#1 |
Member#: 291739
Vehicle:99 Impreza RS Silver Milage |
Hey guys I need pics of a late EJ20G throttle body. The motor I just bought has an EJ20G engine code on the timing cover, but doesn't look like it. I need to know how to wire this thing for my swap, and the throttle body looks like a K to me. Help?
#2 |
Member#: 16819
SCIC
Vehicle:2002 MBP WRX, '98 OB Three Gen 1 Legacy Turbos |
"Late" EG20Gs are wired like Ks.
The coil on the manifold marks yours as a "Late" (3-plug ECU). Early ones had the COPs. If you need the early throttlebody (4 plug ECU) then there have been a few folks to flip an early TB and add a small spacer to mount it on the late (K-style) intake manifold. |
#3 |
Member#: 291739
I got this from Tiger JDM with an Z5 ecu, which is a 4 pin G ecu. I should get them to ship me a different ecu then?
#4 |
Member#: 291739
I'd rather have the 280 HP EJ20k ecu (the 6S I think?) if I can.
#5 |
Member#: 16819
SCIC
I, personally, like the early stuff because Rob has an off the shelf, tested, and trusted tune for them.
IIRC, the 280HP ECUs have a hard time with our gas. Do you have a harness also? If so, is it for a 3 or 4 plug ECU? You might need a 4 plug/COP motor instead? |
#6 |
Member#: 291739
I have a Z5 ECU but I'm gonna get them to send me a 6S or 75 cause the k wiring can't run off of a Z5, correct?
Also, I have access to 93 octane all over, not sure if that makes a diference. |
#7 |
Member#: 51480
International
Vehicle:1984 AM5, 1994 BC4, 2010 BR5 |
You need a 3-plug ECU to run that engine. If it has a TD04 turbo, grey top injectors and a purple label MAF you need either a 2S (WRX Wagon M/T) or 4W (Forester Turbo M/T). If it has a VF-series turbo, yellow top injectors and an orange label MAF you need either a 1S (WRX) or 6S (WRX STI) ECU. The STI ECU runs a bit more midrange boost but power levels are the same (280 PS @ 6500 rpm).
#8 |
Member#: 51480
International
I now see the engine has a flex plate so it's definately got a TD04 and grey top injectors (at least that is how it left the factory).
#9 | |
Member#: 291739
#10 |
Member#: 51480
International
No, the EJ20K ECUs run bigger injectors and a bigger MAF. When mixing these up driveabilty will be quite poor indeed.
#11 |
Member#: 291739
I can find these injectors a lot of places, but where would I find this MAF?
I'm sure the 6S is a more aggressive tune, can I plug it up just so I can drive the car, and pick up the injectors and MAF in the meantime? |
#12 |
n00b Moderator
Moderator Member#: 811
Vehicle:2000 RS-Ej20G It tastes like burning |
In general you need to match the ECU to the injector size and MAF version it expects. Otherwise you are asking for trouble.
Besides that, your motor has a CR of 9:1. If you try to run an ECU meant for high octane AND 8:1 engine, it certainly will not last long. -Rob |
#13 |
Member#: 291739
Thanks Rob, I'm getting a 2S for it. Problem solved!
#14 |
Member#: 88618
SCIC
Vehicle:1994 Legacy "The Silver Slug" |
So what's the power output of the forester 20G?
#15 |
Member#: 291739
#16 | |
Member#: 88618
SCIC
#17 |
Member#: 71627
Vehicle:0205 Vf39 Wrx/Fz XS Wbp/silver |
Here is my 1c,
http://forums.nasioc.com/forums/show....php?t=2360544 |
#18 |
Member#: 51480
International
Late EJ20G in Forester and Impreza WRX Wagon made 250 PS. Both are high compression engines (9.0:1).
I have a 4W ECU available should you be interested. |
#19 | |
Member#: 88618
SCIC
I live in New Zealand so most of the JDM stuff is accessible to me. |
| Thread Tools | |
| Display Modes | |
| FS : cable throttle body, Pics! | scby rex | TXIC Private Classifieds | 21 | 07-20-2012 08:07 AM |
| EJ20G throttle body rebuild/replacement? | tenchu | Pre-2002 Factory Turbo Powertrain | 8 | 06-11-2010 10:37 PM |
| Rotating DBW Throttle body ? Feedback Needed | Hayaboosted | Factory 2.5L Turbo Powertrain | 0 | 04-29-2010 12:01 PM |
| Removing throttle body -- need quick help | GTWagon_Phreak | Legacy Forum | 14 | 10-15-2005 07:38 PM |
| Throttle Body Hose Needed (Red) | mantra1 | Private 'Wanted' Classifieds | 4 | 08-14-2003 12:54 PM |
