Old 07-07-2012, 04:36 PM   #51
ovielito
Member#: 209200
^^^ thank you I just tried contacting him. I'm in search of a 9 second beast myself
ovielito is offline   Reply With Quote
Old 07-07-2012, 06:32 PM   #52
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by juanmedina
Fuji are you guys doing anything to the crank to rev that high? how about on the oiling side? what oil pump?
I am getting crower valve springs and retainers and rev to the moon
Balanced crank, pistons, rods, flywheel/pressure plate, crank pulley. Shimmed/ported oil pump with external oil cooler. Change oil often to keep fresh!
FuJi K is online now   Reply With Quote
Old 07-12-2012, 12:01 AM   #53
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Wow havent been on in awhile here just seen this! CONGRATS!!!
The bullet!
TDagen is offline   Reply With Quote
Old 07-12-2012, 01:39 PM   #54
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
this I want, did I see like 9300rpm there to 3rd? whats the need for a destroked sti, when you can do the same with an sti? nice!
is the power curve any earlier with a 2.34? Is reving to this with a 2.5 any more unreliable then the desroked sti?
I ask because I thought smaller motors like 205/207 or ej22 were the only subies going that high. Before recently an sti going to 75-7800 was the max I've heard of, now its 85-9300, crazy stuff
Irv Weissmanhowerton is offline   Reply With Quote
Old 07-12-2012, 02:14 PM   #55
Nuke209
Member#: 108089
2003 WRX
NF Performance
I went to amazon and ordered a pair of titanium balls. Set rev to 9k and went wot!
Nuke209 is offline   Reply With Quote
Old 07-13-2012, 10:12 AM   #56
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
LOL! How much were they? I might need a set
Old 07-14-2012, 09:49 AM   #57
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
the 2.5L will have an earlier power curve than a 2.34L destroker on this same setup. i can't say if revving the 2.5L is more unreliable or not because the car is still running. last year with the Borg Warner 88/75 we revved it to 8500rpms. It's still on the same engine with this Precision 6766 with a few fancy parts like the NA intake mani.
Old 07-17-2012, 09:09 PM   #58
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
So how many miles so far on the engine? On my old engine I reved by mistake to 10k a couple of times from miss shifting from 3th to 2nd and rev to 7.5K all the time with a regular 10mm pump and that one lasted 60k miles .
Old 07-18-2012, 11:45 AM   #59
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
we were about 7k miles last year end of summer with the Borg Warner, right now we are almost 10k. The 6766 turbo went on not too long ago. We are probably near if not over 1k miles since then.
Old 07-19-2012, 12:15 PM   #60
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by Paul
Did u put this car on the scales recently? It's a very good ET for the trap if the car isnt super light.
Great job!!!
I'll try to get it on the scale soon because i am curious as well.
Old 07-19-2012, 12:19 PM   #61
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
You should have driven onto the scale at the MAP event!
xluben is offline   Reply With Quote
Old 07-20-2012, 12:21 AM   #62
EdekitRex
Member#: 317410
2011 STi Hatch
Dark Grey
such a fun car to watch at the track, glad I was there to witness!
EdekitRex is offline   Reply With Quote
Old 07-23-2012, 10:55 AM   #63
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Nice new gears, I just seen that!
What headstuds did you go with?
Old 07-23-2012, 11:25 AM   #64
Nuke209
Member#: 108089
2003 WRX
NF Performance
On this setup?
Standard ARPs
Old 07-23-2012, 11:38 AM   #65
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
On this setup?
Standard ARPs
Wow I can't believe they are holding still. No coolant pushing?
Old 07-23-2012, 11:52 AM   #66
juanmedina
Member#: 133146
+12345
Do you guys try running more boost? On what boost do you guys dd it at?
Old 07-23-2012, 12:23 PM   #67
Nuke209
Member#: 108089
2003 WRX
NF Performance
+12345
Its about 34.5 psi right now. And thats daily. Only difference between his dd map and drag map is the launch control settings. Other than that. Same ****
No coolant pushing
Old 07-23-2012, 01:00 PM   #68
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Crazy!!
This car is mean.
Old 07-23-2012, 02:06 PM   #69
ByeBye4g63t
Member#: 290896
2004 STi, FOR SALE
Very impressive with such a simple motor setup.
ByeBye4g63t is offline   Reply With Quote
Old 07-23-2012, 03:18 PM   #70
vangstaboi86
Member#: 119945
2004 sti
java black pearl
vangstaboi86 is offline   Reply With Quote
Old 07-24-2012, 12:28 PM   #71
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
When does it hit fullboost in 3rd gear?
Old 07-24-2012, 12:47 PM   #72
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
3rd gear ratio of this gear set is in between 3rd/4th of the '04 gear set.
around 4500 peak boost? Nuke will have to look at the logs.
As long as you're about 5000rpms or more, get ready and hold on!
Old 07-24-2012, 12:55 PM   #73
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Yeah I am just wondering because that's a big ass turbo!
Is the 3rd gear different from my 07 STi 3rd?
Old 07-24-2012, 01:01 PM   #74
juanmedina
Member#: 133146
peak boost at 4500rpm from a 93lb/min turbo?
Old 07-24-2012, 03:25 PM   #75
Nuke209
Member#: 108089
2003 WRX
NF Performance
His 1-4 is same as yours. Longer and better ratio 5-6
Depends on iat and headers if cooled down or not. 20psi at 4k. Can hit peak boost around 4.5k
NF Performance's Speeding Bullet STi - 10.63 @ 133mph Nuke209 Proven Power Bragging 50 05-01-2012 10:17 AM
NF Performance's Project Katana STi 11.6 @ 119mph MAP 20g msp05sti Proven Power Bragging 12 10-13-2011 10:27 AM
NF Performance's Project Katana STi 11.6 @ 119mph MAP 20g Nuke209 Proven Power Bragging 17 10-11-2011 12:54 PM
FS/FT : 2005 Sti 6 Speed, 3.9 r180, sti shaft, exedy twin disk, FULL dccd bugisti Drivetrain 30 12-27-2010 12:50 PM
FS : NEW MY96 AWD 5 speed transmission(3.9 final drive) PHATsuby Drivetrain 5 10-15-2010 12:49 AM
