between the stock / 4pot calipers with h6 rear setup while late braking into turns?
Old 12-05-2012, 05:41 AM   #41
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
You're mad because Pat helps people without resorting to excessive use of caps lock and the number zero.
Counterfit is offline   Reply With Quote
Old 12-05-2012, 06:24 AM   #42
vicious_fishes
Member#: 158864
2003 SOHC destroker
@Patrick
there won't be SFA. it's an improvement, but a miniscule one. not worth doing.
as scotty said, it's the 290mm rear that makes the real difference, though i wouldn't be surprised to see the solid disk overheat pretty quickly.
your next upgrade is rear 2pots with stoptech or brembo rears and LGT fronts. (or at least some ducting to the 294mm fronts).
how do i change brakepads on 4/2 pot brakes from 06? jojotherider Brakes, Steering & Suspension 6 02-03-2012 02:02 PM
WTB : OR: 04' STi steering rack, 06-07 4/2 pots, and ETC!!! Cash ready st165turbos Private 'Wanted' Classifieds 1 03-11-2011 10:04 AM
4/2 pot upgrade on 2000 Legacy Cervantes Legacy Forum 4 02-05-2011 07:55 PM
FS or TRADE: rear STi Brembo's w/ DBA rotors and upgraded pads for stock WRX 4/2 pots thebusiness999 Suspension/Brakes/Handling 7 01-22-2007 06:28 PM
Question on STI 2.5 and WRX Heads wRxbeater11 Subaru Conversions 4 10-04-2004 11:31 PM
