Old 06-25-2012, 01:20 AM   #1
geddesk2
Member#: 119397
98rs 06sti
RBP & WRB...BLUE!
Default Need new calipers for 06 2.5i...4 pots?
Hey all,
Caliper on my wifes 06 legacy has a leaky seal and a nasty vibration when braking. The car has close to 100k on it so I'm thinking its time to just do a full brake job...pads/rotors/calipers.
I was looking on subarugenuineparts and they carry the whole 4 pot and 2 pot setup, but I can't tell if they would be a straight bolt on for my wifes car?
She has 07 wrx wheels on it currently so no wory about wheel clearance.
I've been searching on here, legacygt, and scoobymods and am still not seeing any good threads, if you can help me out it would be appreciated!
geddesk2 is offline   Reply With Quote
Old 06-25-2012, 08:53 AM   #2
octain11
Member#: 298800
I know a couple of guys used the wrx 4 pots on 1st and 2nd gen legacy, and sti brembo's on 3rd gen (but w. sti axles) check sl-i.net has a bunch on the 07 4 pots, these should work on a 4th gen
octain11 is offline   Reply With Quote
Old 06-25-2012, 01:58 PM   #3
geddesk2
Member#: 119397
98rs 06sti
RBP & WRB...BLUE!
Thanks I spent a few hours searching that site and I still can't find a thread with a clear answer.
Based on my reading the 4 pot fronts sound like they will bolt up, but I can't get a confirmation on the rear 2 pots.
Old 06-26-2012, 12:40 PM   #4
geddesk2
Member#: 119397
98rs 06sti
RBP & WRB...BLUE!
Bump!
Old 06-26-2012, 12:50 PM   #5
geddesk2
Member#: 119397
98rs 06sti
RBP & WRB...BLUE!
These are what I want to order...will these be a straight bolt on?
http://www.subarugenuineparts.com/pr...50748b2f9196c4
Old 06-26-2012, 04:52 PM   #6
octain11
Member#: 298800
they will bolt on, but they are not too great. they are all show no stopping power at all, if you want a nice upgrade i would get the same year LGT calipers, those are much better than the wrx ones
Old 06-27-2012, 12:02 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
There are an awful lot of people who would disagree with octain11's assessment that the 4-pots are not an upgrade. Having track tested mine on multiple occasions there's no doubt in my mind that the 4-pots are an upgrade over the stockers. I haven't even bothered to hook up my RCE brake cooling ducts for the last few events I've been to because I no longer need them.
The '05+ 2.5GT brakes might be even better, but they're also heavier, probably overkill on a 2.5i, don't look as purty, and I believe require you to run 17s (so if you've got a 16" winter setup you're SOL).
Pat Olsen
Old 06-27-2012, 07:43 AM   #8
octain11
Member#: 298800
never said the 4 pots are nt an upgrade, for a LGT they are a down grade, but for a 2.5i it will be an upgrade, but why spend more money where you can get the LGT ones for cheaper and will perform better, this is coming from 4th gen owners who have told me they did not see good results with the wrx 4 pots,
Old 06-27-2012, 11:03 AM   #9
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
As I mentioned on LGT.com, these [i]are[i] a big upgrade over the stock 4th gen 2.5i brakes. Substantial increase in braking force, and just as important as Patrick mentioned, cooling. Upgrade the pads and you'll upgrade the bite and the heat-fade resistance. And no upgrade to your MC/BB required.
Subietonic is offline   Reply With Quote
Old 06-27-2012, 12:13 PM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
You're right, you never said they weren't an upgrade, you just said "they are not too great. [T]hey are all show no stopping power at all..."
So you've never tried them yourself? And why would a 4th gen Legacy react any differently to the upgrade that has worked on every previous generation?
suggestions for 06 2.5i new tires jphillis89 Tire & Wheel 4 12-29-2008 07:55 PM
any new CAI for 06 2.5i gloves Normally Aspirated Powertrain 1 09-16-2006 07:51 PM
suspension for 06 2.5i (rs) vinzie27 Brakes, Steering & Suspension 5 07-10-2006 11:10 AM
F+R LSD upgrade for 06 2.5i? dl337j00 Transmission (AT/MT) & Driveline 2 05-22-2006 01:10 PM
springs for 06 2.5i a1killer Brakes, Steering & Suspension 2 04-26-2006 10:17 PM
