Old 06-25-2012, 04:51 PM   #1
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
Default Helo /w AC leak?
Hi Guys. I've got an AC leak. It wasn't hard to figure out where it was coming from. I heard hissing and saw some bubbles.
I'm trying to decide to do a DIY fix or have a shop do it. Any advice?
Here is a pic of where it is leaking from:
monovich is offline   Reply With Quote
Old 06-25-2012, 06:03 PM   #2
candyredfish
Member#: 323959
02 WRX
Sedona Red Pearl
I just did a DIY kit today, seems to be working good so far. But I also didnt have a huge leak like yours, maybe clean it up and try some JB Weld?
candyredfish is offline   Reply With Quote
Old 06-25-2012, 06:34 PM   #3
Immoreradthanu
Member#: 311559
Duct tape!!!! Fixes everything
Immoreradthanu is offline   Reply With Quote
Old 06-26-2012, 02:34 AM   #4
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
What was your fix? I've got a leak in TE line that runs down the frame of the passenger side and am having trouble in ding a solution that doesn't cost an arm and a leg.
pilfflip is offline   Reply With Quote
Old 06-26-2012, 12:42 PM   #5
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Frogsthatmoo is offline   Reply With Quote
Old 06-26-2012, 03:19 PM   #6
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
Thanks Frog! I will try that. Looks exactly like my problem.$1. Woot!
Old 07-05-2012, 07:44 PM   #7
dvancleve
Member#: 5211
2007 Outback XT Ltd.
Diamond Gray Metallic
Lightbulb
FWIW, I just got the AC repaired in my '97 Legacy Outback and the two seals at the compressor were the issue. One step I would add to the repair procedure is go rent a vaccuum pump and gauge manifold from Autozone and pump down the system after you replace the seals. This sucks out all the moist air and the new refrigerant should go in a lot faster... Doug
dvancleve is offline   Reply With Quote
Old 07-05-2012, 08:01 PM   #8
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
Yeah I think I got it re sealed with the one o ring at the compressor. It it only blows cool, not cold. Is this maybe a moisture issue?
Old 07-05-2012, 08:11 PM   #9
dvancleve
Member#: 5211
So you replaced the leaking seal then put in some refrigerant? It should take about 26oz. of R134, so a biggish can and a smaller one. Under or overfilling can lead to cool but not cold. I would try getting more in, unless you think it might be over filled. I believe most of the R134 with additives has a drying agent included. Problem is that you really shouldn't vent the refrigerant to atmosphere, it is bad news...
Doug
Old 07-05-2012, 08:47 PM   #10
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
Maybe I have too much in. The PSI indicator on the filler reads into the high yellow or low red. I used a huge can from Autozone. Maybe some should come out...
AC Leak Problem gigabytexbc Newbies & FAQs 9 07-15-2010 01:03 PM
AC leak question gtfaded Service & Maintenance 5 03-17-2008 01:06 PM
Found my AC leak, help on how to fix it!!!! Ryandc Service & Maintenance 5 09-25-2006 09:41 AM
AC leak .. at firewall? mordy_2v Service & Maintenance 0 08-08-2005 10:29 PM
weird oil leak/AC leak? NateDogg Service & Maintenance 2 05-03-2004 04:23 PM
