Old 06-25-2012, 12:39 AM   #1
MRF22
Member#: 210516
2005 Sti
AW
Default Paint blemesh
Have a white 05 sti and on the front bumper is some paint smear where the previous owner rubbed against a black car. What can I use to get it off? Will a heavy cut work?
Thanks!
MRF22 is offline   Reply With Quote
Old 06-25-2012, 08:26 AM   #2
XERO287
Member#: 253541
2011 WRX 5DR Premium
I'd use a very high grit sandpaper and wet sand it. Start with 3000, if that doesn't work go to 2500, etc. You'll definitely have to polish it after though.
XERO287 is offline   Reply With Quote
Old 06-25-2012, 09:29 AM   #3
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
Normally a heavy compound will work just fine. If not, wet sand with some 2000.
MattTHEpainter is offline   Reply With Quote
Old 06-25-2012, 04:53 PM   #4
MRF22
Member#: 210516
2005 Sti
AW
Ok thank you! Can you recommend a heavy compound?
Old 06-25-2012, 04:53 PM   #5
MRF22
Member#: 210516
2005 Sti
AW
Thanks!
Old 06-25-2012, 05:01 PM   #6
XERO287
Member#: 253541
Try Meguiar's M105 or Menzerna SI 1500
Old 06-26-2012, 02:41 AM   #7
07STifastashell
Member#: 291793
2007 STi Dom built
*sold*
If that doesn't work...Menzerna Power Gloss compound. But you do realize that you will have to go to less and less abrasive compounds after polishing with such an abrasive compound like Menzerna PG to prevent swirl marks and other imperfections. The finish just comes out much better if you go from Menzerna PG to SI (super intensive) to SF (super finish), all with the proper pads of course. And don't forget to use paint sealant and wax after. Like someone said before...you could wet sand as well which is really fast. In that case, you would wet sand, but then you would still need to polish and follow the procedure I previously outlined. Hope that helps!
07STifastashell is offline   Reply With Quote
Old 06-28-2012, 02:39 AM   #8
dunncsu
Member#: 279873
Wow you guys dont screw around first step of heavy cut? damn!
While the heavy cut polishes mentioned above will for sure work im not a fan of going to heavy cut first thing. I like to start with a less aggressive combo before i break out the big guns.
A few years back i was driving my wifes car a car in front of me lost his bumper and we hit it. Left a lot of paint transfer on the bumper.
Here is the product i used with a few MF by hand no polishers.
before picture
product
After
dunncsu is offline   Reply With Quote
Old 06-28-2012, 07:33 AM   #9
XERO287
Member#: 253541
^^^This, which is why I recommended starting with a 3000 grit sandpaper since that usually takes all traded paint off immediately; that, followed with a lower cut polish such as the one pictured.
It's hilarious, I see other cars with traded paint on them and wonder, do they like having someone's paint on their car or do they think it's expensive to remove? XD
Old 06-28-2012, 08:43 PM   #10
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
I would just start with a wash, clay bar, then a finishing polish. It should be enough to remove most surface paint transfer.
pho_shizzle is offline   Reply With Quote
Old 06-28-2012, 09:17 PM   #11
DerrickRH
Member#: 75078
2000 Legacy GT
Black Granite Pearl
you'd be a brave soul to take sandpaper to that "thick" subaru paint.
DerrickRH is offline   Reply With Quote
Old 06-28-2012, 10:29 PM   #12
XERO287
Member#: 253541
^Nahhhh. lol
Old 06-28-2012, 10:37 PM   #13
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
All day, it's not as bad as everyone says.
Old 06-28-2012, 10:59 PM   #14
XERO287
Member#: 253541
^Right, I've been doing it for a while now on a bunch of Subarus and other cars.
Old 06-29-2012, 02:50 AM   #15
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
Its not whether you have been doing it for a while or not.. but rather if the situation calls for that level of aggressiveness or not.
Old 06-29-2012, 09:40 AM   #16
MRF22
Member#: 210516
2005 Sti
AW
Already tried this.
Old 07-02-2012, 05:48 PM   #17
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
Then try the next step polish. Several passes.
Old 07-06-2012, 08:50 PM   #18
MRF22
Member#: 210516
2005 Sti
AW
Thanks for all the advice. I tried the Meguires but it didn't work. Ended up having to wet sand. Thanks again.
Painting WRB STi splitters SRR with paint code-matched spray paint? 05shagginwagon Interior & Exterior Modification 5 07-28-2010 03:09 PM
I'm going to paint a bumper- is adhesive paint promoter and paint all I need? scobaru Interior & Exterior Modification 6 04-04-2007 10:40 PM
Paint, paint, paint! Schludwiller Legacy Forum 5 01-12-2003 06:53 PM
A touchup paint or spray paint? whtstr Interior & Exterior Modification 3 06-27-2001 09:42 PM
Debate: To Paint or Not to Paint STi Sev General Forum Archive 8 05-18-2000 12:06 AM
