Old 06-13-2012, 12:44 PM   #1
BMXspears
Member#: 79339
2002 EJ257 swap WRX
Midnight Black
Default Steering rack compatibilty
I have an 02 WRX with worn steering rack bushings. I have a complete 06 Sti steering rack including crossmember laying around. I would rather put in this rack than just replace bushings. What compatibility issues will I run into trying to install it?
BMXspears is offline   Reply With Quote
Old 06-17-2012, 10:02 PM   #2
BMXspears
Member#: 79339
2002 EJ257 swap WRX
Midnight Black
I installed this Saturday morning, so I figured I should reply to my thread.
Everything bolted right up, I even had the STI universal joint and threw that on as well.
Used the factory service manual instructions. Took about 3 hours using a lift and air tools.
Tip: Reaching PS lines is a pain. Part of my process included unbolting the front control arm pivot on both sides. Once I had the cross member disconnected I let it hang on the semi-loose control arms giving me lots of room to remove the PS lines and reattach the new ones.
Old 06-25-2012, 01:53 PM   #3
whitt
Member#: 8928
0216 02 WRX & 16 WRX
White & Lapis Blue
Might be a good Idea to use some shorty wrenches next time if you drop the cross member the alignment should be done after, but it is easy to measure the steering arms end to end and duplicate the distance to keep the alignment close enough to not need a new one. Anyway good job.
Whitt
Garage Tuning
whitt is offline   Reply With Quote
WTB: 04 STI Steering Rack or 02-04 WRX Steering Rack zee lee NWIC Private Classifieds 15 10-03-2008 04:12 AM
WTB: 04 STI Steering Rack or 02-04 WRX Steering Rack zee lee Private 'Wanted' Classifieds 7 04-01-2008 04:34 PM
[WTB] Front Lower bar Steering Rack Rod, Steering Rack Gaskets... Zak Shaker Private 'Wanted' Classifieds 0 02-12-2008 07:10 AM
WTB: WRX steering rack or 04 STI rack. 02-03STI hoodscoop STI steering, 04 gold BBS's Davenow Private 'Wanted' Classifieds 3 05-01-2007 06:52 PM
Difference between 96 impreza L steering rack and 02 wrx steering rack? petawabit Brakes, Steering & Suspension 4 02-02-2005 10:36 AM
